Can i empty the waste toner on a bizhub c252?
I know I am supposed to replace the waste toner box, but as I've discovered on a few occasions, there are certain parts of the machine that can be reset/emptied as opposed to having to replace. Thought it worth asking just in case!
  • 624 Answers
SOURCE: Ricoh CL3000 Laser Replace Waste toner
Couple of things to try: - If you just emptied the waste cartridge then you have to take the bottle back out and clean the insides as well. The sensor sees the toner on the walls and still thinks it?s full. FYI as typical the manufacturer recommends replacing the bottle with a brand new one. - If not that then you may have toner covering the optical sensor. Try blowing the area where the waste bottle attaches to the printer with canned air. Let us know if you have any other questions and please don?t forget to rate this post.
Posted on Feb 17, 2007
tech435
  • 284 Answers
SOURCE: waste toner box
you need to talk to a dealer so they can go into service mode and reset the counters., im sorry to say i dont know what password they used to block the service mode. or i could help
Posted on Oct 23, 2008
  • 990 Answers
SOURCE: estudio 3511 empty waste toner problem
Hello sir;You have to empty waste toner container, it located at the end of the drum unit.
Posted on Jan 05, 2009
  • 2072 Answers
SOURCE: waste toner container replacement
Yes you can. But there is a window at the top of the bottle . There is a sensor that looks through that window to sense toner in it. It is a small area about a half inch high and quarter inch wide that bulged out of the top of the bottle.
Poke a hole in it, clean it with a q tip and reseal the opening you make .
That should do it.
Posted on Jul 02, 2009
xeerie
  • 347 Answers
SOURCE: Emptying waste toner BizHub C250
It has the facility to empty the waste toner cartridge manually.You do not need to buy new one.
Posted on Jun 05, 2012
I keep getting an error message stating to install a waste toner box and close all doors.
Printers usually have a waste collector where excess toner is collected. Obviously, yours needs to be changed.
Mar 07, 2016 | Konica Minolta Bizhub C452 Color Copier,...
Reset Waste Toner
If your machine is displaying "replace waste toner container" then you can empty the waste toner box & reset the machine.
If you open the front door you will see a large black box & above this a small rectangular green button. Pressing this button will release the black box. The box will then lift upwards from the machine. At the bottom of the box you will see a round, clear plastic bung, remove the bung & empty the waste toner into a suitable bag or container. Once emptied, the bung can be re-fitted, the waste box can be inserted back into the machine. Locate the waste box into the 2 slots then push the waste box firmly back in place until it latches. Turn the machine off & on using the switch located to the left of the waste box in the bottom left corner of the inside of the front door. This should reset the machine. Be careful when disposing of the waste toner, it is flammable so do not dispose of in a fire. Hope this helps.
Dave.
Feb 19, 2016 | Sharp MX-3501N All-In-One Printer
Message on screen says "Waste Toner Box Full"
Typically you will need to replace the waste toner box. There is usually a difficult to access part of the bottle that is used by an optic sensor to tell when the box is full. Plus toner is very fine and you do not want it getting into the air. Toner will pass through the filter of most vacuums and go back into the air.
Dec 12, 2015 | Kyocera FS-1035MFP
Ive replaced the waste toner box in a Brother MFC-9140CDN but the replace WTB message still continues and I still can't print. Its supposed to last for 50,000 pages, its done 8,000 pages.
Check your operator''s manual for a reset procedure. If this doesn't work, pull the AC plug overnight, if the error isn't stored in a flash memory, this may help reset it.
Jun 25, 2015 | Brother Office Equipment & Supplies
My bizhub c252 keeps reading low toner for yellow, and after a few copies it reads no toner and has to be reset to continue working. What is the problem
you may have to get into the printer settings on your PC and tell the printer it has a new cartridge installed. the easiest way is to open the computer folder and right click your printer and select properties. you can also go to start-control panel-hardware and sound and select view devices and printers then right click your printer and either select printer properties or troubleshoot. troubleshoot may give you an answer or idea how to correct the toner issue
Nov 24, 2014 | Konica Minolta BizHub C252
Waste toner bottle full so replaced but will not reset and says still full
then the clear section of the waste toner bottle is not clear some toner is left blocking the sensor that monitors the waste toner level
Apr 02, 2014 | Konica Minolta New Bizhub C25 Color Laser...
Epson C2600N waste toner collector full warning, after replacing the collector
Victor_Ott:
You have emptied the waste toner bottle, now you have to tell the printer that you have done so. The waste toner collection system has a "latch" (electrical signal) that is tripped when the bottle is full. it may be a pressure sensitive switch under the bottle or a photo-sensor that senses the toner level when full. I don't know the sequence of events to "switch" that latch. Usually on the larger machines it is a series of keystrokes on the printer's keypad, starting with turning the machine off and holding down a series of keys while turning the machine on (known as the "maintenance mode". Once you are in the maintenance mode, you can "trip" that "latch" to let the copier know that the toner collection bottle has been emptied.
Sep 22, 2012 | Epson AcuLaser C2600N Printer
May 15, 2012 | Konica Minolta magicolor 5430 DL Laser...
Sharp MX 2300N - Toner collection unit needs replacing, not sure what this means. We replaced toner cartridgers very recently and assume this is a container that collects loose toner particles. How do...
REPLACING THE WASTE TONER BOX
The waste toner box collects residual toner that is produced during printing. When the used toner box is full, the display
will show "Replace used toner container". Follow the procedure below to replace the used toner box.
Open the front cover.2
Release the used waste toner box.
The waste toner box will fall forward as shown.
Gently support the box with your hands as you let it fall forward
as far as it will go.
fmtx.png Remove the waste toner box.
Hold the box by both hands and lift it up slowly.
If the waste toner box falls too far forward, it will not be possible
to remove it. (Remove the box when it is at an angle of about
30 degrees.)
Install the new waste toner box.
Insert the box from above at a slant. (The direction opposite to
when you removed it.)
Push the waste toner box into the
machine.
Push the box in until it clicks into place.
Close the front cover
Hope this helps.
Feb 07, 2011 | Sharp MX-2300N Color Copier
35 people viewed this question
k24674
