Question about RCA Televison & Video
What's the code to program to a RCA HDMI DVD player
SOURCE: DVD/CD player
If you are using the HDMI output, you must press the HDMI button on your remote control.
Posted on Jan 07, 2008
  • 3 Answers
SOURCE: programming comcast remote
try this...
I got the RCR612 remote to work with my DRC200N by using Memorex code 3318, see if that works, also try 3391 and 3314, I read a lot of people got those to work.
Posted on Sep 22, 2008
SOURCE: need code for rca dvd player
Use code 156.
Total Method: turn on dvd player
1) Press select and mute together and hold till top buttons light up.
2) Enter code 156, if it turns off press mute. If that turns it back on press select to lock in the code.
This worked for me.
Posted on Aug 29, 2009
SOURCE: sony dvd players codes on rca universal remote
unemployed and cant affoed to go to your site sorry will figure out another way.
Posted on Dec 04, 2009
SOURCE: Code to program my RCA Universal Remote to work my Jwin DVD Player
i need the remote code for a JD-VD5503
Posted on Dec 24, 2009
How do i connect Orion DVD Player to LG Television with out a remote control.
The best option would be the HDMI-to-HDMI connection between your player and your TV. But because you mentioned that your TV is an old model, probably it does not have an HDMI port, in which case you have to use the RCA A/V connection. I understand you do not have a remote control for your TV, but you do not program a TV channel to watch DVD movies; you just switch between your TV and the DVD player as your audio/video sources. Here is what you have to do: check on your TV box for a button labeled 'Source' or 'Input'. Press on the button and it will alternate between TV and DVD (assuming you do not have any other device hooked up to your TV).
Dec 17, 2014 | Orion BDP3959 Player
Get RCA DVD Player to work.
ok on dvd player u wann use hdmi cable direct to tv ok then select input hdmi on tv remote to see picture
Feb 02, 2008 | Thomson Lyra PDP2860 Digital Media Player
Isn't this just a simple hookup? What am I not doing?
You either need to change the input source. Currently the source is TV, depending on how you connected the DVD player to the TV, it should be composite (A/V), component video or HDMI. (S-video is also a possibility. Very few DVD players are connected on the RF (coax) input which might be channel 3 or 4 without having a converter between the DVD player and the TV.)
Look on your TV remote for a button marked Source or Input. You may also find this button on the TV. (On some TVs, this may also be accessed through the menus.)
How did you connect the TV and the DVD player? If your audio and video were connected via three RCA plugs (yellow, red, white) on each end, then use the composite video input. If you used cables with 3 RCA plugs for video (yellow, green, blue) and 2 for audio (red/white), then switch to the component input. If you used HDMI which carries audio and video in one cable (with rectangular ends), then use the HDMI input.
Some older TVs only have the Source/Input button on their original remote. Not all universal replacement remotes have this button, you may need a different remote. Those that do may require you to try additional codes for your TV manufacturer to enable the button. (The on./off buttons often will work with more of the codes for a brand.) The ones that can be programmed via a USB connection to a computer are most likely to support the function. Please add a comment with the type of TV for additional help with this.
I hope this helps.
Apr 21, 2012 | Sony Dvp-sr500h 1080p Upscaling Dvd Player
How to connect dvd to tv.
Good day!!!!
Please try this procedure on how to connect your DVD player to your TV..
Follow this instructions:
1. Check the back of your DVD player. It will have up to three different types of outlet connections enabling it to be linked to the TV. The most ideal is an HDMI connection, which is a thin rectangular outlet marked "HDMI." It provides the highest quality signal to your flat panel TV. If your DVD player doesn't have an HDMI outlet, you can also use a standard RCA outlet. This consists of three round cable jacks labeled with a color coding. The yellow jack is for the video signal while the red and white jacks are for audio signals. Some DVD players may have an S-video outlet as well. It will be a circular jack with a number of holes. While not as effective as the HDMI jack, it provides a clearer picture than the RCA cables.
  • 2. Look at the back of your flat panel TV for a series of "In" jacks corresponding to your DVD player. There may be a number of them under different labels (Input 1, Input 2, HDMI 1, HDMI 2 and Component Video are common). All of them work, however, and all can carry the DVD signal into your TV. Simply select an "In" jack that matches the DVD outlet you have selected and note the precise label.
  • 3. Connect the "In" jack from the TV to the corresponding outlet on the DVD player, using the proper cable (RCA, HDMI or S-Video).
  • 4. Turn on the TV and press the input button to select the jack connected to the DVD player. (The exact label for the input button will vary by model. Some will say "Input," while others will say "TV/Video" or "Signal.") A menu should pop up onscreen giving you a list of jacks in the rear of the set. Select the jack connected to the DVD player. The name of the player brand should appear on your screen.
  • 5. Place a DVD in the player and watch as normal.
  • I hope this procedure will be helpful...Thanks for using fixya..
    Aug 13, 2011 | Panasonic Televison & Video
    I have a universal remote and need the code for a magnavox dvd player to program the dvd player thank you
    To get the code please go to below website
    http://remotefinder.rca.com/default.aspx?site=rca
    Please
    Provide model of your remote
    device to be programmed (VCR,TV)
    Make name(toshiba,sony)
    Thanx
    Jul 28, 2010 | RCA RCU404 Remote Control
    How to connect dvd player to tv
    In order of best to worst quality, and depending on which connectors both have.
    1. Hdmi ( Video and Sound in one cable )
    2. RGB also known as color stream (Red,Blue, and Green RCA ) Sound Seperate ( Red and White RCA )
    3. Composite ( Yellow RCA ) Sound Seperate ( Red and White RCA ) sometimes mono (single sound RCA)
    4. COAX (cable) which most DVD players don't have.
    All RCA connections on devices should be center color coded And grouped by connection Video 1 Video 2 ect.
    Mar 16, 2010 | Philips Magnavox DVD Player MWD200F
    DVD/CD player
    Nov 13, 2007 | RCA DRC247N DVD Player
    I NEED REMOTE CODES FOR THIS DVD RCA DRC200N
    I finally found a code that works. Code 3144 worked. I am using the RCA universal remote control RCR412S and RCA DVD player DRC200N. The code 3144 is listed under Memorex in the code book that came with the remote control.
    Oct 17, 2007 | RCA DRC200N
    Televison & Video Logo
    Top RCA Televison & Video Experts
    matt martin
    matt martin
    Computer Repairing
    Computer Repairing
    Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
