Question about Dishwashers
Bottom rack spokes broken, and utensil basket broken. Where do I get replacement part
    Top Expert:
  • Dishwashers Master
  • 47,720 Answers
Perhaps through the dealer that sells that make /model
Posted on Apr 06, 2015
My Maytag stainless steel dishwasher utensil basket has 2 holes in it. I would like to buy a new one. Can you help me ?
Try either SearsPartsDirect.com or RepairClinic.com. Provide them with your dishwasher model number. Once you get the part number for the utensil basket, then you can go to eBay and usually find one cheaper!
Feb 15, 2015 | Maytag Dishwashers
Wy is top rack not washing
top rack is for small plates & cups not pots & pans as they may obstruct the rotating of the sprayer & foul the water from getting to all the items
Aug 31, 2014 | Bosch Dishwashers
We have got the machine for approximately 2 years and the top dish rack has corroded so badly that I think it might collapse with a load on it. What could be the cause of it?
The causes are usually poorly coated rack combined with rough usage (coating pierced
by cutlery, broken stemware, etc., combined with hard (mineral-laden) water, which
corrodes the steel of the rack quickly.
Luckily, the upper rack is replaceable, so check:
http://www.buyspares.co.uk/dishwasher/ld12bw5/basket/catalogue.pl?shop=lg&path=111329&model_ref=49220&refine=basket
Jun 09, 2011 | LG 24 in. LD-12BW5 Free-standing...
Need an new bottom rack
Welcome to FixYa.
The lower rack for your Viking dishwasher ( made by Asko ) has been revised and now comes with a new utensil basket as well.
The original number is 80 584 90-36 but now substitutes to number is #1486550 and available at "repairclinic.com" for approx. $170US dollars.
That will include what is shown here...
and this...
Hope you found this helpful and I indeed answered your question. Let me know if you require further assistance.
Thank you for choosing FixYa and good luck going forward.
Regards,
Macmarkus :)
Oct 19, 2010 | Viking 24 in. Professional Series VUD141...
Need replacement rack.
https://www.geapplianceparts.com/GEApplianceParts/Dispatcher?REQUEST=HOMEPAGE
May 02, 2010 | GE Nautilus 24" Built-in Dishwasher
Top rack is not level. Glasses and cups roll forward
I assume that the bottom rack is level and the upper rack is not.
On the LG dishwashers, you can remove the upper rack by removing the little gray clip at the front of the rails. Each will fall off in your hands. You can then pull the basket out.
Place it on the floor and confirm that all wheels roll properly and all touch evenly. Resolve any problems on the rack via LG service parts.
Inspect the rails still inside the dishwasher, confirm that they are paralel and level.
Replace the upper basket carefully, making sure the wheels all slide into the rail evenly.
Please update me on what was done to finally resolve the problem.
Oct 12, 2008 | LG 24 in. LDF 7811 Stainless Steel...
Basket for utensils
There are a number of parts houses on the web which will gladly sell you the item you need, depending on your location. Repairclinic in the US has these items. Bosch probably sells them direct.
Jul 18, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
I have the same problem with dirty dishes on the top shelf and the utensil baskets
Dump the Kenmore on the seller's doorstep - when the place is full of customers!!
Dec 27, 2007 | Kenmore 24 in. 16264 Built-in Dishwasher
Poor washing
before you suspect the pump and motor assy, do you hang the silverware basket on the front side of the lower rack or if not did one of the holders for the rack fall off and you replaced it? I have found that id the basket is hung on the rack that tall utensils will hold the door from opening fully. when that happens water from the spray arm will not hit the soap dish and when you open the door you will see soap in it. also there is a plastic peice on the top rack if not installed the correct way it wil hold the dispensor door closed causing the soap to stay. I see this problem all the time. when in the wash cycle do you hear the water spraying around inside? If you do I would not suspect the pump and motor. And with whirlpool the pump and motor is a full assembly and it is disconected from the under side of the washer and removed from the top. also run it empty on a short wash cycle and listen for the dispensor door to pop open. make sure thats working properly to. check all that out and let me know if it helped. good luck
Aug 05, 2007 | Whirlpool 24 in. GU1500XT - Multiple Color...
Dishwashers Logo
48 people viewed this question
Top Dishwashers Experts
