Question about Pioneer Car Audio & Video
I have a Pioneer AVIC 8100 NEX and im getting amp error message and loud noise coming out of my speakers how do I fix it or What's causing it
SOURCE: PIONEER AVIC-N3 DVD CAR AUDIO
There's a small switch on the back. It's covered by a silver sticker. It will void the warranty if the sticker is removed, but once the little switch is hit, the video will be displayed while Driving for the front seat passenger ;-) You also should connect the brake wire to a constant ground source to avoid any problems. -I-
Posted on Sep 23, 2007
hogan doan
  • 227 Answers
SOURCE: pioneer AVIC-D3
Check your EQ setting for each source, sometime on certain unit each source can have it own setting. May be try to reset it by disconnect the battery and reconnect. If you still have a remained warranty, contact Pioneer and send it in for service. Hope that would help.
Posted on Mar 05, 2008
hogan doan
  • 227 Answers
SOURCE: Ipod problems with Pioneer AVIC-D3
Do you have an ipod module or are you using ibus-to-rca cable to connect your ipod to the D3? In order to control full ipod functions by touch screen you need the ipod module, hence the D3 says ipod control ready not ipod control built in. Let me know so I can pin point the problem.
Posted on May 02, 2008
SOURCE: How do you pair an LG Dare phone Bluetooth to Pioneer Avic Dz3 unit
make sure your phone is in discovery mode so it can be seen by bluethooth device, I had the same problem with my lg voyager
Posted on Sep 12, 2008
MNfisherman
  • 11896 Answers
SOURCE: pioneer avic z2
The rick to cure this problem is to disconnect the ground wire from the harnessand ground it to metal on the vehicle like ashtray or something. (radio ground to car metal. This will cure your problem
Posted on May 05, 2009
Amp error message on Pioneer DEH-15UB. Vehicle was jump started twice would this cause this problem? The receiver is not connected to an external amp. The radio/cd player will work for about two minutes...
I just had an "amp error" message display on my Pioneer DEH-15UB and it quit playing. No sound at all. It happened while I was driving my Jeep. When I got home I removed the passenger side speaker from the sound bar and found the previous owner had used a wood screw to hold the wire to the speaker. That screw came into contact with the metal roll bar and caused the error. When I installed ends on the wires the error message cleared itself and now works fine
Sep 17, 2013 | Car Audio & Video
I have a Pioneer AVIC D3X im get a error 2 when i put in a cd
Dirty, Clean disc, Scratched disc, Replace disc, The disc is loaded upside down, Check that the disc is loaded correctly.
Mar 26, 2012 | Pioneer AVIC-D3 Car DVD Player
Pioneer VSX-1015TX 7.1 Receiver AMP ERROR I just recently started getting this AMP ERROR message when I try to change input sources, it does not matter which source I click on, for example, whenever I...
I would recommend checking your speakers polarity ( + on the + - on the - ). Also check to make sure the wires are not touching each other where they connect to the speaker or amp. Also check your input connections if you are not using HDMI or Optical. Worst case is you have to send it in to get serviced. Hope this helps
Mar 15, 2011 | Pioneer VSX-1015TXK Receiver
The navigation voice has no audio on my pioneer AVIC D3
voice only comes out thru the front speaker, if you hook up amp to rear rca, change to fronts. also speaker outputs, too. btw, did you turn on the voice/volume at the menu??
Dec 16, 2009 | Pioneer AVIC-D3 Car DVD Player
Pioneer avic z2
May 05, 2009 | Pioneer AVIC-Z2 Car DVD Player
Road noise
Is it a whining noise that changes with the accelerator pedal? Do you have aftermarket amplifiers in the car? There are a number of different noises you could be hearing and a number of solutions for each. Also, if aftermarket amplifiers are connected to the front speakers and the Pioneer radio was powered up and RCA's connected to the back, you may have burned out a diode inside the radio and you'll get "engine noise"
Jul 11, 2008 | Pioneer AVIC-D3 Car DVD Player
Thanks but I still need help!
there is a guy on ebay that say that they will fix it for about $150, i have the same problem and it look like no one can give an answer for please post if you found a fix.
Jun 11, 2008 | Pioneer AVIC-D1 In-Dash Mobile Navigation...
Pioneer GPS - AVIC-S1
Main screen ---Settings ----Keep follow the 1st page, you will see the restored function as Restore Factory Settings.
Apr 13, 2008 | Pioneer AVIC-S1 GPS Receiver
Humming sound
you might need a surge suppressor i think that what its called i had a problem like that with one of my old cars the noise is generated from the engine and it goes through the power creating a surge which makes it hum cause the power needs to get filtered properly. you conect it in the positive and negative wires
Apr 30, 2007 | Pioneer AVIC-Z1 Car DVD Player
Car Audio & Video Logo
196 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
