Question about Inverter Electronics - Others
How to change inverter parameter
How can i set inverter parameter
How to save the parameters in KEB F5
Here is how to use the keypad. If a decimal shows up after the value is changed, enter must be pressed to save the value.
Also insure that the inverter is not enabled or in nOP status.
Jun 27, 2016 | Inverter KEB COMBIVERT F5
Sir i have keb f5 inverter i need default parameter i am trying to external run but i do not have parameter.
There are over 1500 parameters in the inverter. These have been setup by the manufacture of the machine so that the machine functions the way it was intended to in a safe trouble free manner.
Before one defaults the inverter you should always use the COMBIVIS software to obtain a complete upload of all the parameter values. This way you can always get back to the settings before the inverter was set to default.
Also with the COMBIVIS software you can access all the parameters in the inverter. With the software the Fr parameters are where you would find how to reset the inverter to default values.
Dec 11, 2013 | Inverter KEB COMBIVERT F5
Hi, We have KEB F5 inverter on our machine model
If you are connected to the inverter with COMBIVIS, go to parameter FR.01 and enter a value of -4. This will set all parameters back to factory default.
You may be having an issue with the inverters software verison. As long as the inverters are the same part number, you should be able to download the parameters without any issue. There may be some unknown parameters but you should be able to hit ignore and keep on downloading.
Oct 26, 2013 | Inverter KEB COMBIVERT F5
Hi, I have KEB 07.f5.c1b-3b0a inverter. I just got
Via Combivis, write a value of -4 to Fr.01. This will set all parameters back to the factory default values.
Then download your backup parameter file.
Sep 24, 2013 | Inverter KEB COMBIVERT F5
I use KEB 18.F5.CBG340A (22,0 kW) "Compact"inverter , to run this inverter whose parameter must be set from cp mode and application mode
The CP mode parameters are a small list of parameters that are mapped from the application parameters. Not knowing what you are trying to do with the inverter, it is very difficult to tell you what needs to be programmed.
90% of the machines that us the KEB inverters use the application parameters to gain the full functionality of the inverter.
The machine manufacture whom built the machine that the inverter is installed in should be able to provide you with parameter settings.
There are instruction manuals on the KEB site.
www.keb.de
www.kebamerica.com
Sep 04, 2013 | Inverter KEB COMBIVERT F5
I fit a new keb f5 inverter which parameter set to run motor
Pretty general question. If it is a replacement inverter, best source would be to upload parameter values from original inverter with the COMBIVIS software.
Otherwise I would suggest downloading the manual from the KEB web site.
Aug 24, 2013 | Inverter KEB COMBIVERT F5
I cannot change parameters of this drive(Siemens Micromaster 420 6SE6420-2UD22-2BA).
A while from when you asked the question but how you are trying to change the parameters? Through the BOP or software......?
Are you unable to change all or just some of the params?
Use the manual to check your access level in P0003.
Mar 24, 2011 | Inverter Siemens Micromaster 420 Ac ...
When inverter fitting, some parameter are set please name these parameter
What F5 inverter are you asking about? There are many different control stages and each has different default parameter settings.
Nov 14, 2010 | Inverter KEB COMBIVERT F5
Hello I'm use keb f5 inverter. I have to return to the factory parameters. How I'm do it?
It is strongly suggested to contact the OEM of the machine that this inverter is being used on to obtain the actual parameter settings that are required.
Oct 11, 2010 | Inverter KEB COMBIVERT F5
Electronics - Others Logo
156 people viewed this question
Top Inverter Electronics - Others Experts
mntech1
ray gallant
Tom Chichester
Are you an Inverter Electronics - Other Expert? Answer questions, earn points and help others
