Question about Leggett And Platt Leggett & Platt Prodigy Adjustable Bed Full-Double
Prodigy Adjustable Bed with Massager not working properly.
The head and foot of bed only raise slightly, to number 8 on the remote, then make a loud vibrating noise and won't rise any higher. The massager works fine.
Bed foot is stuck in the up position
Try resetting the remote control and control box also check batteries
Feb 21, 2016 | Ergomotion US400TL59MNE 400 Series...
I have the adjustable bed, but have lost the remote control. Two #'s that I see are 17500249 & 062805.
ADJUSTABLE BED ACCESSORIES AND SERVICE
adjustablebedmart.com/accessoriesservices.html
REPLACEMENT HAND CONTROLS We have both hard wired and wireless remotehand controls. Does your hand control look like one of the two on the left?
Sleep Number Bed Replacement Parts ' Sleep Number
www.sleepnumber.com/sn/en/.../bed-replacement-parts
Select ComfortREPLACEMENT PARTS. Remote control. Most issues with your remote can be easily resolved by following certain troubleshooting steps. If your remote is ...
Jan 25, 2016 | Televison & Video
The bed is stuck with head up can I manually lower the bed
We have a Tempur-pedic. Each side is controlled by its own remote. It also has battery backup for each side (head and foot) in case the power goes out. We simply push a little button on the battery controlled box on whichever side needs lowered. It works to lower them, but they cannot be raised in a power outage. If you don't have something like that, or a manual crank or something, I suggest you call the company and ask THEM what to do. If it's stuck with the power still on, then even more reason to call the company.
Apr 23, 2014 | Ergomotion Furniture
Medline electric bed wont stay raised equally
If the bed is equal when raised and one end slowly goes down,that bed end is bad. Gears in the end may be stript allowing the cable to not hold.
If the ends are always unequal, dis engage drive shaft (head) and the spring loaded actuator at foot end.
in the middle on thetop of the bed ends slide the plastic access door to expose a slotted feed screw. Turn the slotted screw to make the end go down completely. Repeat on other side. Once completed put drive shaft back on and engage actuator at foot end. This should work
Apr 05, 2013 | Medline Medical
Coaster wireless remote not working.
I would suggest contacting Coaster directly: http://www.coasterfurniture.com/contactus.aspx
I know they have a 1 year limited warranty on all of their furniture. I believe you can submit a warranty claim through the retailer who sold you the adjustable bed. More details can be found here: http://www.coasterfurniture.com/current/warranty_2011.pdf
Aug 13, 2012 | Coaster 300131Q Adjustable Queen Size Bed...
My Adjusta-magic control for my Englander bed will not work. HELP PLEASE! The foot of the bed will not go down.
1) You must open the foot of the bed , and see for the switch, and test it with a VOM, see for open , tight any wires loose cables, or broken and repair. God bless you
Jun 13, 2012 | One For All URC-3300 Remote Control
Ultramatic bed problem - bed will not raise either head or feet - does not move at all. Received replacement remote from company but no different. Lights on remote do not stay on - only when press a button...
Had same problem with my husbands moms bed. Found out that it ended up being a stripped plastic piece that the screw uses to raise and lower the bed. Because its stripped the screws don't have anything to grip on again to raise or lower bed. Piece needs replacing, but not sure where to get them.
Jan 12, 2011 | Minicraft Models Full Electric Bed -...
My Craftmatic Adjustable bed does not stay upward after adjusting it (head or foot). It just slowly sinks back down.
Hi. Most likely a faulty switch in the hand piece. I had a hoist in for repair the other day doing a similar thing. The down switch was being pressed by the covering on the handpiece. You might be able to find someone in a local electronics store to look at it or buy a new hand piece. Try raising the bed and then unplugging the hand piece and see if the bed stays up. Good luck. Neil.
May 21, 2010 | Health & Beauty
Leggett And Platt Leggett & Platt Prodigy Adjustable Bed Full-Double Logo
301 people viewed this question
Top Leggett And Platt Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Leggett And Platt Furniture Expert? Answer questions, earn points and help others
