Heater starts then stops. Screen shows reset and fault 13
Reset showing fault 13 What does this unit need?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 83 Answers
You need to look on the legend on your furnace blower door for the meaning of this error code, it can only be a few things, since you say the unit lights up and runs but shuts down the high limit circuit is suspect, I would check the air filter and insure all supply vents are open, the limit may be bad however a cracked heat exchanger will also do this so a free inspection by your gas co will be a great idea once you get it running again.
Posted on Apr 07, 2015
Error code f-13
Do u want to resolve the f-13 fault code ON HOTPOINT WD860 Ultima and other models.
Fix the fault . It is a tricky job but the heater thermostat switch has tripped as it senses something burning. Probably a little bit of fluff on the heater element inside the heater unit.. There are 2 switches on top of this heater unit. One where the 2 blue wires go on the top left of the 3rd picture and the other which has a tall black wire connector on shown in the middle of the 3rd picture. Remove that connector and undo the holding screw . You can then reset the switch. The switch is a small circular switch hidden beneather the connector on the photos. This thermostat switch has a yellow. red dot ontop of it. If you use a small pin or needle and press into that dot you will hear it tick back into place. you have reset the switch now. You will probably need to clean the inside of the heater element unit to get rid of the fluff particles or it will keep switching off. To take this apart you will need a set of Star screwdrivers. Its a bit tricky but you will be able to undo the star screws and take them all out. I will add some photos to show you the unit apart. You can see the build up of fluff on the photos i have added from my hotpoint WD860 heater unit. This is a tricky job and takes about an hour due to the screw being awkward to take off and put on again but mine hasnt faulted for 2 years since sorting it out. You can buy a new Thermostat switch which is about 10 pounds sterling from Hotpoint or other spares stores. error-code-f-13-04t3bj0jgktmuqmnt3s3ejb0-2-0.jpg error-code-f-13-04t3bj0jgktmuqmnt3s3ejb0-2-2.jpg error-code-f-13-04t3bj0jgktmuqmnt3s3ejb0-2-5.jpg error-code-f-13-04t3bj0jgktmuqmnt3s3ejb0-2-9.jpg error-code-f-13-04t3bj0jgktmuqmnt3s3ejb0-2-14.jpg error-code-f-13-04t3bj0jgktmuqmnt3s3ejb0-2-20.jpg
Dec 07, 2014 | Hotpoint Ultima WF860 Front Load Washer
Whirlpool Cabrio washing machine stopped mid-cycle, setting off a beep. Code F on panel. Help
Aug 01, 2014 | Whirlpool WTW6400SW Cabrio Washer
Why is my dryer beeping and showing E60?
The last alarm code memorized can be displayed even if the appliance is in normal operating mode (e.g. while the drying programme is being performed): - Press (start/pause) and first option button simultaneously for at least 5 seconds: the display shows the last alarm.The alarm sequence continues to flash as long as the two buttons are held down.
The appliance continues the cycle while the alarm codes are being displayed. If the appliance is in programme selection mode, the options previously selected are stored in memory.
E60 is family fault code but after reading last alarm you will see exactly fault code (E61; E62; E63)
E61 - Insufficient heating (maximum time exceeded)
  • Heater unit faulty
  • Wiring faulty
  • NTC sensor incorrectly calibrated/out of position
  • Electronic board faulty
E62 - Power reley to heater unit faulty
  • Wiring faulty
E63 - Intervention of auto-reset thermostat on the heater unit
  • Thermostat faulty (replace heater unit)
  • Wiring faulty
Dado
May 10, 2014 | AEG T57800 Electric Dryer
Hotpoint washer dryer wdf 740 showing error code F-13
F13 error code is a dryer NTC problem.
What you need to do is take off the top of the washer. From there you will see the dryer chamber on top. Towards the front of this is the NTC it will have 2 thin wires going to it.
Make sure the wires are on ok and not broken. If the wiring is fine then you will need a multimeter and test the NTC. It should give a reading in Kohms.
If the NTC is fine then its possible the control board at the back is the problem.
Oct 15, 2012 | Washing Machines
My screen just went white and a black dot appeared with the message press dot what should i do
Try pressing the dot. If that does not work you can try resetting the unit which will return it to factory specs but all your saved information like favorites and routes will be lost. The reset button is on the bottom of the unit. Power the unit off then press and hold the reset till it starts and the choose yes on the screen to restore the unit.
I have attached a link to the manual which shows a photo of the location and page 13 describes the reset in more detail.
Thanks for using FixYa
http://www8.garmin.com/manuals/nuvi205W_QuickStartManual.pdf
May 18, 2011 | Garmin nuvi 205W GPS Receiver
My hotpoint waher dryer edd960 keeps flashing f13 on cuts out drying half way through, what is the problem and can i fix it myself? if not how much it cost ish? thanks
Do u want to resolve the f-13 fault code ON HOTPOINT WD machines
Original pictures not showing. hotpoint-waher-dryer-edd960-brswrwcy453xu5qdcnkktuei-3-0.jpg hotpoint-waher-dryer-edd960-brswrwcy453xu5qdcnkktuei-3-2.jpg
Feb 09, 2011 | Dryers
I have replaced the batteries on the controller, but cannot reset the temperature. The screen shows either -1 or -0. How do I reset it after replacing the batteries?
most of these units need to be synchronized so turn the power off to the entire unit and start as if it were the first time using it.
Feb 03, 2011 | Rinnai Digital Remote Water Heater Control...
F:13 COMES UP ON THE DISPLAY WHEN THE CYCLE FINISHES. YOU HAVE TO TURN OFF THE MACHINE WHEN IT F:13 IS DISPLAYED AND IT TAKES A WHILE FOR THE DISPLAY TO COME BACK IN THE MACHINE AGAIN.
f13 is a Dispenser circuit error
If the dispenser motor is not able to be driven to it's proper position.
Check mechanical linkage from dispenser motor to the top of the dispenser.
Check Wire Harness connections to the dispenser motor and Central Control Unit (CCU)
Check Dispenser Motor
Thanks for using FixYa!!
Jan 09, 2011 | Washing Machines
We have F-13 flashing. Can you please advise what
Error code F13 indicaters dryer fan or dryer thermistor faulty.
These are to be be found in the top of the washer on top of the heater manifold.
To access them remove top cover.
Please rate my solution.
Thankyou.
Jan 25, 2010 | Hotpoint Aquarius WD640 Front Load...
Heating & Cooling Logo
90 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
