MACHINE STOP USING COLD WATER ONLY USE HOT WATER I PRESS COLD WATER BUTTON BUT IGNORE IT USE ONLY HOT WATER THX
    Genius:
  • Washing Mach... Master
  • 1,585 Answers
Replace inlet valve
Posted on Apr 12, 2015
SOURCE: whirlpool washing machine...only uses hot water
Make sure the hoses are connected correctly to the water valve on the machine. The connections will be marked with an "H" and a "C".
Given they are correct, most current washing machines have and auto temp feature on the water fill. It allows even cold water settings to bring in some hot water to make sure the water temp is hot enough to efficiently disolve your laundry detergant. The preset temps are usually around 75* for cold, and 105* for warm. Hot water comes in at whatever temp your household water temp is.
Posted on Sep 12, 2009
active209
  • 14 Answers
SOURCE: my simpson encore 605 beeps when you press the
problem was caused by lever mechinism under lid ,which pushes down safety lever inside top box behind electronic control pad. when lid is closed. Adjusted to suit , now machine is working fine.
Posted on Nov 06, 2009
Testimonial: "very helpful, spot on !"
jmeredith
  • 417 Answers
SOURCE: My washing machine (dwd-wd32ws) only uses hot water to wash!
hi,
try and switch your hot and cold water hoses around the other way. it should start the cycle with hot and rinse cold.. If it still does it you may have to have it serviced..
jm
Posted on Nov 27, 2009
  • 2128 Answers
SOURCE: I can't set my Neptune washer temperature to cold
you need to call your parts store or the factory number in your book,give the model and serial number to them and order the console,the touch pad is damaged and they sell you the whole top console on the washer
Posted on Feb 20, 2010
FAV6800AWDIY
  • 526 Answers
SOURCE: hot water when cold is selected
""Selectedd cold / cold and machine fills with hot water.""
Is your machine a FAV6800A or FAV9800A? If it's one of those I Have specific info to troubleshoot in Service Mode.
We will go into Service mode and turn on the Hot and Cold water inlet valves from the console and make sure the correct water inlet valve opens and fills the machine...........Rich
and a p/n if you need to replace the water inlet valve assembly.
Posted on May 01, 2010
Hello, I have Lg fuzzy logic 7 5. I used to run it using cold water only. It stopped working using cold water only. Now only runs on hot water. Any ideas?
the cold water solenoid has a problem and not allowing the water through
you can swap the hoses at the taps and that means when you press hot water , you will get the cold water to enter the tub
Jun 10, 2017 | LG Washing Machines
I have no cold water hose so I put the hot water one on but the water isn't coming out how can I fix it
all washing machines require both hot and cold water lines . better get a plumber to assist you
Sep 23, 2016 | Washing Machines
Stop a whole litre of water going through each time i put a pod in.
The way to program the quantity of water is to press & hold the button you are programming until the amount of water you want is in the cup, then release it. Next time you make a cup with that same button with a single press this time it should cut off with that same amount in the cup. If that doesn't work then take it back, that is what a guarantee is for.
Jan 25, 2015 | Krups Coffee Makers & Espresso Machines
Washer only washes with hot water
consult your owner manual about you are unsure about if the machine is acting anormally
Some machines, is running hot water during cycles, other cold water during cycles.
God bless you
Jul 18, 2012 | Washing Machines
LG Washer stops when it gets to rinse cycle
Code flashing IE? The code means the machine is not getting enough rinse water. Remove the hoses from the back i=of the machine, pull out screens, cold water is blue tab inside connection on washer, hot water is red. Clean screens and insert them back into the appropriate connection. Use a stiff brush and water to clean. Reset the machine by disconnecting power, press start/pause button(blue button on right) for at least five seconds, reconnect power.
Oct 31, 2010 | LG WM2277H Front Load Washer
Hot & Cold Water connection - can I connect just to cold?
Yes it may take a little longer to process a cycle but yes all new machines are cold feed only now.
Jul 22, 2009 | Beko 24 in. D3731F Free-standing...
Does not allow for hot water
Check the hot valve screen. If clean you will have to verify there is voltage present at the valve when using hot cycle. If there is and the screen is clean then the valve is bad.
Eric
Jul 02, 2009 | Washing Machines
Tefal quick cup
Press the Hot and Cold button for 3 seconds,
The red indicator light will start to blink,
Release the hot and cold buttons and while the red is still blinking, press the and hold the hold water button, Once the desired amount of hot water is reached release the hot water button.
Now press and hold the hot and cold water buttons simultaneously for about 3 seconds.
The red light will stop blinking to the end of the programming.
NB the RED LIGHT WILL BLINK FOR THE DURATION OF THE PROGRAMMING.
Repeat the process for the cup quanity selector for the cold water.
------------------------------------The end -------------------------------------------
Feb 28, 2009 | Tefal Kitchen Appliances - Others
Maytag neptne fav 6800 aww does not fill wiht hot water. works fi
Hi Big Wags
I would remove both water hoses at the back of the washer and check the Hot & Cold inlet screens for a clog/restriction.
They look like this;
You can turn the individual valves on in service mode using the procedure on page 16 of the Service Manual.
To enter Service Mode; press and hold simultaneously the Enviro Plus and Spin Only keys for three seconds or until the control beeps and the display reads “00”.
Now go into board output test by pressing the Delicates key.
Now press the Normal button to open the Hot Water Valve you can press the Normal button again to turn off the valve or just press the Off button to end the process. Or just use the wash cycle to toggle the H/C water valves on. I like folks to become familiar with using Service Mode and the SM.
If the inlet screens are free of debris and you have good water pressure from your source valve then you may have to replace the valve assembly Here is a link to check for FAV6800AW PARTS Sears Parts Direct. Shout back If you have questions. Rich
Jan 02, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Washing Machines Logo
32 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
