Question about Dishwashers
LOCATION OF HEATER
ELEMENT NOT WORKING ERROR HE
    Top Expert:
  • Dishwashers Master
  • 45,382 Answers
Usually in the bottom
Posted on Apr 06, 2015
I HAVE ERROR 189 ( TIME TOO LONG FOR HEAT UP BOILER ), CAN YOU HELP ME PLEASE ?
Sounds as though the boiler has lost the supply to the heating element, or the supply is low.. Check that the thermal fuse in series with the boiler heater is not open circuit (there may be more than one in series). If it is OK, check for continuity across the heater inputs - if that measures open circuit or very high resistance, the heater has failed.
Otherwise just backtrack along the wiring harness looking for the power supply to the boiler, there will be at least one relay (contactor) and switch. Make sure all are working correctly. You should be easily enough able to locate where the supply to the boiler's heating element is getting lost :o)
Nov 06, 2013 | WMF Coffee Makers & Espresso Machines
Location of the heater element relay
hi the heater relay is located on the module board you may have to take it out and check circuit for dry joints somtimes commen problem but also check your heater ellement for continuity or open circuit there is allso a heater cut out to check check the heater and then the cut out first
Nov 06, 2011 | Hotpoint Washing Machines
I would like to get a manual/guidefor dishwasher DW009H from B&Q . Drying does not seem to be very thorough at the end of the cycle. Also the code E3 is showing when finished.
E3 Error Code
Cause: The water heater element does not work properly or the filter mesh is blocked.
Remedy: Clean the filter mesh and if the problem continues please contact service
As far as a manual is concerned, I believe Hobart manufacturers your model and not B&Q. B&Q just sells the unit. You may want to locate a Hobart dealer in your location to try to get the manual. You will probably need one to fix the heater element any how.
Jun 05, 2011 | Dishwashers
Cotton wash e8 error comes up
Error F08 means that the heater relay cannot be activated. Check connections on:
- pressure switch.
- heater element.
- control module.
The heating element is gone open circuit. Replace element. If you still cannot get it to work, then you are probably going to have to call an technician service.
Hope this helps.
May 30, 2011 | Baumatic Washing Machines
Dishwasher isn't drying probably coming up with error three. Can't locate a solution to this. Can anyone help?
I would say a 3 fault is a heater element fault so you water is not getting hot atall. The heater is located in the base which you can gain access to from the front bottom of the appliance but be very careful the base plate is very sharp and will cut you, cover it with a towel for safety. The element is a little tricky to change but not impossible if you have some diy skills. Make sure you tighten the clamps that hold the element to the spray motor as it will leak and then give you an f2 fault. I think the elements are about £40 quid if you do it yourelf.
Hope this helps
Nov 06, 2010 | Dishwashers
Error message e64
Hi
Error code E64 means Heater Open Circuit. This error appears when the Heating element or wiring to the heating element is defective. To clear the error code (s): Press and hold the far left key under the display and
Sep 07, 2010 | Electrolux EIED55H Dryer
I have a front load LG washing machine. Its two years old and it stopped working today and it is giving a code of TE on the read out. what does this mean? Any help would be greatly appreciated!
TE is a Thermistor error.
This can be a shorted Thermistor and or a bad heater element. These items are located at the front bottom of the washer's tub.
If you have a washer with steam function. It could also be the steam generator's thermistor and or a bad heater element. The steam generator is located just behind the dispenser’s housing on the top left side.
I can get you part numbers is you need them.
Mar 14, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Error code f-08 on indesit wixe127 washer
Error code F08 means that the heaterrrelay cannot be activated.
Check the connections to the Pressure switch, the Module,and the Heater element.
If you can, test the element of the heater to make sure it is o/k.
Hope this helps.
Dec 02, 2009 | Indesit W 123 Front Load Washer
WF000G Board
i have the same prob i know where they go on the heater element but where do they go on the pcb
Aug 26, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Dishwashers Logo
46 people viewed this question
Top Dishwashers Experts
