Question about Miele Washing Machines
How to fix Miele WT2670. No issue in doing the wash, but when it comes to drying, it seems to be stuck in the last 12 minutes . Then eventually the machine stops, but the clothes are still not dry
The machine has no issues in washing, but when it comes to drying, it would stuck in the last 12 minutes (and keeps going on for about an hour). When the machine eventually stops, the clothes would still end up not dry, despite filter has just been cleaned. Can anyone please help with a solution? Many thanks
    Top Expert:
  • Miele Master
  • 50,169 Answers
Perhaps the timer has gone bad many times the washer does not spin out as fast as they should thereby making the dryer work even harder to dry the clothe completely .
Posted on Apr 06, 2015
  • Anonymous Apr 06, 2015
    Hi Ray. So is there I can do at this stage to fix the timer? Any other areas that I need to check? Thanks
MIELE W412 PREWASH INDICATOR FLASHING
If your PreWash is flashing then you have a pressure problem. You can dry using a washer machine cleaner or doing a hot cycle with white vinegar. If that doesn't help the electronic would have to be changed.
Jan 08, 2012 | Miele W412 Front Load Washer
How do i remove the lid of a miele wt2670 wasing machine
Two small screws at the back and one on either side (behind little covers)
There are two hinges at the back, so lift off from the front up.
Aug 28, 2010 | Miele WT945 Front Load Washer / Dryer
I have a G656 SCi Miele Dishwasher and the water
Probably the heater relay - do you have any fault codes?
Aug 24, 2009 | Miele 24 in. G656SCi Plus SS Built-in...
Miele WT2670 message on screen "waterproof system activated". How do I reset?
I've just had this fault on this model, Its caused by a leak of water into the tray at the bottom, which activates a sensor to shut the water in flow off and thus prevent a flood. The fix is as for a posting by halldor to a question about the w4146 - ie.
Turn off and unplug, drain by the filter plug, lean the machine forward - the water flows out the bottom, plug in and it should work.
You do need to establish the cause of the leak first. Mine was a draw cord on some trousers dangling out of the door, thus preventing a proper seal, the water dribbled down the front and into the tray. Miele stated it could only be fixed by their service mechanics - I'd have had to wait 10 days!
Jul 17, 2009 | Miele Washing Machines
Wps code
Simply disconnect it. Water completes the circuit - so you want to make sure it is open.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 26, 2009 | Washing Machines
Spin cycle lasts indefinately
the spin cylce in washer, did not shut off?soundslike an issue with the timer itself, no servicing htetimer strictly replace, as far as teh time in the dryer, i would check for clogged/kinked dryer vent, biggest issue with any dryer, innadequate vent
Nov 25, 2008 | Kenmore 98702 Stacked Washer/Dryer
Washer water level low, clothes come out dry !!
This is the water saver feature and the only solution may be to put it on the maximum wash cycle to get clothes really clean.
These washers normally get the clothes almost dry.
Mar 04, 2008 | Frigidaire GLTF1670A Front Load Washer
Miele transit rods stuck
My husband was able to pull it out .
Feb 27, 2008 | Miele Washing Machines
Timer stuck on dry
i have Miele electronic G562 dishwasher which gets stuck in cycle exactly on 1/2 way main wash when the water is is comming in can i fix it myself?
Dec 21, 2007 | Dishwashers
Washing Machines Logo
423 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
mpservices
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
