Question about Fishman Aura Spectrum D.I.
Aura Spectrum Di spoiled, only works in tuner mode, any solution please?
It is the second Pedal who spoils me with the same problem, perhaps no one has been able to find fault? Appreciate one Solution
    Top Expert:
  • Fishman Master
  • 3,107 Answers
Contact the store tat sold it to you for an exchange. If them will not help you, contact the Customer Service department of the manufacturer to discuss a replacement under your warranty.
Posted on Apr 07, 2015
It´s defect, so you have to use your warranty.
It´s nonfixable.
I´m sorry.
Posted on Apr 06, 2015
Zoom g1x dc supply not working, my zoom g1x is working when battery operated but if i connect it to a adaptor there is no power, i've already checked my adaptor and it was properly working, what can i...
Is the unit old?? Is it stored in an environment that has temperature fluctuations?? It could be the terminals on the input of the unit have dry jointed. This is when the solder lifts away from the circuit board. I have had the same problem on my ZOOM MRS1608 recording desk. Resolder the connections on the input. The base plate will problably remove easy enough to get to the point where the adapter is soldered onto the circuit board.
Good luck
Aug 11, 2011 | Zoom G1x Guitar Multi Effects Pedal with...
My ibanez Ael20 works for 2 seconds when plugged in and than stops working. I have replaced the batteries.
Make sure you are using a TS type cable (standard guitar cable, not balanced). Make sure the tuner is off as there are modes for tuning that kill the outgoing audio during tuning.
Jun 23, 2011 | Ibanez Ael20e AcousticElectric Guitar with...
Any way to sever the "bypass" connection from either the "A" or "B" input? Scenario would be an Electric Guitar in input "A", which passes it's signal out the...
Just use WYE connectors and run each guitar to their destination without using the bypass output of the tuner at all... Each guitar into a WYE into the tuner and then continue to the amp and DI box.
Mar 19, 2011 | Korg Pb02 Pitchblack+ Advanced Chromatic...
After several months of being stored i used my roland juno D to find that some of the keys didnt work. I cleaned the rubber contacts etc but they still dont work? and the ones that do are uneven volumes...
Did you clean these contacts with ONLY isoprophyl 99% alcohol and Qtips? If you used another product you may have spoiled the contacts. Also did you clean the circuit board where they contact with the same product?
If you used another cleaner, best to redo your work... quickly... Contact cleaners such as Deoxit and Blue shower destroy this type contact.
Mar 14, 2011 | Roland Juno-D
G1X not working
The first thing to check is the power source. A weak battery or adapter will cause this.
Beyond checking these the only other problems will be internal and require electronic servicing.,
Jul 02, 2010 | Zoom G1x Guitar Multi Effects Pedal with...
No vocal sound
It sounds like the guitar level input to the unit is too low.
NOTE: With this product you MUST use an amplified or electric guitar that has a preamp within it.
If you have a straight guitar that does not have an amp in it, buy a preamp to first run the guitar through.
Apr 26, 2010 | DIGITECH VOCALIST LIVE 2
My mg100dfx gain knob spoiled.may i know the specs.for the knob pls
If you have the pot out look on the edge of the metal can for the code. Take it in to a good electronics supplier for a match. You will need the same audio taper also.
Jul 08, 2009 | Marshall Mg100dfx 100-Watt Combo Guitar...
Static Noise from guitar amp.
I take it you have made sure that both the cable to the distortion box from the guitar and the cable to the amp are both good. From the description you give, it sounds like there is no signal getting to the pedal. If the cable is good, then the next likely suspect would be the input jack on the fuzz box. Try wiggling it a little with the guitar cable in place to see if it is loose. Some input jacks are unbelievably cheap and flimsy. A crackling sound (static like) is almost always a bad connection. If it was the output jack, I would think that the guitar signal would come through a least a little bit, but you might want to try wiggling that one, too, if the input jack isn't the culprit.
Another possibility to check is the battery, but this doesn't seem as likely. Some effects units devour batteries, especially units that use 9V batteries. I have a multi effect pedal that kills a 9V in about an hour.
Jan 22, 2009 | Epiphone Les Paul Studio Electric Guitar
Fishman Aura Spectrum D.I. Logo
88 people viewed this question
Top Fishman Music Experts
Matthew Spark
Matthew Spark
Michial Gueffroy
Are you a Fishman Music Expert? Answer questions, earn points and help others
