Question about View and View Technologies VNV AquaView 17XP 17 in. Flat Panel LCD Monitor
Input not supported
I have View and View Technologies TFT LCD monitor, model 17XP. I works fine with Fedora but displays "input not supported" for Windows XP. Any ideas?
    Scholar:
  • 71 Answers
Do you get anything on the screen when you first turn on your computer?
If you do the windows resolution somehow got set to high for the screen to handle. To fix this press the F8 key a couple times after the BIOS splash screen goes away ( The screen that has HP or DELL, etc on it). If done at the right time it will bring you to a menu that has several options including safe mode. You'll want to pick " Enable VGA mode." From there it will start to load Windows, but everything on the screen will be large. Once windows is fully loaded find a empty spot on your desktop and right click. From the menu that pops up please select Properties. It will open up a box that says "Display Properties." Click the tab that says Settings. On this tab move the resolution slider to right right a click or two to make the monitor normal size and click apply.
Posted on Nov 14, 2007
Norcent Technologies LM173SB 17 in. Flat Panel LCD Monitor Won't work with Windows 7
I ran into this very problem myself, the issue is that the monitor only supports 1280x1024 resolution MAX. Windows 7 cannot detect this monitor and so it does not know it is limited to this resolution, so Windows 7 is putting out a higher resolution at startup, thus the monitor tries to autodect for a second but then just goes blank because it doesn't understand (and can't display) the signal. The only solution is to use another monitor and adjust the resolution to 1280x1024 or lower, but I run into a problem where as soon as you remove the other monitor and restart, WIndows tries to "plug & play" the monitor all over again at startup. So you're best bet really is a newer monitor unfortunately, I only use my old Norcent monitor with my XP computer.
Aug 29, 2012 | Norcent Technologies LM173SB 17 in. Flat...
I recently reinstalled my windows XP program and added the Dell E173FPc. At the beginning it work perfectly. I then downloaded all the XP updates and restarted several times. I now have a terrible...
Have you tried setting the resolution using display settings in control panel?
Go to control panel search for display. There you will find option to select monitor and resolution.
Oct 01, 2017 | Dell E173FPc 17" TFT LCD Flat Panel...
I have A VNV Aquaview 17xp monitor,when I turned it on the power button lit up orange,the screen is black,is the transformer bad,can I buy parts to fix this,or do I need to throw it in the trash. and now...
Take a look inside and also read about bad caps.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Jun 26, 2010 | View and View Technologies VNV AquaView...
LIGHT VIEW 17" TFT MONITOR LM17SB OUT OF RANGE WHEN USING WINDOWS 7 WORKS FINE WITH VISTA
Set your resolution from "Display" which you can find in control panel. And fix the resolution at 1280 by 768.
Regards
Ashly
Feb 02, 2010 | Dell E173FPb 17" TFT LCD Monitor
Monitor goes to BIOS Screen Repeatedly
Your monitor is fine, the problem here is with your computer, and sounds like a virus. Time to competely reinstall windows, or have a tech look at the computer.
Aug 01, 2009 | Microsoft Windows XP Professional SP2 Full...
Monitor displays the message "INPUT NOT SUPPORTED"
Hi
please install the monitor driver to your pc the see what,...
Thanks!
Jul 08, 2009 | Acer AL1913 19" LCD Monitor
It is all black, as if off
when starting windows press f8 key before the windows logo shows up > go to safe mode > click start>control panel> display>adapter>list all modes> choose 800x600 x 16 colours > apply > close > reboot to normal xp. OR When f8 key pressed > choose VGA mode. If this does not work then change the VGA Cable (borrow from someone if its TFT to test)
Jan 05, 2009 | Acer AL1717 17" LCD Monitor
Windows XP Pro. driver for the acer LCD Monitor X193W
To my knowledge, it is compatible and certainly would work with XP. Since this monitor has both DVI and VGA inputs make is compatible for most video cards or even a built-in video of the PC. If for some reason the Acer X193W would not work with your Windows XP PC, possible reasons are:
  • Screen Resolution and/or Screen refresh Rate of the PC's Display Properties too high, try lowering them down;
  • hardware fault either on the monitor or video card;
  • incorrect/missing drivers of the video card;
  • it is being hooked as a secondary monitor and the dual/twin view is not activated.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Nov 08, 2008 | Acer X193W LCD Monitor
View and View Technologies VNV AquaView 17XP 17 in. Flat Panel LCD Monitor Logo
243 people viewed this question
Top View and View Technologies Computers & Internet Experts
David Payne
David Payne
Are you a View and View Technologies Computer and Internet Expert? Answer questions, earn points and help others
