Question about Tomtom GO 710 Car GPS Receiver
I get a picture of a robber with a swag bag with a cross over it then the device switches off what is this?
    President:
  • Tomtom Master
  • 489 Answers
It's just a reminder that you put your TomTom device away ... like out of sight ... so that thieves don't get an opportunity to break into your vehicle to steal your TomTom.
You may change the option (to not display this screen image when you shut off your TomTom) using the "Change Preference" menu.
Posted on May 06, 2015
2008 ford f-350 passenger air bag flashes 1-7 code than stays on when truck is started.What does the code mean and can the code be reset without tearing air bag out of truck?
If a SRS fault exists, the RCM sends a message to instrument cluster module to flash a coded sequence which is called a lamp flash code (LFC) on the air bag warning indicator. Each LFC is flashed 3 times after which the air bag indictor will remain lit for the remainder of the key-on cycle. In addition to the self-test at start up, the RCM continuously monitors all of its external and internal circuitry for faults.
While the LFCs are an indication of a general concern in the supplemental restraint system (SRS), the DTCs are more specific. The DTCs can be retrieved from the RCM with a scan tool via the DLC.
DTC a c LFC b Description Action To Take - Continuous Lamp The Air Bag Warning Indicator is Illuminated Continuously (RCM Disconnected or Inoperative, Loss of Battery Feed or Loss of Signal Ground) Go To Pinpoint Test A . B1048 c - Passenger Side Air Bag Cross Link to Another Firing Loop Go To Pinpoint Test B . B1049 c - Passenger Seatbelt Pretensioner Cross Link to Another Firing Loop Go To Pinpoint Test C . B1054 c - Driver Seatbelt Pretensioner Cross Link to Another Firing Loop Go To Pinpoint Test D . B1057 c - Driver Air Bag Cross Link to Another Firing Loop Go To Pinpoint Test E . B1231 13 RCM Crash Data Memory Full INSTALL a new RCM and CARRY OUT programmable module installation (PMI). REFER to Restraints Control Module (RCM) and Inspection and Repair After a Supplemental Restraint System (SRS) Deployment in this section. B1317 Continuous Lamp Battery Voltage High REFER to Section 414-00 . B1318 Continuous Lamp Battery Voltage Low REFER to Section 414-00 . B1342 24 RCM is Faulted INSTALL a new RCM and CARRY OUT programmable module installation (PMI). REFER to Restraints Control Module (RCM) in this section. B1871 25 Passenger Air Bag Deactivate Module Fault Go To Pinpoint Test F . B1884 27 Passenger Air Bag Deactivation (PAD) Warning Lamp Circuit Failure Go To Pinpoint Test G . B1890 27 Passenger Air Bag Deactivation (PAD) Warning Lamp Short to Battery Go To Pinpoint Test H . B2292 33 Restraint System - Seat Belt Pretensioner Fault (Driver Pretensioner Circuit Fault) Go To Pinpoint Test I . B2292 34 Restraint System - Seat Belt Pretensioner Fault (Passenger Pretensioner Circuit Fault) Go To Pinpoint Test I . B2293 19 Restraint System - Air Bag Fault (Driver Front Air Bag Circuit Fault) Go To Pinpoint Test J . B2293 21 Restraint System - Air Bag Fault (Passenger Front Air Bag Circuit Fault) Go To Pinpoint Test J . B2296 42 Restraint System - Impact Sensor Fault Go To Pinpoint Test K . B2434 53 Driver Seat Belt Buckle Switch Circuit Short to Ground Go To Pinpoint Test L . B2435 53 Driver Seat Belt Buckle Switch Resistance out of Range Go To Pinpoint Test M . B2477 54 Module Configuration Failure This DTC indicates programmable module installation (PMI) has not been done to a newly installed module. CARRY OUT PMI. REFER to Section 418-01 . CLEAR the DTC. CARRY OUT the self-test. B2607 57 Harness/Configuration Mismatch This DTC indicates the RCM is configured incorrectly. CARRY OUT programmable module installation (PMI). REFER to Section 418-01 . CLEAR the DTC. CARRY OUT the self-test. If DTC is retrieved a second time, INSTALL a new RCM and CARRY OUT PMI. REFER to Restraints Control Module (RCM) in this section. B2691 53 Seat Belt Buckle Switch Circuit Fault, Front Driver's Side Go To Pinpoint Test N . C1414 29 Incorrect Module Design Level VERIFY RCM part number is correct for vehicle.
CARRY OUT programmable module installation (PMI). REFER to Section 418-01 . CLEAR the DTC. CARRY OUT the self-test. If DTC is retrieved a second time, INSTALL a new RCM and CARRY OUT PMI. REFER to Restraints Control Module (RCM) in this section. U0100 14 Lost Communication With ECM/PCM REFER to Section 418-00 to diagnose the communication concern. U2023 14 Fault Received From External Node REFER to Section 418-00 to diagnose the communication concern. U2050 14 No Application Present This DTC indicates programmable module installation (PMI) has failed. CARRY OUT PMI. REFER to Section 418-01 . CLEAR the DTC. CARRY OUT the self-test. If DTC is retrieved a second time, INSTALL a new RCM and CARRY OUT PMI. REFER to Restraints Control Module (RCM) in this section. a DTC: Diagnostic trouble code, retrieved using scan tool.
c Cross-link DTCs will be retrieved in pairs to identify the cross-linked components.
b LFC: Lamp fault code, flashed on air bag warning indicator.
Apr 18, 2017 | Ford Cars & Trucks
What pin do you cross to reset the air bag light
Do not try and cross any wiring as you can deploy your air bags.
You need to have a scan tool that will read air bag codes and make necessary repairs.
May 15, 2015 | 1996 BMW Z3 Roadster
Morning, I have a problem connecting my son's SWAG tablet to our Wi-Fi. It was working perfectly but for the past 2 days have been unable to "switch on" the Wi-Fi on his tablet. Please would you be able...
Greetings
First is any other devices connected wireless to your router?
If not try resetting your internet connection.. then do you see any other wireless devices in the tablet? IE other neibors or such ?
If so try re entering the password again..also make sure the AIRPLANE mode isnt on. If this doesnt work you might need to do a reset on this tablet.
Let me know if this doesnt work..there might be other fixes.
Chadman
Feb 24, 2015 | Tablets & eReaders
Can't get the back up light to burn, the fuse & bulbs aare good so it must be the switch, Where is it located???
Might want to verify the switch operation by checking the 7 pin trailer tow adapter for the reverse circuit. This is a standard 7 pin RV type plug
The "reverse switch" is called the DTR ( Digital Transmission Range ) Sensor, and it is mounted on the side of the transmission. This also contains the contact for only starting the truck in park or neutral, so if that works correctly, I would take a SWAG that the reverse section of it is OK ( but that is a SWAG ).
You can check the 7 pin, if that reverse works, the DTR is fine and the issue could be at the rear of the truck with the splice ( which the trailer tow adapter also goes through ).
You need to drop the spare tire to get to the connector, it is a large multi pin connector, reverse is the Black w/ pink stripe wire.
Feb 17, 2011 | 2004 Ford F150
Have a 2003 BMW i want to change the steering wheel, has air bag. I want to make sure i dont set off the air bag, 1st thing i did is desconect the battery. then?
Carefully remove the cloumn housin, there are two wires which actually go up into the steering wheel if so disconnect them, if it has stereo controls etc on the the wheel, there is a plastic pushfit connector. Disconnect it. Behind the wheel the should be 4 bolts, undo the bolts and carefully, with a soft robber hammer, tap the wheel off the spline.
Jul 16, 2009 | 2003 BMW 325
Picture has a swag at top and bottom of picture
hello it sound like convergance trouble can you access the menu and try and adjust the picture if that don't work it could be the convergance chips
shaun
Apr 08, 2009 | RCA Televison & Video
Wireless ceiling fan
there are remote controlled fan out on the market.
there are also devices the make it remote, but the cord is for power so i dont think you can hide the wires to much without going thru the ceiling.
if you have no access of the cieling then the wire must be there for powering of the fan run along the wall, try stapling the wire to the cieling like around the egdes of the ceiling then perhap painting the wire the same color of the ceiling.
you do not have much option to work with.
you have to make sure you buy the right remote controll
but it still need power.
http://www.csnceilingfans.com/Ceiling-Fan-Remote-Controls-C14870.html
there a site for remote controls for fan or just buy a new fan all together. im sure they put the plug there for a reason because if you use the fan alot they do go bad.
Good luck
I’m happy to help further over the phone at https://www.6ya.com/expert/david_92c86cbc79e9b552
Aug 16, 2008 | Dryers
Air Bags 1995 Jeep Cherokee Sport
You should be okay... dont cross any wires...
Jul 30, 2008 | 1995 Jeep Cherokee
Red Convergence on JVC AV- 65WP74
convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Jan 28, 2008 | JVC AV-65WP74 Rear Projection Television
Tomtom GO 710 Car GPS Receiver Logo
89 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
