Water pumps in and out, but wash cycle never starts
Sorry - wrong forum
  • tom cassidy
    tom cassidy Apr 12, 2015
    Hi Nigel Sykes, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
  • Nigel Sykes
    Nigel Sykes Apr 13, 2015
    Sorry Tom - I accidentally posted this in the wrong forum and couldn't work out how to delete it - hence the lack of details since I 'edited it out'. I started a new question thread in the dishwasher forum instead...
  • Washing Mach... Master
  • 5,323 Answers
Washer fills with water then drains:
The critical question is. Is the water is just running down the drain but the pump isn't running. If it is being pumped out, and you can hear the pump running just the same as when it's emptying prior to spin then it could be aborting the wash because it is, or it thinks it's overheating. ( due to defective water temperature switch)
If the pump is failing to shut off then there is something wrong with the electronics. If your washer is a mechanical timer controlled device then you may have a sticking switch (which may explain if switching cycles does something for you). But if you have an electronic timer then you may be experiencing a board failure, where a cycle is being commanded when it is not intended to by design.
If water isn't being pumped out, but just draining away all the time, the washer will keep detecting there isn't enough water inside and top up with more.
Modern washing machines should be sophisticated enough to realize something's wrong and abort with an error, but if not, it may continue washing or rinsing for a short while before losing enough water to trigger more coming in again. It can get stuck on this cycle indefinitely and it's called siphoning.
Siphoning occurs when the end of the drain hose is lower than the level of the water inside the washing machine.
Try raising the hose and see what happens.
Also the drain hose should have some type of air gap where it fits into the stand pipe. It should not have an air tight fit.
Again Either it's siphoning down the drain due to an issue with the plumbing, it's overfilling, or also if it ( THE WATER) overheats then in some machines the software will employ a fill and drain tactic to cool down the water. The important thing is to work out which of these different faults is causing the problem by careful observation.
Other switch's to check would be the water inlet valve and the water pressure switch with a multi meter for continuity or OHMS.
Posted on Apr 13, 2015
Washer_tech
  • 164 Answers
SOURCE: Water not pumping out and spin cycle not working.
it sounds like you have something obstructing the pump. does the machine eventually empty? or does it remain with water in it. you need to remove the hose that leads from the tub to the pump and clear any debris. if you continue to run with debris in the pump you could burn out the pump motor
Posted on Jul 02, 2007
Coldcut
  • 1554 Answers
SOURCE: Washing machine it shuts down water filling cycle
First thing to check is the filter,
DISCONNECT power
open the bottom pane (3 screws on bottom front lip)
in the cent is a large removable filter ,
set a pan or rags under it ,there will be water.
clean out any debris an be sure the pump impellers move freely.
let me know if that fixes it.
Posted on Jan 29, 2008
yalmer
  • 549 Answers
SOURCE: wont pump water
If it did not pump at all I would say you had a bad pump. Try removing hoses and check for plug up. If there is no plug up, I would manually try to adjust the timer to see where in the cycle it does not pump. It could be a bad cycle timer.
Posted on Feb 04, 2008
barkencoa
  • 3463 Answers
SOURCE: washing machine stops mid cycle and lights start flashing
Drain the water by lowering the hose into a bucket or something and then try it on spin, if it spins o/k then you probably have blocked pump or filter.
The filter is located in the large black hose that is fastened to the bottom of the drum, remove and clean.
Hopefully this will solve the problem.
Plz rate this solution.
Thanks.
Posted on Dec 17, 2008
  • 236 Answers
SOURCE: Washing machine is not completing it's wash cycle
either you have a blocked hose to the pump or the pump itself is either jammed or the impellor has come off the shaft. either way i think you will need to replace the pump. i presume you managed to get the water out? if so i would say the pump is favourite.
Posted on Mar 16, 2009
SORRY wrong forum but hope it can still be answered. Quiet Partner 3 dishwasher completes diagnostic perfectly but will not run normal cycle. Inlet valve works as does the float during diagnostic.
Does the water fill during other cycles? How did you confirm the water inlet valve works, through the diagnostic mode or just by applying power? There's a chance it is not providing enough water pressure to trigger the pressure switch (although that would likely cause a diagnostic code).
Oct 15, 2016 | Washing Machines
How to stop the water?
Not knowing what brand / model you have makes it difficult however, the basic symptoms of a water problem are; If the water keeps coming into the machine with the power off and the tap on, it will be a valve fault. If the water keeps coming in with power on and on a wash cycle, its likely to be a fault with the pressure switch, pressure tube (Split or hanging off) or an electronic failure of the control board.Lastly, check the drain hose. If the end of the hose is lower than the water level of the machine, it is possible for the machine to start syphoning itself. Espe3cially just after the first pump out (Start of Rinse cycle) Make sure the machine is actually pumping water out. If it cant pump out, the machine may try to refill but it is already still full from last wash , causing the error code to flash. Check for pump jamming up with foreign objects, or hoses blocked with a sock, lint etc.. Sorry but cant help much more than this.
Sep 02, 2014 | Washing Machines
The product only washed two cycles and got stuck on the third and now it doesn't even turn on. What is the problem?
Sorry but with such a fault it is virtually impossible for anybody on this FixYa forum to guess remotely what is wrong with your washer.
It could be internal wiring/plugs sockets, control panel switches, control PCB, water inlet control valves, door solenoid, main motor, drain motor etc..
I fear that your only real option is a service call as the engineer will have the right equipment to safely diagnose what is wrong.
By the way it is always better to tell us on the FixYa forum the make and model ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Oct 06, 2011 | Washing Machines
MY WASHER TRIGGERS THE MAIN POWER FUSE BOX EVERY TIME I PULL THE BOTTON TO START THE CYCLE
Sorry but with such a fault it is virtually impossible for anybody on this forum to remotely guess what is wrong with your washer.
It could be internal wiring/plugs sockets, control panel switches, control PCB, water inlet control valves, door solenoid as primary suspects. Secondary suspects could be main motor, drain motor.
John C
Jul 30, 2011 | Washing Machines
Kenmore Washing Machine Belt-driven, top loading Model 110-8228310 Stock # 22831 Machine was over- loaded. Machine Stopped in Rinse Cycle did not empty water. Cleared load. Made New loads, machine...
I'm surprised the main breaker didn't trip or fuse blow as the washer has obviously demanded a fair amount of current to 'slightly' melt the end of the cord!
Sorry but with such a fault it is extremely difficult for anybody on this forum to remotely guess what is wrong with your washer. It could be the main motor, following the overload, or drain pump/motor as primary cause followed by damage to internal wiring/plugs sockets, I fear that your only real option is a service call as the engineer will have the right equipment to safely diagnose what is wrong.
John C
Jun 27, 2011 | Washing Machines
Washer keeps tripping electric out whilst running through its cycle
I fear that you only real option is a service call as the engineer will have the right equipment to safely diagnose what is wrong.
Sorry again and good luck,
John C
Mar 17, 2011 | Hotpoint WMM75 Front Load Washer
Washing machine tripped my electric and when i turned it back on it will not run cycle ive checked theres no blockages and door is secure do you think it is thermostat it is trying to do wash but then...
Sorry but with such a major fault it is virtually impossible for anybody on this forum to remotely guess what is wrong with your washer.
John C
Mar 09, 2011 | Asko 8005 Front Load Washing Machine
Does not appear to be cycling water or pumping
You have created a suds lock condition with the wrong soap.
Take a shop vac if possible and vacuum out all water and suds. No shop vac, bail and wipe with a towel.
Then fill with COLD water from the faucet. Start the was cycle a few seconds. Then DRAIN. Repeat with cold water, wash then drain several times until the suds are clear.
You will know the suds are clearing each time you refill with COLD water and start the cycle. It will begin to sound like it is washing and pumping rather than humming.
May 05, 2009 | Dishwashers
Not washing at all on any cycle
Sorry, sounds like your Circulation Pump is faulty/worn out.
If your machine is not over two or four years old then maybe you have a simple blockage.
If your machine is old, a new pump can be half the price of a new machine.
Hope this helps.
Apr 16, 2009 | LG Dishwashers
CANT DRAIN OR SPIN WATER OUT OF MY WASHER
you have a clogged water pump....its simple to unclog but thats whats wrong a clogged water pump
Jan 29, 2009 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
