Question about HP Computers & Internet
My hp compaq la2306x monitor has smoke coming from the back when i connect to the power.it works well. what is the problem?
    Top Expert:
  • HP Master
  • 1,144 Answers
In case of intensive white smoke, one electrolytic capacitor in the power supply is faulty (perforated). Do not use the monitor - must be repaired!
Posted on Apr 06, 2015
    Top Expert:
  • HP Master
  • 6,702 Answers
Switch it off as soon as possible and don't use it till you found what is smoking. Unless someone was blowing smoke as a joke, smouldering something inside won't take long till it burns or makes a shortage, what in turn can blow the power supply.
When you don't have the skills to repair electronic things, please ask a tech to see what is wrong, before it is defect complete.
Monitor will not stay powered up
It is possible that the monitor is going back into "Sleep mode" meaning it is not detecting a valid signal from whatever device it is plugged into. I would try replacing the cable that is connecting the monitor to the PC or Console. As a trouble shooting step try pulling up the "Menu" on the monitor itself by pressing the "Menu" button on the front panel of the monitor, if this does come up then we can say that the LCD itself is most likely working.
Nov 10, 2012 | HP Compaq WF1907 19 LCD Monitor
HP Compaq Presario turns on monitor stays blank
Yes it could especially when it does not work on another monitor.
Try another video card.
Sep 22, 2012 | HP Compaq Presario PC Desktop
How do i get monitor output
You can switch to anexternal monitor by two methods.1. Connect the externalmonitor to the laptop's video port, power up the external monitor first and thelaptop. The video information will automatically switch to the externalmonitor.2. If you power up thelaptop first then you can switch the video output to the external monitor bypressing the Fn key and one of the Function keys, depending upon your make andmodel laptop. You can also toggle between the external monitor or both LCDscreen plus the external monitor or back to LCD screen only by pressing the Fnkey plus one of the function key. Here is a lkeycombinations for the laptops :-HP and Compaq = Fn + F4
Mar 11, 2012 | HP Compaq nc6120 Notebook
Compaq p1220 crt monitor...no power dear, when the electric power generator is running and i turn on monitor it works....but on the station electricity its does'nt powers on....infact the both voltages...
Sounds like there is an issue with the power coming in or there is a problem with the internal power system have you tried any other montiors on the power generator?
Feb 28, 2011 | HP Compaq P 1220 (Carbon, Silver) 22" CRT...
Compaq FP5315 screen turning off
check the same on bios screen for a long time if the same thing happnes need a repair.
Sep 10, 2009 | HP Compaq FP5315 15" LCD Monitor
My compaq nx6110 screen goes black and on, why?
This is the issue with the monitor.This is a hardware issue.Please connect the notebook to external monitor and check .If it is working fine then it is the issue with the LCD of notebook If not then this is the issue with the video card.
And ckeck the power cables tooi think this is the issue with the monitor of the notebookAny how you can try to install the latest version of video drivers
Jan 08, 2009 | HP Compaq nx6110 PC Laptop
No power to Compaq Presario
There were several recalls on Compaq's ac adapters and batteries that caused fire to units...
Check this out
http://www.consumeraffairs.com/recalls04/2006/hp_batteries.html
I would also check with compaq about your problem. They were replacing and repairing the units free of charge due to the defects. I would check with them
Hope this helps you
Oct 21, 2007 | HP Compaq Presario R4010US (PX352UA) PC...
Compaq fp7317
I suspect that when you reattached the monitor back you might have moved the agp card out of her slot. Check if you have connected properly your monitor to the pc And if the agp is in it's slot properly attached. Hope it helps, good luck!!
Feb 14, 2006 | HP Compaq FP 7317 17" Flat Panel LCD...
Nothing on the screen after power on
Turn on the computer and complete the following steps: Step 1: Check cable connections (If you can see the initial HP or Compaq logo screen but later lose the picture, you can skip to Step 2.) check the video cable connection on the back of the computer and on the monitor. Make sure that it is connected properly and the connecting screws are tight. Turn the monitor off and then back on again (while the computer is on) to see if an image appears. Some Flat Panel monitors have two similar power input connections placed side-by-side on the back of the monitor, which sometimes allows them to get confused for one another. One connector is used to supply power to the speakers with a separate power cord, while the other connector is used for the monitor's power adapter. Ensure that you have the monitor's power adapter cord plugged into the power connector and not the speaker connector. After you have reconnected the power cord, turn on the monitor (while the computer is on) to see if an image appears. If there is still no image, continue to the next Step. Step 2: Resetting the monitor At first setup, or under certain signal conditions, the monitor may not be able to switch to a new display resolution. Do NOT shut down or restart the computer. Instead, perform the following steps: Turn off the monitor using the Power button on the front. If the Power button does not respond, unplug the power cord from the back of monitor and wait five seconds. Plug the power cord back in. You should see the image from the computer on the screen.
Jan 05, 2006 | HP Compaq FP 7317 17" Flat Panel LCD...
Computers & Internet Logo
71 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
