Question about HTC Explorer A310E
Hanging while pick up or doing calls
It automatically stops n getting off
  • 3 Answers
Check the call-waiting service settings.
Posted on Apr 06, 2015
Phones keep hanging up on peopleand then says updating the phone rings back immediatly what do we do to fix this
Possible bug? Phone auto-dialing new call after hanging up with ...
forums.androidcentral.com > ... > Android 4.4 KitKat
Mar 17, 2014 - 25 posts - ‎19 authors
stop lying to your customers .... Then my wife picked up the phone to call another person and we ... It seems to happen every once in a while right after hanging up with ... Again, both KitKat based phones but very different manufactures. ... I'm having a very similar problem since updating my Samsung GS4 ...Missing: rca ‎peopleand
Phone Spam: Our Records Show You Have Not Updated ...
https://www.seroundtable.com/google-busines...
Search Engine RoundtableJan 3, 2014 - It then asks you to press 1 to update the listing and 2 to exit. ... Previous story: Google: Can't Crawl Your Robots.txt Then We Stop Crawling Your Site ... even thought the messages says FREE. or they just laugh and hung up the phone .... jump on GOOGLE on their phones to answer questions of find things!
Jan 12, 2016 | RCA 25420 DECT 6.0 Cordless 4-Line Phone...
How do i call
Hello Tedelen,
Be sure to meet all the requirements of the phone to make calls and to be fully operational. These requirements can be found here (Requires Adobe Acrobat Reader).
To make a phone call follow these instructions:
Making calls with the Handset
1. Pick up the handset and the phone automatically selects the priority line. If the priority line is occupied, it selects an open line.
OR
Pick up the handset and press a LINE button to select a line.
2. Wait for a dial tone, then dial a phone number.
3. Hang up the handset when finished.
Making Calls with the Speakerphone
1. Press the SPEAKER button and the phone automatically selects the priority line. If the priority line is occupied, it selects an open line.
OR
Press a LINE button to select a line.
2. Wait for a dial tone then dial a phone number.
3. Press SPEAKER button when finished.
If you are having problems refer to the given link to the User Guide.
-bsalamakha
Jul 05, 2011 | RCA 25415RE3 Phone
How to receive a fax
  1. Connect the multi-function printer to a phone line. Most printers with fax capability have more than one phone jack, so make sure you are plugged into the right one.
  2. Turn the printer on and access the start-up menu. Pick an answering mode based on your expected usage of the fax capabilities of your machine (see the next steps for more information about this).
  3. Put the printer in manual mode if you expect little fax traffic. The manual mode usually requires you to pick up every call that comes to the machine. If you hear the signal for a fax, you push the start button and hang up.
  4. Choose the automatic mode if you expect a lot of faxes or have a dedicated fax line. In automatic mode, the printer listens to incoming calls and determines whether they are faxes or voice calls. Voice calls get sent on to your phone, and faxes are picked up by the printer.
  5. Select the number of rings you want your multi-function printer to give you before dropping a call. If you are using the manual mode you may want to go with four or more rings. Two rings should be sufficient in the automatic mode.
  6. Load paper into the paper tray. Check on the paper level frequently if you receive a lot of faxes.
  7. Set the desired print quality, and you are ready to receive faxes.
Mar 01, 2011 | Samsung SCX 4521F All-In-One Laser Printer
How do I program the phone to ring on an incoming call? The ringer is on.
The solution will depend on why the phone is not ringing. Do you have a good cable? (Can you get a dial tone and make outgoing phone calls?) If you don't have a dial tone, use another phone to check if the phone is the problem or if the jack is at fault.
Next is the phone forwarding calls or in the "do not disturb" mode.
If the problem is one of the above, which model of the Main Unit do you have, KX-TA624 or KX-TA1232?
If the unit is in the "do not disturb" mode, to cancel: pick up the handset, press Program then 0 followed by # with the TA624. For the other model, press Program followed by 0 . Then hang up the handset. For this the manual says press the FWD/DND button not the Program button. I'd check both.
To cancel Forwarding, except for Follow Me Forwarding, pick up the handset, press FWD/DND and then 0 and # (TA624) or 0 (TA1232) then hang up the handset. To cancel Follow Me Forwarding: pick up the handset, press FWD/DND then 8 followed by the extension number. Then press # for the TA624 and hang up; just hang up the handset for the TA-1232.
I hope this helps.
Sep 23, 2010 | Panasonic KX-T7730 Corded Phone
How to receive fax
Instructions Things You'll Need:
  • Phone line
  • Multi-function printer
  1. Step 1 Connect the multi-function printer to a phone line. Most printers with fax capability have more than one phone jack, so make sure you are plugged into the right one.
  2. Step 2 Turn the printer on and access the start-up menu. Pick an answering mode based on your expected usage of the fax capabilities of your machine (see the next steps for more information about this).
  3. Step 3 Put the printer in manual mode if you expect little fax traffic. The manual mode usually requires you to pick up every call that comes to the machine. If you hear the signal for a fax, you push the start button and hang up.
  4. Step 4 Choose the automatic mode if you expect a lot of faxes or have a dedicated fax line. In automatic mode, the printer listens to incoming calls and determines whether they are faxes or voice calls. Voice calls get sent on to your phone, and faxes are picked up by the printer.
  5. Step 5 Select the number of rings you want your multi-function printer to give you before dropping a call. If you are using the manual mode you may want to go with four or more rings. Two rings should be sufficient in the automatic mode.
  6. Step 6 Load paper into the paper tray. Check on the paper level frequently if you receive a lot of faxes.
  7. Step 7 Set the desired print quality, and you are ready to receive faxes.
You should be all set now to receive faxes.
Aug 06, 2010 | HP Officejet 4355 All-In-One InkJet...
How do i transfer a call with my norte t7316e
There are 3 Flexible Feature buttons under the horizontal display. When you are on a call, the display will show "Transfer" over the last button. Press that button, which will automatically put the caller on hold, pick up an intercom and prompt you to enter the extension to transfer the caller to. Enter the ext. number and tell your employee who is on the call, and heng up - the caller will be connected automatically. Or, after dialing the ext. to transfer the caller to, just hang up and the call will ring through. Good Luck!
May 05, 2010 | Nortel T7316E 2-Line Corded Phone
How do you remove a recorded answering machine message
Settings:
In Settings dialog you can set the following options for Best Answering Machine:
* Greetings - allows setting up the greetings played on pick-up;
* Active in profiles - defines in which profiles the application will pick-up the phone and record messages;
* Storage - allows selecting on which disk the records will be saved;
* Pick up after - sets the time after which the call will be answered;
* Record time - maximum amount of time the message is being recorded;
* Format - message file format (amr,wav);
* Icon - configures the visibility of the icon displaying application activity and presence of new messages; depending on this parameter, can be shown in standby screen only (Phone application) or in any application;
* Play volume - play volume for the greeting;
* Records lifetime - automatically removes old messages;
In this view you can listen to new and old messages, delete unnecessary messages, send the recorded messages and call the person directly from this view.
During the call:
When Answering Machine is processing an incoming call, you will see a dialog showing the application's progress with the ability to stop it:
* Answer - when this command is chosen during a call, it stops greeting playback or message record and you can continue talking to the caller;
* Hang up - stops greeting playback or message recording and terminates the call; hope this will be helpful...
Jun 23, 2009 | Nokia Cell Phones
How to configure call forwarding on RCA RCA Phone model 25425RE1-
CALL FORWARDING HAS TO BE DONE THRU THE PHONE COMPANY IF YOU HAVE CALL FORWARDING - AND I DO THIS IS WHAT I DO - I HAVE AT&T IN MEMPHIS TN PICK UP HAND SET AND HIT *72- YOU WILL GET A BEEP- DIAL THE PHONE # YOU WANT TO FORWARD THE PHONE TO - SOMEONE MUST BE AT THAT PHONE NUMBER TO ANSWER IT! ONCE THE LINE IS ANSWERED- THEY HANG UP AND THEN YOU HANG UP AND PHONE SHOULD BE TRANSFERED- I ALWAYS TEST IT TO UN- TRANSFER IT PICK UP PHONE AND HIT 73# AND IT WILL BEEP 2 TIMES- NOW PHONE IS NOT TRANSFERED ANY MORE
Jan 16, 2009 | RCA 25425RE1 Phone
Pick up and hang up
answering a call on a meridian phone can be determined in software by giving priority to the line that is ringing rather than the one that is configured on the first key key 0.you can have several lines on the phone and in this way when you lift off, the line that is ringing is the one that is answered automatically rather than having to press the actual key itself.so unless you are familiar with the s/w overlays it will be hard for you to change your current setup yourself
Dec 10, 2008 | Nortel Norstar 16-Line PBX Speakerphone
Speaker picks up automatically
callers maybe calling you and than pressing 1 to voice call you. Dialing your extensions than 1.
Pick up the handset before pressing speaker.
Mar 12, 2008 | NEC Electra Elite 32D-1 Corded Phone
HTC Explorer A310E Logo
29 people viewed this question
Top HTC Cell Phones Experts
Ashutosh Khandelwal
Level 1 Expert
Charles Blake
Charles Blake
Level 1 Expert
D. E. Hev
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
