Question about Breville Kitchen Appliances - Others
We have a Breville 9217 electric razor. A great razor but can't buy the blades. they are a 2 hole blade. Can someone help please?
Q89037 Breville 9217 electric Razor.
robotek
  • 1512 Answers
SOURCE: Remington HKVAC-2000 Electric Shaver
Hi beebee73
If you are referring to the hkvac2000, it is a clipperstyle shaver, where the blades, because of the cutting action, do not generally need to be replaced. I have checked on the Remington website, and they do not sell any spare part blades for this model. To se what all comes with the shaver... comb sizes etc, check out the user manual for the device here
Hope this helps you. If you need me to do some more research, just ask:) Thanks for using FixYa, a FixYa rating would be great for my efforts to get this information for you. Cheers
regards
robotek
Posted on May 08, 2008
  • 3 Answers
SOURCE: Wahl razor's not cutting, how do I fix it?
have you tried taking apart the blades and replacing them so that they line up together? Have you had a professional shear sharpener look at your blades? mabie all they need is to be sharpened again. Blades like knives or scissors need to be sharpened every once in a while. Also try replacing the blades with a new ones. The blades may have worn out. also try oiling the blades every once in a while.
Posted on Oct 14, 2008
SOURCE: changing lens on oakley razor blades glasses
Firstly, remove your nosepiece. Grab hold of the frame at one of the top corners with an index finger and thumb - use your other index finger and thumb to hold the lens, apply presure and gently pull apart. The notch will release. To mount your new lens, insert one notch into the frame and press the other notch into place. Do not apply pressure to the stems or hinge.
Posted on Jun 24, 2010
brector3
  • 1610 Answers
SOURCE: I have a Norelco model 7315 razor that I purchased
It is very unlikely that the smell is coming from the body of the shaver. Have you completely removed the heads and thoroughly cleaned them individually with alcohol or shaver cleaner? If you are simply rinsing the blades under the faucet and have not removed them and thoroughly cleaned them, this is almost certainly the problem. The smell is decomposing hair and oils from your skin.
You may want to consider using a shaver cleaning product like the ones linked below from shaveroutlet.com
http://shaveroutlet.com/norelco-al80-razor-lubricant-spray-p-255.html
http://shaveroutlet.com/shaver-accessories/eltron/eltron-parks-shaver-cleaner-p-737.html
Posted on Jun 29, 2010
Testimonial: "Excellent advice. Cleared the problem up with one thorough cleaning. Thank you"
brector3
  • 1610 Answers
SOURCE: how to remove the blades
On Arcitec shavers, the blades can not be removed from the head assembly. This makes it difficult to thoroughly clean them and they must be replaced reqularly because of this.
If needed, you will find replacements at shaveroutlet.com.. See link below
http://shaveroutlet.com/shaver-replacement-parts/norelco-philips-rq10-arcitec-replacement-heads-p-353.html
Posted on Nov 18, 2010
How to change blade on a Chicago jigsaw
Harbor Freight Chicago Electric Jig Saw - Review - YouTube
? 2:21
www.youtube.com/watch?v=lSh0M4WIJTk
Dec 13, 2013 - Uploaded by AdamDIY
Chicago Electric - Orbital Jigsaw 92772 They change the design over time but some of the key flaws tend to ...
jigsaw from hell - chicago (electric?) brand - DoItYourself.com ...
www.doityourself.com/.../445560-jigsaw-hell-chicago-electric-brand.ht...
Mar 9, 2011 - Most blades either have a hole in the shank or the shank is shaped like a .... A brand new one is only about $25 and no tools for blade changes.
Oct 22, 2015 | Saws
Dull razor blades after moisturizing stripe wears off
Expensive replaceable cartridges are only made to offer 4-6 "good" shaves for most people. Sorry - that's the deal. You can strop cartridges (in on direction only) on denim and pick up maybe a dozen more - search youtube for examples. I finally gave up on carts and moved to a straight razor; a razor or two will last for a lifetime with good care. There IS a learning curve for safe use and maintenance procedures. Find a straight razor forum if you want great shaves and good advice on what to buy, what not to buy and how to be safe.
Double edged safety razors are also a very good alternative for better, smoother shaves and WAY less expensive blades. Same advice - find a razor forum to save money, buy right and avoid nicks.
Apr 16, 2014 | Health & Beauty
How to fix a wobbly ceilng fan
wobbly cieling fan
1. make sure all mounting screws between the fan and the ceiling are tight. There is probably an electrical box mounted in the cieling that the fan is screwed into. I would turn the fan light on and then keep flipping breakers off, on at a time ,to see which breaker turns off the fan light. leave the fan light breaker off and you can unmount the fan from the cieling electrical box. The electrical box may have several holes in it for mounting screws and prehaps there are some holes left empty in the box that you can put more wood screws into to help keep the electrical box more firmly mounted and that may help lessen the wobble.
Its ok to bend the electrical wiring aside to put more screws in. Just be reasonably gentle with the wiring and then bend it back somewhat to where it was before you started. make sure that wiring does not get pinched between the fan and the electrical box and that all wiring resides inside the box.
#2 This is harder to do. you need to balance the blades for the fan ,similar to how a lawnmower blade is balanced after sharpening and before remounting the lawnmower blade on the mower. also kinda like balancing a car tire. I have a lawnmower blade balancing fixture that i bought at the lawnmower shop, but i dont know if there is a fan blade balancing fixture that you could buy from somewheres. Maybe try google.com,bing.com or ask.com and type into the search box fan blade balancer
or fan blade balancing fixture or fan blade balancing jig.
PLEASE read the directions or SPECIFICATIONS before you buy the fan blade balancer, only to find out that it only fits 9 inch diameter fan blades, and your blade is 2 4or 36 inches long.
The balancer may have to fit a certain diameter hole at the center
of the fan blade. When you finally find out which side of the fan blade is heavy, you have to grind , with an electric grinding wheel, some material off the heavy side of the blade so that it is the same wieght as the light side of the blade.
Try to imagine a cone shaped center[like step drills] like the capital letter V ,only up side down, so that the point is up. ON the underside of the inverted V is a needle tiped post that upside down V can pivot in any direction on. The hole in the middle of a lawnmower blade is centered somewheres on the outside of the inverted V, depending on the diameter of the hole in the lawnmower blade. The heavy side of the mower blade will go down and may touch the level asphault or the table top, depending on where you placed the balancing fixture. THen i would grind off metal until the heavy side can up to be level with the light side of the mower blade and it was considered balanced.
an appliance repair parts store may sell fan balancers, but if the would fit your cieling fan, better ask before you waiste your money on something that wont work for what you want.
Try calling up customer service of the manufacturor of your ceiling fan and ask about repair service for your brand fan.
see what repair service has to say, im sure many others have asked them about wobbling fans.
so they should have all the answers down pat.
Two more thoughts.
1.
.MAKE SURE ALL SCREWS THAT HOLD FAN BLADES ON TO THE HUB ARE THERE AND are TIGHT. one loose fan blade mounting screw or one missing fan blade screw will unbalance the whole thing and cause wobble.
2. the fan motor shaft bearing could be worn out or round or even egg shaped. If this is the cause, the motor must be diaassembled and new fan shaft bearings installed or the fan motor must be replaced.
good luck and have fun!
Sep 22, 2013 | Hampton Bay 24002 Ceiling Fan
What is an electric shaver?
Not like shaving razors, electric shavers work by shearing the whiskers, the hair enters the perforated metal heads of the shaver and is cut by the moving blade inside.
Feb 06, 2013 | Health & Beauty
It keeps saying check color cartridge. If the color is done, shouldn't I be able to still print, with black. And why it would not work if only one cartridge is in.
My dear its business, printers are running with mono cartridge,with our color cartridge who will buy color one? Its story of razor and blade, once you purchased razor, every time you need to buy blade! if the blade cost is half of the razor cost what you will do?. You cannot throw the razor out or else you can't spend on blade..this is business...
Sep 28, 2011 | HP PSC 1610 All-In-One InkJet Printer
Needed blades for wahl clipper homecut usa type 9217.both blades chipped on one corner where can we purchase blades ffrom to replace them thankyou.
The blade you have is it a three hole blade or a two hole blade and if you can send me a picture of the blade it self I could order it for you. send me an email at ask@mannyssharpening.com
May 08, 2011 | Health & Beauty
Hello. I need two parts for my Breville Classic BlendMaster Model CBL-10. I need the removable centrally located inner lid and also the blade assembly features patented stainless steel twin cutting...
Breville CBL10 has been a fantastic appliance but now electrical section works at slow speed only so I will get rid of it, however the glass jug complete with lid, blade etc is still perfect. Does anyone need this part? I am in Rockhampton.
Jan 23, 2011 | Breville CBL10 BlendMaster Classic Work...
How to replace window blades?
It depends on which style of wiper arm you have. Most auto parts stores will install new wiper blades free - just ask them when you go in to buy.Don't buy the cheapest blades - you get what you pay for! I personally buy Bosch blades - being winter, I get the winter blades. Wiper blades are meant to last only 3 months and the life will be greatly shortened if you have tree sap or chemicals on the glass. Scrape the glass with a razor blade then clean with an alcohol based window cleaner and make sure you wipe the new blades with the alcohol wipe they come with, as most all blades have a chemical coating to delay rubber decay during shipping and pre - sale storage and this coating can cause streaking on your window. You may want to clean your existing blades with alcohol if they wipe good but streak or cause hazing on the windshield. Hope this helps and please rate my solution!!
Nov 22, 2010 | 2003 Buick Century
I took my Wahl clippers apart to clean ......
Okay I fixed mine. this is I what I did and it works now take the big blade and put it on a table, take the little blade and put on top of the big blade if you look closely at the big blade you can see where the little blade went, make sure you allign the blades. next take the white thing dont know what you call it bit it rotates the blades put that on the little blade, take the gold piece align with holes to the big blade and take the silver piece allign with holes and then put the screws back in. when you put it on the clipper make sure the white piece goes in the hole that rotates the blades and sould go in fine
Jun 08, 2009 | Wahl 8550
Conair hc318d reassembly
i have hc318d clipper it been use two time and havent use it in a year so was going to use it last nite and the small blade fell out. i try to put it back in and it want hold keep falling out
Dec 17, 2007 | Conair HC100RCS Hair Trimmer
Kitchen Appliances - Others Logo
166 people viewed this question
Top Breville Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Jerry Greenberg
Jerry Greenberg
bengsoon Neo
Are you a Breville Kitchen Appliances - Other Expert? Answer questions, earn points and help others
