Braemar Heater starts then stops. Screen shows reset and fault 13
Reset showing fault 13 What does this unit need?
SOURCE: When GPS is turned on unit locks up
I had losts of lock ups when flipping on the GPS - almost ready to get rid of the Garmin IQUE 3600 since it hasn't worked well for over a year. Sometimes it works a short time with the GPS; other times it was instant lock up when searching for satellites.
I took many steps to isolate the issue, and then added complexity to the equation: update to r6 (no change), hard reset, no user data on IQ3600 during testing, use only internal drive, only use basemap lite on internal drive, only use 1 local city on internal drive, load other maps on external card. Each time I went outside and flipped on the GPS to see if that was affecting the lock up.
Then I played with the GPS settings. The factor that seems to solve the issue: TURN OFF WAAS - it is intended to improve accuracy to 9 ft but it seems to have a bug.
Garmin
Ique 3600
Palm OS Release 5.2.1r6
GPS lock up crash bug
Posted on Feb 03, 2009
gripfitter
  • 557 Answers
SOURCE: U61 ERROR ON DISPLAY
U-61 is a hardware error code. Usually means main board failure, however have found that a bad changer can also trigger that code since it connects directly to the main board.
Posted on Sep 21, 2009
SOURCE: Whirlpool washing machine "clean pump" error light.
take top off machine. look down right side and you will see a disc about 50 mm in diameter, attached to this is a small flexible rubber pipe, take this off at the disc and blow through it,( you will need some type of pipe to connect to the rubber pipe).this worked for me with the very same problem.
Posted on Mar 13, 2010
SOURCE: braemar spectrolink comfort controller keeps on
sim lock
Posted on Apr 09, 2010
Look for the error code on the right hand side of the display above the zone section and below the actual temp displayed.... refer to:
http://www.braemar.com.au/PDFDocuments/Section8_ServiceTroubleshoot.pdf
Posted on Jul 22, 2010
You need to look on the legend on your furnace blower door for the meaning of this error code, it can only be a few things, since you say the unit lights up and runs but shuts down the high limit circuit is suspect, I would check the air filter and insure all supply vents are open, the limit may be bad however a cracked heat exchanger will also do this so a free inspection by your gas co will be a great idea once you get it running again.
Apr 06, 2015 | Heating & Cooling
Error code f-13
Do u want to resolve the f-13 fault code ON HOTPOINT WD860 Ultima and other models.
Fix the fault . It is a tricky job but the heater thermostat switch has tripped as it senses something burning. Probably a little bit of fluff on the heater element inside the heater unit.. There are 2 switches on top of this heater unit. One where the 2 blue wires go on the top left of the 3rd picture and the other which has a tall black wire connector on shown in the middle of the 3rd picture. Remove that connector and undo the holding screw . You can then reset the switch. The switch is a small circular switch hidden beneather the connector on the photos. This thermostat switch has a yellow. red dot ontop of it. If you use a small pin or needle and press into that dot you will hear it tick back into place. you have reset the switch now. You will probably need to clean the inside of the heater element unit to get rid of the fluff particles or it will keep switching off. To take this apart you will need a set of Star screwdrivers. Its a bit tricky but you will be able to undo the star screws and take them all out. I will add some photos to show you the unit apart. You can see the build up of fluff on the photos i have added from my hotpoint WD860 heater unit. This is a tricky job and takes about an hour due to the screw being awkward to take off and put on again but mine hasnt faulted for 2 years since sorting it out. You can buy a new Thermostat switch which is about 10 pounds sterling from Hotpoint or other spares stores. error-code-f-13-04t3bj0jgktmuqmnt3s3ejb0-2-0.jpg error-code-f-13-04t3bj0jgktmuqmnt3s3ejb0-2-2.jpg error-code-f-13-04t3bj0jgktmuqmnt3s3ejb0-2-5.jpg error-code-f-13-04t3bj0jgktmuqmnt3s3ejb0-2-9.jpg error-code-f-13-04t3bj0jgktmuqmnt3s3ejb0-2-14.jpg error-code-f-13-04t3bj0jgktmuqmnt3s3ejb0-2-20.jpg
Dec 07, 2014 | Hotpoint Ultima WF860 Front Load Washer
MY BRAEMAR th5X23E showing reset -05 heater is not working at all
Go to the outside unit and open the door that covers the electrical connections. There will be a reset button on one of the temp switches that needs to be pushed. Now you have to see why it needs a reset.
Mar 21, 2014 | Heating & Cooling
Hotpoint washer dryer wdf 740 showing error code F-13
F13 error code is a dryer NTC problem.
What you need to do is take off the top of the washer. From there you will see the dryer chamber on top. Towards the front of this is the NTC it will have 2 thin wires going to it.
Make sure the wires are on ok and not broken. If the wiring is fine then you will need a multimeter and test the NTC. It should give a reading in Kohms.
If the NTC is fine then its possible the control board at the back is the problem.
Oct 15, 2012 | Washing Machines
Braemar spectrolink reset error 05
I had the fault code 05 (spectrolink controller) recently on a Braemer TG420 ducted heater. The heater would start and cut out on high temp as the room fan was not starting. I checked under the house and found the cable fitted to the return air thermistor had been chewed. I repaired the section of cabling and restarted the unit and it worked fine. Fault Code 05 is to do with the Thermistor in the return air duct.
Mar 27, 2012 | Heating & Cooling
My hotpoint waher dryer edd960 keeps flashing f13 on cuts out drying half way through, what is the problem and can i fix it myself? if not how much it cost ish? thanks
Do u want to resolve the f-13 fault code ON HOTPOINT WD machines
Original pictures not showing. hotpoint-waher-dryer-edd960-brswrwcy453xu5qdcnkktuei-3-0.jpg hotpoint-waher-dryer-edd960-brswrwcy453xu5qdcnkktuei-3-2.jpg
Feb 09, 2011 | Dryers
Braemar spectrolink comfort controller keeps on asking to be reset works ok for a while then goes to reset
Jul 21, 2010 | Honeywell Programmable Thermostat Heater
Cannot reset remote for braemar Ecostar Ducted heatin. Need to reset time and day. Would like to reset programmes also however when i hit the set button as per instructions in little book provided the...
The Braemar heater I have is wired directly to the control unit. The only way to reset the time is to turn of the heater for 5 minutes - the remote display should clear, and turn it back on (takes a minute for remote to come back on) the time will be flashing - use the Up and Down arrows to set the time, and SET button to set the day of week.
Jul 18, 2010 | Heating & Cooling
Heating & Cooling Logo
172 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
