Question about Kyocera Mita TASKalfa 180 Black Toner Cartridge Genuine
Shake toner container problem - Kyocera Mita TASKalfa 180 Black Toner Cartridge Genuine
The toner container may be almost empty.
Jan 22, 2017 | toner Office Equipment & Supplies
Please send me a manual on how to fix this problem of shake toner container
Since you did not provide the manufacturer make and model, recommend google searching for it by including the word manual. You can also search shake toner container problem and get good results for various models.
Apr 06, 2015 | Office Equipment & Supplies
How do I change the toner if it gives me the message : AP adding powder
4 Slide the toner container to the left and then pull it out toward you. 5 Gently pull the cleaning shaft out as far as it will go and push it back in 2 to 3 times. IMPORTANT Do not pull the cleaning shaft with force or pull it out completely. 6 Hold the new toner container vertically and tap the top 15 times. Turn the container upside-down and tap the top 15 times. Then, hold the container horizontally and shake it from side to side 10 times. WARNING High voltage is present in the charger section. Take sufficient care when working in this area, as there is a danger of electrical shock. 7 Install the toner container. * First insert the toner container into the copier as far as it will go and then slide it to the right as indicated by the marked arrows.
Mar 04, 2015 | Kyocera Mita KM 1510 Laser Printer
E000025-0103
This is a easy fix and very common problem. It is caused by toner from the toner cartridge dropping onto toner supply sensors.(The last two digits of the sub code 0103 denotes which sensor (03 in this case is the black toner supply sensor).
Fix open front cover remove waste toner container by releasing blue locking lever on the right.(point of consideration, when removing waste toner container be careful not to shake or tilt container as if full can spill over into full detection window causing 'waste toner full message'). Then you will need to remove the cover directly above waste toner container, there are 3 screws one at the very bottom of cover roughly in the middle, one top left of cover and one under a cover on the right of cover (to remove the right side screw press down on top of the small cover whilst pulling, this cover will pop off allowing you to get screw out.) now you can remove this cover, underneath this cover you should see a circuit board with lots of wires.Now remove this circuit board and remembering where all the wire connections are and the plastic circuit board support where the circuit board was attached too, allowing visual of all four sensors and ease of cleaning with a blower brush. Re-assemble the copier and reboot machine. Job done.
Jun 18, 2012 | Canon iRC2380i
Toner empty error. None of the solutions worked.
Replace the container that holds the TONER INK.
Maybe, just removing the cartridge, and gently "rolling" it (not SHAKING it) from side-to-side, and then re-inserting it, will temporarily work.
May 20, 2011 | OKI B4600 Printer
How to change the toner cartridge?...please I need help!
1 Open the top cover.
2 Open the front cover.
3 Lift the process unit, together with the toner container, out of the machine and place it on a clean, level surface.
Do not stand the process unit on end and never expose the drum to normal lighting for more than five minutes.
4 Pull the lock lever towards to the UNLOCK position then pull the toner container release lever to the right.
5 Gently remove the old toner container. Put it in the supplied plastic bag and dispose of it according to local rules and regulations.
6 Shake the new toner container horizontally 5 or 6 times to distributed the toner inside.
7 Remove the orange protective seal.
8 Align the knob on the left side of the container with the groove in the process unit and insert it. Push on the PUSH HERE marks until the container clicks into place.
9 Push the lock lever back into its locked position (away from you).
Clean the charge and registration roller.
Refer to Cleaning the Charger and the Registration Roller on page 5-4.
Feb 22, 2011 | Copystar CS-1820 Copier
Used toner bottle is full, how do I change it or fix it?
One possibility is the toner is caked inside. Solution: shake and reinsert in machine.
1) Wrap toner bottle w soft cloth or pliable paper 2) Shake gently up/down twist. 3) Replace container into machine.
This solution has avoided the trouble of repurchasing the same product.
Good luck.
Mar 22, 2010 | Office Equipment & Supplies
It says that it needs toner to finish copying but we had already replaced the tone a day ago
common thing in a office is people are lazy. instead of inserting new toner they shake the container which tricks the toner level sensorthus running you out of toner in the inner hopper. or someone is only loading half at a time
Mar 19, 2010 | Konica Minolta Office Equipment & Supplies
Replace waste toner container message
I have a CLX-2160N and have just emptied my own waste toner container. (Disclaimer: not sure how toxic or environmentally friendly this is).
Emptied carefully and thoroughly (fine dust). Immersed in bowl of warm soapy water, and vigorous shaking to get nice and clean.
Shook all water out well, and dried off as much as possible. Reinstalled. Turned printer back on. Hey presto - seems happy.
Mar 04, 2009 | Samsung CLX 3160fn All-In-One Printer
Kyocera Mita TASKalfa 180 Black Toner Cartridge Genuine Logo
121 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Kyocera HP Expert
Henry Gertcher
AAAA262430
Level 1 Expert
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
