Question about Seiko Teriostar Lp1020 Printer / Copier / Scanner Color
When the printer is on, only intilizing & booting are only display, after few seconds there is no disply and no indicator lights
Hp pavilion modelp6510f press power switch on top of pc does not light computer fans blow but compute does not turn on
ok th p6000. complete range when they were made had to be recalled as they put the copper expansion pipes ran across the gpu & cpu hence a massive overheat problem. they put copper shims over the cpu & gpu but this worked for a short time but it was inevitable and both units ended up being cooked i had this problem with mine. so if you have tried external monitor with no images it would sound or more likely to be the gpu cooked sorry for the bad news.
Jan 28, 2014 | Computers & Internet
Nokia 114 display light problem
how 2 jumper 114 nokia lighting
Feb 05, 2013 | Cell Phones
"door is locked" displys for a few seconds, but it
There is likely to be a problem with either the door solenoid/lock or the 'door closed/locked' sensor requiring a service engineer's attention I suggest. Sorry ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Jun 16, 2011 | GE WBVH6240F Front Load Washer
Deskjet 3745 power light flashing green, wont print
Hello thanks for using fixya
You should try this solution:
Remove the power cable from the printer, Press power then wait a few seconds, then Press power again. Now plug in the power cable and try to turn the printer on, It will boot, If it does boot then it means the power supply is not exactly correct in printer. So you may need another power supply
I hope this solution will helpful 4 u
Please don't forget to click on Four thumbs which are given below & then write testimonial in your words for appreciation if it is helpful
THANKS & Keep Using fixya
Jan 23, 2011 | HP DeskJet 3650 InkJet Printer
I have hp deskjet 3744 and the Light flashes constantly please help me
Jan 22, 2011 | HP Deskjet 3845 InkJet Printer
Power is on to my Canon Pixma MP780, but no display
I got such problem on my MP 780 (grayed boxes on bottom LCD line, no function). It turned out to be missing 1.5V for CPU core. On revese (solder) side of mainboard i found point described as "1.5V". I've powered this from external supply (took about 2 amperes) for few seconds and MP is alive again (without external supply).
Jun 06, 2010 | Canon PIXMA MP780 All-In-One InkJet...
No display
The internal parts might have been damaged because it is located underneath the keyboard of your Notebook, better to have it checked by a certified technician near your place or if it's covered by a warranty have it replaced.
Dec 25, 2009 | HP Pavilion dv9830US Notebook
I have a zebronics mother board with intel 845 chip. Now whem i power on that it give long beep and no disply,RAM is ok, then what i can do?
Hi ieb_amit,
Typically a long single beep indicates that your display adapter or card is bad. If you haven't put in a new graphics card, then I might suggest doing so, to eliminate the beep.
Good Luck
mark
Dec 04, 2009 | Computers & Internet
Having display light but display is not working
The display circuit is broken even if the LCD-panel seems to be ok. the only circuit working in the display is the one for the backlight.
This is a very common Nokia display problem.
Only solution is to change the display.
You need a T-6 Torx skrewdriver to do the job.
You can find displays for fair prise at:
www.mytrendyphone.com
This is your solution! Please vote!
Jun 27, 2009 | Nokia 3120 Cellular Phone
Seiko Teriostar Lp1020 Printer / Copier / Scanner Color Logo
60 people viewed this question
Top Seiko Office Equipment & Supplies Experts
Oloyede Monsuru
Andrew Taylor
Andrew Taylor
Are you a Seiko Office Equipment and Supply Expert? Answer questions, earn points and help others
