Question about Exercise & Fitness
How do I tighten the belt on my treadmill - Exercise & Fitness
    Top Expert:
  • 10,875 Answers
Should be a couple bolts on either side,tighten both the same
Posted on Apr 06, 2015
5 Suggested Answers
SOURCE: i need to know how to tighten the belt
describe how to tighten the belt on a tx 400 sportscraft treadmill.
Posted on Jan 06, 2010
bwinton
  • 83 Answers
SOURCE: Treadmill is slipping. Already tried tightening
This sounds like either the drive belt is loose or the walking belt is old. First, check the tension on the drive belt. If the drive belt is not slipping, then walking belt may need to be replaced. I say may because without working on the unit, I cannot say that IS the problem.
Posted on Mar 19, 2010
maxtreadmill
  • 832 Answers
SOURCE: How do adjust tension on treadmill belt
If the walking belt slips when walked on. Using the allen wrench, turn both rear roller bolts clockwise, 1/4 of a turn. When the walking belt is correctly tightened, you should be able to lift each side of the walking belt 3 to 4 inches off the walking platform. Be careful to keep the walking belt centered. Carefully walk on the treadmill for a few minutes. Repeat until the walking belt is properly tightened.
Posted on May 31, 2010
AJIN G
  • 6694 Answers
SOURCE: How to tighten the walking belt on a Reebok treadmill
Posted on Dec 21, 2011
I have a Healthstream Ge3400 Lightning treadmill and I need to know how to tighten the belt as I can't find the user manual for it, It has been ages since it has been used and when you walk on it even...
hi,
Here is the steps to adjust the treadmill belt,
(1). Turn off the treadmill and remove the plug from the wall outlet to make sure it doesn't turn on during the readjustment process.
(2).Tighten the roller bolts on the rear of the treadmill belt with an Allen wrench. Tighten both the right and left bolts with 1/4 turns.
(3).Avoid tightening the bolts more than 1/4 of a turn at a time. If the belt is tightened too much, it may cause damage to the belt, which would require a replacement.
(4).Plug the treadmill into the wall and press "Power."
(5). Select a program and begin walking. If the treadmill is still slipping, turn off the treadmill, unplug it and tighten the bolt a 1/4 turn again until it is properly adjusted.
watch the following video which will help you to do the same.All brand hve the same procedure for tighten the walking belt
Sep 04, 2011 | Exercise & Fitness
Belt starting slipping, adjusted according to User's manual...belt still slips.
hi,
watch the following video which will help you to do the same.All brand hve the same procedure for tighten the walking belt.
If then also the belt is slipping then you have to replace the running belt with a new one.
ok
Sep 03, 2011 | Reebok T 1280 Treadmill
I have a Reebok treadmill. The belt stops while the motor continues while walking on it. What could be causing this to happen?
the drive belt is too loose. you need to tighten the belt that drives the front rolller, which drives the walking belt. depending on the type of treadmill there shoudl be a way you can do this by loosening the motor and adjusting that to tighten the belt. it could also be that the belt needs to be replaced and also could be the walking belt. you should try to tighten the walking belt first. that is at the end of the treadmill where you walk on it. there are two holes one on each side of the treadmill where teh belt goes back under the treadmill. there are allen key bolts that you need to tighten clockwise one turn then try the treadmill. if it doesnt tighten then turn another full turn. if not tight enough then it might be the drive belt. if you tighten the walking belt all the way then try to tighten the drive belt.
Jan 28, 2011 | Reebok Exercise & Fitness
My running belt is slipping how do I make the Adjustment to tighten the belt?
hi,
Treadmill's belt get slipped when the the belt expands due to the usage and wear and tear. In all teradmill's there is an option for tighten the belt. I have added here some videos related to the belt tightening of treadmills. so many makes of treadmills the have similar adjustment. it will help you a lot to adjust the belt of your treadmill. you need allen keys to adjust the screws. watch the video and do the same. If you need further assistance fell free to contact me through fixya.
Jan 16, 2011 | Precor 923 LowImpact Treadmill
Belt is slipping.... does this mean I need a new belt?
Typically you can tighten the belt with an allen wrench at the rear of the belt, treadmill be sure to align belt before tightening. Alternate each side as you tighten
Nov 25, 2010 | Proform XP 580 Trainer Treadmill
My walking belt is off cener
Here are two solutions one is to get the belt centered on the treadmill and the other is to tighten the belt.
There should be two bolts in the rear of the treadmill, one on each side. These bolts adjust the rear roller of the treadmill. The walking belt will always go to the side that is looser. To get the belt back on track, (if you can start the treadmill so the belt is running) tighten the bolt on the side that the belt has slipped to. Tighten the bolt a little bit at a time. If you tighten the bolt too much, then the belt will go to the other side.
To tighten the belt, start by locating the two bolts that adjust the rear roller (one on each side of the unit in the back). Run the unit at about 3 mph. Tighten the bolts a 1/4 turn at a time. Make sure that what you do to one side, you MUST do to the other side or the belt will get off center. After you tighten it 1/4 turn, check the belt to see if it is still slipping. If it is then tighten the belt 1/4 turn again. Continue until the belt does not slip, but do not tighten the bolts more than 2 full turns.
May 07, 2010 | Proform 530 Treadmill Walking Belt
The belt on my treadmill is off to one side. how
Apr 27, 2010 | Exercise & Fitness
Treadmill belt keeps slidding to the side
Apr 08, 2010 | RTO Image 15.0R Treadmill Walking Belt
The belt went all the way to the right side and it sticks when walking
Mar 10, 2010 | Proform 650 Crosstrainer Treadmill
Adjusting the walking belt
Jan 13, 2009 | Exercise & Fitness
Exercise & Fitness Logo
44 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
