Please send me a manual on how to fix this problem of shake toner container
  • 3,960 Answers
Since you did not provide the manufacturer make and model, recommend google searching for it by including the word manual. You can also search shake toner container problem and get good results for various models.
Posted on Apr 06, 2015
2 Suggested Answers
  • 53 Answers
SOURCE: Replace waste toner container message on IR 5570
on right hand side is waste toner you should be able to dump it yourself the main problem is reseting the counter that is not included in your manual Go into service mode by depressing the additional function key, then 2 & 8 at the same time, then aditionall function key. Select copier, then at the top far left side select counter. I blieve the counter is under MISC as waste toner. Select waste toner, depress the " C " buton on the keypad and it should reset to all 0's
Posted on Jan 18, 2010
Shake container error taskalfa 180 how do i fix the problem
make sure you are using Kyocera oem toner first of all then if you are remove the toner cartridge and shake it back and forth
Jul 28, 2017 | Kyocera Office Equipment & Supplies
Shake toner container
The toner container may be almost empty.
Jan 22, 2017 | toner Office Equipment & Supplies
I have a kyocera 180 copier does not print texts even when we do internal print. it's blank when copying. We change DRUM, TONNER, DEVELOPER and MOTHER BOARD but still the same. Is there any other thing...
I have a kyocera 181 copier when we switch on the machine it showing error message " shake the toner container' kindly do the needful or send me service manual as soon as possible
I am awaiting for valuable response....
Sep 18, 2013 | Kyocera TASKalfa 180 Copier
How to change the toner cartridge?...please I need help!
1 Open the top cover.
2 Open the front cover.
3 Lift the process unit, together with the toner container, out of the machine and place it on a clean, level surface.
Do not stand the process unit on end and never expose the drum to normal lighting for more than five minutes.
4 Pull the lock lever towards to the UNLOCK position then pull the toner container release lever to the right.
5 Gently remove the old toner container. Put it in the supplied plastic bag and dispose of it according to local rules and regulations.
6 Shake the new toner container horizontally 5 or 6 times to distributed the toner inside.
7 Remove the orange protective seal.
8 Align the knob on the left side of the container with the groove in the process unit and insert it. Push on the PUSH HERE marks until the container clicks into place.
9 Push the lock lever back into its locked position (away from you).
Clean the charge and registration roller.
Refer to Cleaning the Charger and the Registration Roller on page 5-4.
Feb 22, 2011 | Copystar CS-1820 Copier
Free service manual with code for kyocera TASKalfa 180
Pls. send Free service manual with code for kyocera TASKalfa 180.
My email itechf2@gmail.com
Especially interisuet off hibernation.
Aug 05, 2010 | Kyocera TASKalfa 180 Copier
Keeps saying toner empty even when replaced with new toner
Please do not be offended by any of the suggestions. I do not assume anything.
Toner can become "caked" slightly hardened, so if you have the opportunity to shake the toner inside its container, do so.
If you have replaced an entire unit, confirm protective strip has been removed from toner before installing into cartride or its proper placement.
These two suggestions are preliminary to comprehensive troubleshooting.
Try that
Mar 24, 2010 | Brother IntelliFAX 4100 Laser Fax
Used toner bottle is full, how do I change it or fix it?
One possibility is the toner is caked inside. Solution: shake and reinsert in machine.
1) Wrap toner bottle w soft cloth or pliable paper 2) Shake gently up/down twist. 3) Replace container into machine.
This solution has avoided the trouble of repurchasing the same product.
Good luck.
Mar 22, 2010 | Office Equipment & Supplies
Samsung 350N seizes up during warm-up cycle.
I think I have fixed this. The waste toner container was fairly full.This problem was initially intermittent and then persistent. Opening the printer cover and closing it was enough to shake the toner clear of the sensor until it became so full that shaking it made no difference. There was nothing to differentiate this problem from a paper jam so it was just luck that I checked the waste container. A quick short term fix was to tilt and tap the container to clear the sensor window, but the risk is that the container will overflow. Samsung tell you to replace the container (for about $AUD25) but it can just be emptied. I used a vacuum cleaner to **** out most of the toner and then washed out the rest with soapy water. I rinsed it with a solution of about 20% alcohol and then left it to dry over night. No problems since.
Jan 30, 2010 | Samsung CLP-350N Laser Printer
I have a CLX-2160N and have just emptied my own waste toner container. (Disclaimer: not sure how toxic or environmentally friendly this is).
Emptied carefully and thoroughly (fine dust). Immersed in bowl of warm soapy water, and vigorous shaking to get nice and clean.
Shook all water out well, and dried off as much as possible. Reinstalled. Turned printer back on. Hey presto - seems happy.
Mar 04, 2009 | Samsung CLX 3160fn All-In-One Printer
62 people viewed this question
k24674
jasbo
jasbo
