Question about Ovens
Hi i have bought the part i need to replace, fan oven element but cant get old one off to put in new one. Any ideas of how i get it off
  • Ovens Master
  • 5,323 Answers
Usually just pulls out or has a couple tiny screws holding it in, some become so old and brittle and have residue build up hard to pull out?
Posted on Apr 22, 2015
Hi their i am replacing my old fan oven element. but when i pulled out the old element the wires fell down the back!!! any ideas on how to retreive them? thx
use a coat hanger as a hook to grab then but unplug the stove before you do it. You should be able to sang them without to much difficulty.
Apr 18, 2010 | Whirlpool GMC275PD Electric Double Oven
No heat on bottom oven. fan running but not heating up
Neff fan oven element video. 1, If the fan motor . in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter.
To gain access to the NEFF element .you will have to remove the back plate from inside the oven. Once removed you will see the fan and element,. if you look closely at the element .you will probably see a small hole burnt in it where it has blown. Sometimes however there is no evidence of a fault but the element is open circuit ie: broken inside the element casing, either way it will need replacing. Some elements will are fixed from inside the oven and some are held in place by nuts from the rear of the machine.
2, If your NEFF fan oven is getting warm but takes a very long time to cook or is burning the food more on one side than the other, then you need to check if your oven fan motor is working you will see the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven then you need To replace the oven fan motor is a little more expensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heating and burning everything then you will need to replace your NEFF oven thermostat
4, A quite common and easily overlooked answer is if your NEFF oven is not working at all ie: no heat and no fan then the chances are that someone has put the oven timer into AUTO mode, simply put oven back to MANUAL mode and all should be working again.
For all Free appliance repair videos visit our VIDEO TUTORIALS
Jul 19, 2009 | Neff U1421 Double circotherm Electric Oven
Problems with the fan on neff b1641 oven
Hi, from what you describing it can only be either the oven element (located behind the back plate inside the oven, hold by 6 screws, 2 at the top, 2 at the bottom and 2 on the sides). Switch off the cooker, remove this panel and have a look at the element, looking for unsual bends, corrosion, or burn marks. The other possibility is the safety stat located near the element connections at the back of the oven. Pull the oven out, remove the back chassis panel and inspect the stat.
Cheers
Feb 19, 2009 | Neff B1641 Single circotherm super...
Please help Fan not working in Neff U1451
Hi, the fan is one part and the bulb another. They are not connected. If the bulb isn't working simply unscrew the bulb lens and replace the bulb. About the fan motor, sometimes they cease up because the build up of grease at the back of the oven. You can try to remove the insid back plate that covers the element and fan, and try to rotate the fan manually. Try to clean it and test again. Last resource, it needs a new fan motor.
Cheers
Feb 08, 2009 | Neff U1721 Double circotherm Electric Oven
Hotpoint ew83p oven has no heat
The oven fan element has failed, you need to fit a new one.
Remove inner rear panel of oven and you will see the round element at rear.Unscew screw(s) that secure element, disconnect leads, and fit new element.
Refit element cover.
Job done..
Make sure you have power off to oven before you start.
Plz rate my solution.
Thanks.
Jan 12, 2009 | Neff B1641 Single circotherm super...
Hotpoint DY46
had the same problem with my Electrolux. Element blew and the fan stopped working and food was stone cold. I pulled the element out - had to remove the rear panel to get to the wires but the element came out from inside the oven by removing a few screws. Went off to the local Applaince store and bought a new element which was pretty dear as this model was made in NZ. Replaced the element put it all back together and away she went. If you do it yourself make sure you TURN OFF THE POWER at the power box. It is a good idea to have an electrical tester to make sure the element is the problem. These are usually not hard to repair and it is usually just a few screws to remove the rear cover and possibly a cover inside the oven to get the element out. A Handy Person will be able to do this job. Hope this helps.
Regards
Bryan
Jun 01, 2008 | Hotpoint DY46 Style Line Stainless Steel...
Duco4ss main oven not heating on fan setting
put test bulb on the two wires going to fan heating element,that will tell all,if bulb lights,its the fan element that needs to be replaced!good luck!!
Dec 17, 2007 | Ovens
Baumatic bt180 oven
assume a fan oven.does fan turn and oven light come on? if so problem is the circular element. if no fan and no oven light, then clock probably needs setting - this will be in instruction book. clocks sometimes go wrong but not often. if clock is faulty, a cheap repair is to bypass the clock so auto function no longer works
Apr 09, 2007 | Baumatic B180 Electric Single Oven
Ovens Logo
130 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
