Question about Microwave Ovens
The cover of the oven light has broken off as I was cleaning. Can I use the oven without this?
    Top Expert:
  • Microwave Ovens Master
  • 45,346 Answers
If radiation does not scare you .google make/model/parts see if a new one is even available
Posted on Apr 06, 2015
Sharp carousel microwave
Sometimes, bits of food get behind the microwave generator mica cover and cause this EXACT problem they short out the microwave energy and spark. . It is NOT broken but DONT let this happen for more than a few seconds. !!!! You will see the Mica (looks like plastic) cover from inside the oven and will be on one of the sides.It looks oblong normally, It is actually transparent to Microwaves and is how they get from the generator in to the oven. Give it a real good clean around the edges or better still take it out to clean. and it should be fine
Aug 25, 2014 | Sharp Carousel R530EST Microwave Oven
My oven turns on and seems to work (i.e, the light comes on and the table turns round), but the microwave is not heating up. What is the fault. ps the conventional oven parto of this microwave still...
HI..there is a heating filament of an oven..it s responsible of producing heat to the oven..this filament must be replaced by a new one..theres no problem with the motor cos it runs the table power and light button seems working..
Jul 07, 2011 | Bosch HLK4555GB Convection / Microwave...
Sparkscome from food (no metal involved) and heating VERY quickly!
Arcing in or above oven chamberThere is often a simple cause:
  • Arcing in the oven chamber with a normal load (a cup of water, for example), often just indicates that a thorough cleaning of the oven chamber is needed, particularly around and inside/above the waveguide cover. Any food that gets trapped here will eventually burn and carbonize resulting in a focal point for further arcing. Usually, the waveguide cover is designed to be removable without taking the (cabinet) cover off of the oven. However, burnt food and carbon often make this difficult so that some disassembly will be required. See the sections: "SAFETY" and "Getting inside a microwave oven".
for more information see "Arcing in or above oven chamber" section of online Microwave Repair Manual.
If the microwave is clean, please post a reply and I will look at it again (this time include a model # and/or approx manufacture date)
Oct 21, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave oven part fallen off.
There are nylon push-in fasteners that snap into place. If there is a shop that works on microwaves, they will generally have them. Over time these fasteners get brittle and crumble away. Another option is to use nylon screws, if you can find some the right size. I don't recommend metal screws as they may arc in the cooking cavity. Using the microwave without the cover will result in spattered food getting into areas that can't be cleaned.
Feb 23, 2010 | Microwave Ovens
Arcing while cooking.
Make sure the inside of the oven is clean and the waveguide cover on the right wall of the oven is especially clean and not damaged. Don't ever run the oven without food in it. If the waveguide cover is damaged it will arc no what but you can probably get a replacement for a few bucks. The magnetron may already be so damaged that it'll never work right again.
Oct 19, 2009 | Daewoo KOC-925T Microwave Oven
Deep Cleaning techniques for GE spacemaker Convection microwave
Try simple green. It is great at eating through grease. It may take a few times but it works. It is biodegardable. I used it at one of my old jobs for cleaning grease off of glass and use it in my home as well.
Apr 19, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Smoke Coming from inside of Microwave even when warming for 10 seconds
Proberly wave guide cover at side it can get grease behind it,And when you used it with small load it tried to cook it and then burned the mica cover,Take mica cover off and try it without it to seeif problem resolved if ok,New cover can be obtained if req.Regards grandadfixer
Oct 10, 2008 | Thermador MBBS Microwave Oven
BROKEN GLASS COVER UNDER NIGHT LIGHT
SAME PROBLEM FOR ME...I REMOVED THE BOTTOM COVER AND FOUND THAT ONE LIGHT WAS NOT FIXED AND WAS LOOSE AND WAS TOUCHING THE GLASS. THIS HEAT WAS WHAT BROKE THE GLASS COVER. CLOSED INSPECTION SHOWED THE LIGHT SOCKET WAS TOO LARGE FOR THE CLIPS AND WERE NOT SECURED WHEN PURCHASED. I GOT SMALL SCREW AND NUT, BENT CLIPS SO THE SOCKET HOLE MATCHED THE HOLE MADE BY THE CLIP AND SECURELY ATTACHED THE SOCKET. THIS WILL SECURE THE LIGHT AND KEEP IT FROM TOUCHING THE GLASS..........IF I CAN EVER FIND A GLASS REPLACEMENT....MAY JUST HAVE ONE CUT. NOW THE PROBLEM IS TO REPLACE THE LIGHT AND MICROWAVE FUSE WHICH WAS BLOWN WHEN THE GLASS BROKE.
May 21, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
I have a new Advantium Oven, and while I had guest here, someone heated a tomato based food in the microwave without covering the dish. Food particles have popped into the steel webbed covered light...
If a plastic scrubber won't clean it, then when it's dry, you may be able to place duct tape or packing tape over it, press and rub it firmly, and remove the tape. It may remove much of the debris.
A can of compressed air (in the computer section of Wal-Mart, for example) may blast out the bits.
If it resists all efforts, it may be necessary to take to the outer cover off, peel off the plastic light cover sheet, do the cleaning, then install a new light cover sheet.
We're happy to help and we appreciate your thoughtful rating of our answer.
May 12, 2008 | GE Microwave Ovens
Broken door hook
The plastic cover on the inside of the door is purely push fit.
To force it off I used 2 strong stainless steel dinner knives.
By easing one knife between the internal glass and the plastic cover I managed to spring one corner by using the other knife on the external bottom edge of the plastic cover.
Try concentrating on one end and once this springs out it is easy to free the rest without having to take it off completely.
The hook is simple to do but be careful with the spring.
All in all it took 3 minutes!
Jan 13, 2008 | Neff B7740N0GB Microwave Oven
Microwave Ovens Logo
43 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
