Question about Electric Garden
WhySmoke and sparks out of electric motor? - Electric Garden
    Top Expert:
  • Electric Master
  • 12,962 Answers
The windings on the motor rotor or stator have melted to the point where excessive current is entering the motor and causing it to overheat and melt further - results in smoke, possible fire, blown fuses.
Posted on Apr 07, 2015
    Top Expert:
  • Electric Master
  • 44,580 Answers
Probably got water in the motor and it has shorted out. It it doesn't work now It may be time for a new motor or a new unit.
Posted on Apr 06, 2015
Ba 203 won't start imobilelizer has come on can't get it off how had ute 1week ford say have to to tow to them and $140.0 to go on computer is there cheaper easy way please. tony f# fords
Hi Anthony......,It's either electrical OR fuel so If you're a hands on guy then do this.... Pull a spark plug lead off a spark plug OR if it's a "COIL ON A SPARK PLUG" pull that off and put a spare spark plug into that spark plug lead OR coil, Then earth that spark plug to a clean part of the motor(make sure the spark plug is touching steel)Turn motor with the key and see if the spark plug sparks.... If it sparks then you have a fuel problem....... But if no spark then you have an electrical problem.... The links below are YouTube videos showing how to fix a car that doesn't start/cranks but doesn't start, Also there's videos down the right side of the links that may help as well...................
Fixing Car That Does Nothing When You Turn The Key
Fixing Car That Cranks But Doesn Start Up
Car Cranks But Will Not Start
May 04, 2016 | Ford Cars & Trucks
I have a 1985 30hp electric start outboard motor the solenoid pulls in and the starter motor engages but there is no spark at the plugs
Hi Neil, Straight away I'd test the coil. The link below is a youtube video on NO spark on an out board motor...Hope this helps.... CHEERS..
https://www.youtube.com/watch?v=FlAobp6COzg
Apr 01, 2016 | Boating
Hi there, i have placed new coils and spark plugs also got new air-flow meter sensor new battery and car does not crank over please help
Hi does the motor turn with key but doesn't start?, If so take a spark plug out and replace it back into the spark plug lead and earth it onto a steel part of the body(make sure it's touching something steel). Have somebody turn the key to see if your getting spark. If you have spark then you have a fuel blockage but if you don't have spark but have new coils and battery then it could be a loose wire in the coil harness meaning electrical......
You say car does not crank over, If you mean you turn the key and motor doesn't turn then it's electrical, so no spark OR motor doesn't turn you're better off getting an auto electrician but if you have spark it's fuel problem and you need a mechanic... Sorry and good luck......
Mar 12, 2016 | 2002 Mazda Tribute
Why wont my mower start
You need to pull the plug wire off the spark plug put another spark plug and put it in and hold it to the motor and crank it to see if you are getting spark. Some models you have to have the spark plug in the motor cause some have sensor that will not make spark because it doesn't sense compression. If you are getting spark then you are having a fuel issue.
Dec 20, 2014 | Kubota T1600H Mower tractor
Mariner 40 hp outboard
Faulty kill switch faulty ign switch,how old is motor,is it electric start,isit ayamaha mariner or mercury mariner,if Yamaha disconnect white wire from cdi
Dec 31, 2013 | Boating
Dewalt DW718 Sparks When cutting . just bought it
The people from Lowes were right.
There are two types of motor designs: Induction motors and brush-type motors.
All electric motors that have brushes make sparks where the brushes contact the rotating commutator. They also run less efficiently but they are a bit smaller than induction motors for equal power output. Brushed motors can also deliver greater power at initial startup.
Because the sparks in brushed motors create heat, the housing around the motors typically have ventilation slots for air to go through to keep the commutator cool. This means you are likely to see the sparks if you look in the right place.
Since it's more difficult to get an induction motor turning, they typically have a "start capacitor" mounted on the side of the motor to give an extra kick to get the stator turning. While induction motors use less power when running, the amperage they use at start-up is typically double the running amperage.
Sep 09, 2013 | Dewalt 12" Beveling Sliding Compound Miter...
Treadmill motor sparking
Any electrical motor has the same principle and the same maintenance(lube the bearings+replacing brusch, cleaning+replacing some old winding hot,etc)
Now you have two option a)go to some repair shop for repair electrical motor or 2) by a new ones .
See my personal TIPS for motor help
God bless yoy
Jan 22, 2013 | Horizon CT5.0 2.0 HP Digital Drive Motor...
WHY IS THE MOTOR PRODUCING SPARKS?
Sparks from where? Is it electrical like a loose wire or wire that has become bare? Is it fuel sparks? In any case sounds dangerous to people or electronics of the car at a min.
Jan 12, 2013 | Cars & Trucks
Motor brushes spark like crazy!
If you already replaced the brushes you could have a couple problems, the least is the armature commutator needs cleaned and the more expensive is that it needs replaced. This is a problem unless you want to tackle taking the motor partially apart. Let me know what route you want to take either a repair center or looking at the commutator.
Jan 14, 2009 | Bosch Electric Table Saws
Garden Logo
66 people viewed this question
Top Electric Garden Experts
Steve Oakes
dannydoesita
roeb
Are you an Electric Garden Expert? Answer questions, earn points and help others
