My touchpad does nor Work have i touched a key or vhat do i do
    Top Expert:
  • Computers & ... Master
  • 51,186 Answers
My laptop has and fn button that if you hold it down and tap f9 it turns the touch pad on or off
Posted on Apr 06, 2015
Turn on touchpad on
Do you mean the mouse buttons below the touchpad do not work but the actual touchpad does? If so I would try removing/reinstalling your touchpad drivers. If that holds no success I would consider replacing the touchpad hardware.
Mar 20, 2014 | Computers & Internet
Touch pad does not work
Locate the "Fn" key in the lower right or left corner of the laptop keyboard. The "Fn" key typically has different colored text on it or the key itself is a different color. Locate the function (F1 through F12) key at the top of the keyboard that disables or enables the touchpad on the laptop. The key typically has an icon that resembles a touchpad with a finger touching it or a touchpad with a diagonal line through it. Press both the "Fn" and touchpad Function key simultaneously to reactive the touchpad on your laptop. Move your finger along the touchpad to verify that it works. Press the combination at any time to disable the touchpad again.
Feb 27, 2013 | Computers & Internet
Asus Laptop Touchpad trouble shooting
Step 1:
Touchpad Not Working in Laptop b> Locate the "Fn" key in the lower right or left corner of the laptop keyboard. The "Fn" key typically has different colored text on it or the key itself is a different color. Locate the function (F1 through F12) key at the top of the keyboard that disables or enables the touchpad on the laptop. The key typically has an icon that resembles a touchpad with a finger touching it or a touchpad with a diagonal line through it. Press both the "Fn" and touchpad Function key simultaneously to reactive the touchpad on your laptop. Move your finger along the touchpad to verify that it works. Press the combination at any time to disable the touchpad again.
Feb 06, 2013 | ASUS Computers & Internet
Pontier will not work
The touchpad pointer?
Click Start/Control Panel andlook for the Mouse and open it to check the mouse properties. Make sureyou don't have the touchpad disabled.
Some models will allow you to toggle the touchpad on or off by clicking on thebutton that is located at the top of the touch pad in the middle.
Some models will allow you to toggle the touchpad by tapping twice in the upperleft hand corner of the touchpad.
Some models will require a keystroke to toggle the touchpad. Press andHold the ALT or FN function key located at the lower left portion of thekeyboard, then hit the key that toggles the touchpad. The correct key tohit will have the icon of a finger pointing at a square that represents thetouchpad.
Download and reinstall the touch pad drivers.Get online and got towww.google.com In the google search box type: "Dell Support"(without the quotes and put your manufacturer name before Support). Lookfor downloads and drivers. Enter your model number and operating system whenrequested. Download and install the Touchpad drivers.
May 26, 2012 | HP Computers & Internet
Touch pad is not working?
Just check for the key combination on your key board (ex. Fn + F4 or F5..depends on the what key was designed for the touchpad), the touchpad might be locked.
If it is not locked, reinstall the touchpad driver, but it this still doesn't work, boot to Safe Mode to check if it does. Touch pad still not responding in Safe Mode would mean hardware failure.
Hope this helps.
May 25, 2011 | NEC Versa FX Notebook
Dear Sirs, I have been using Toshiba Satellite M326 for about one year. Suddenly, the touch pad no longer working and now I need to use an external mouse. I am not sure whether it is due to the fault...
If you accidentally turned it off it would be one of the function keys. The one for the touchpad would have a small picture of a touchpad on it and a touchpad with a diagonal line through it. Possibly F9. You have to press and hold the Fn key and press the key with the small picture of a touchpad on it together. If that doesn't work then you might have a problem with the touchpad or the software for it.
Aug 30, 2010 | Computers & Internet
Satellite P505 Model S8980 - unable to get TouchPad to work now where it did work before. The TouchPad ON/OFF button nor the Fn+F9 approach are no help. A USB-connected mouse worked fine, tho. Just no...
----- control panel - mouse - see if touch pad disabled there ----- have a look in the bios/setup and see if the touch pad is disabled there, as the PC boots - you should see which key to use to enter the bios/setup F2, F10, DEL KEY are often used ----- On some machines a combination of FN and F key can disable/enable the touch pad - F7 or F9 ----- If you point the mouse to the top of the screen you may get a menu dropdown, which will also tell which key to use to disable/enable the touchpad ----- control panel>system>{vista}lefthand side device manger or {XP}hardware>Device Manager>Mouse and other pointing devices>Touchpad>highlight touchpad and right click, Properties, may be an option here to Disable/enable,
Feb 18, 2010 | Toshiba Satellite P505-S8950 Notebook
Hi.my touchpad don't work at all!!I can't do anthting with my touchpad.
The pad may be defective buy a cheep wireless usb mouse for it and use it to work without the pad. the pads do wear out and the replacement would be over a 100 Bucks.
Jan 15, 2010 | Acer Aspire 5100 Notebook
The left key on my dell touchpad is not working
that part of the touch pad is not working anymore, its faulty and you need to replace the whole touch pad.
I don't know why this is mostly common with Dell. My friend has a Dell inspirion 1501 and the touch pad has exactly the same problem as yours.
I would advice you get a USB mouse to keep you going pending the time you get the touch pad fixed.
I wish you the best of luck.
Jan 06, 2010 | Dell F3534 Touchpad
Touch pad center click button no longer works
Near your clock, you'll usually find an icon for your touch pad (probably synaptics). Open this & select mouse properties, in there look under Device Settings & try the "Reset Devices" icon.
If that don't work, Click start>control panel (classic view)>mouse.
On the Touchpad tab, make sure the 'tapping' box is checked . Click apply, click ok.
If that doesn't work, click start>run, type devmgmt.msc
and click ok.
Click the plus to expand Mice and Other Pointing Devices.
Right click and uninstall any mouse or touchpad listed.
Reboot.
Let Windows rediscover and reinstall the touchpad drivers.
Good Luck!
Jan 09, 2008 | Acer Aspire 3680 Laptop
Computers & Internet Logo
David Payne
David Payne
