Question about Ricoh Office Equipment & Supplies
Hi! i am using ricoh afficio MP171 SPF. i replaced the toner but it still showing the message "add toner". what can i do please?
I replaced the empty toner with new one, but it still showing the message " add toner" and it is not printing. What can i do?
  • Ricoh Expert
  • 155 Answers
Check toner hopper some times old cap gets caught and doesn't go into old bottle. Remove toner bottle and look inside of toner hopper and see if an old cap still in there. could be photo conductor is bad. How many copies are on it. only good for 45,000 copies to mfg specs.
Posted on Apr 06, 2015
    Top Expert:
  • Ricoh Master
  • 6,702 Answers
You could check if the contacts on the toner cartridge and in he printer are clean and shiny. Perhaps just a bit of glue or a scrap of plastic is on a contact, making it impossible for the printer to read the status.
How to empty ricoh mp171 waste toner
Ricoh MP171 does not have a waste toner container. It recycles used toner back in the developer unit - where it is mixed with new toner and developer powder, and can be used for printing again.
Jun 24, 2017 | Ricoh Office Equipment & Supplies
My Ricoh afficio say add toner while tone is full
If this is a color copier you may have a bad toner pump. Need a model number.
May 30, 2017 | Ricoh Office Equipment & Supplies
mp 171 has no waste toner container. it recalculates toner back to developer section.
Mar 20, 2017 | Ricoh Aficio Mp 171 Spf Copier,...
How do I fix the error code SC 542 for Ricoh MP171 SPF?
Fuser problem will need to be fix ibefore code can be reset
Oct 14, 2015 | Ricoh Office Equipment & Supplies
How to turn off the 'toner empty' message on a Ricoh 1170L
Just looked in the service manual. There is no SP to turn off toner message. The only way to clear it that I can see is to add another toner cartridge.
Apr 13, 2010 | Ricoh Fax 1170L Laser Fax Machine 1170-L,...
Changing developer unit in afficio 450
Remove PCU, remove development unit, remove cover (2 plastic C-clips) remove filter, remove development roller (2 shoulder bolts). Clean roller and empty all developer. Pour in new developer, re-assemble unit. Reinstall drum and Development unit. Place a small piece of paper between the PCU and toner entrance hole to prevent used toner from entering dev. unit during calibration. Perform SP2-801. Remove paper form dev. unit
Apr 24, 2009 | Ricoh Aficio 450 Copier
Used Toner Bottle Full Ricoh Aficio 1035P
The used toner is stored in the Transfer Belt assembly on the right door that you open to remove a jam. Remove one spring on each side and release the catch while gently lifting up on the belt and roller assembly. It swings 90 degrees up from the rest of the assembly. There are 6 screws that hold a cover on the lower assembly. remove it and dump the waste toner. *** VERY MESSY*** have a vac on hand. Not a shop vac unless you want toner clouds floating around the office. If the six screws aren't present, dump the toner out of the **** between the mylar-rubber blade and the lower assembly. once this is done, the message will clear.
Apr 08, 2009 | Ricoh Office Equipment & Supplies
Afficio 450 or gestetner 3245 calibration
Dev. Change Process
1. Check that Dev. unit has the lastest seals.
2. replace dev. material.
3. Dump dev.
4. add new dev. material.
5. Hand rotate the dev. unit 10 times.
6. reinstall the dev. unit into machine.
7. cover the toner inlet opening with a piece of paper
8. insert PCU unit.
9. turn the machine on.
10. When machine reaches ready -- enter SP modes and perform SP-2801 (2 times)
11. open the right cover of the machine. Cheat the right cover switch. Examine the drum as it rotates. Afew bands of toner and the ID pattern will be developed on the drum. The drum should be clean -- a slight dusting on the drum is OK.
12. Perform SP-3001 -- ID sensor initial setting.
13. ** Important** remove the PCU unit. Empty the toner from the PCU by sliding the shutter on the bottom of the PCU to the side and tapping the PCU.
14. reinstall the PCU.
15. Run test copies.
Pls rate -- thank you
Mar 02, 2009 | Ricoh Aficio 450 Copier
146 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
