Question about Kyocera Mita Office Equipment & Supplies
How can service error code C0220 be fixed? - Kyocera Mita Office Equipment & Supplies
  • 43 Answers
On which machine?
Posted on Apr 27, 2016
2 Suggested Answers
  • 523 Answers
SOURCE: KYOCERA 6030 ERROR CODE C0220
Try reset this code by entering on the panel: 1087 1087this will take you to service modehit 906 then hit Start keythen on the screen highlight execute and hit start key.
the machine is going to reboot and this will take care of your problem.This is a board error but can be fixed by updating the machine firmware.
Posted on Jan 13, 2012
Error codes c0220,c0040,c0035
They seem to be related to ABS. Is your ABS service light on? If so, it could be a sensor.
Jul 07, 2016 | Cars & Trucks
Tip
How to resolve Cannon ir400 Error e004
<span>Hi,<br /><br />For error code E004-001 or E004-002<br /><br />Cause:<br />The SSR has a short circuit.<br />&bull; The SSR has an error.<br />&bull; The DC controller PCB has a fault.<br />The heater relay has an error.<br />&bull; The heater relay has an error.<br />&bull; The DC controller PCB has a fault.<br /><br />Description:<br />&bull; The fixing heater remains<br />on.<br />&bull; The fixing temperature has<br />increased abnormally.<br />The heater relay remains on.<br /><br />FIRST TRY TO CLEAR ERROR:<br />Resetting Errors<br />1. The following error codes cannot be reset by merely turning off and then on the main power.<br />They require resetting in service mode:<br />E000, E001, E002, E003, E004, E032, E717<br />1) Start service mode, and select COPIER&gt;FUNCTION&gt;CLEAR&gt;ERR.<br />2) Press the OK key.<br />3) Turn off and then on the main power.<br />2. Error codes other than the above may be reset by turning off and then on the main power.<br />n Detail Code<br />Some error codes offer detail codes, which may be checked in service mode:<br />COPIER&gt;DISPLAY&gt;ERR (3rd block from the right)<br /><br />SERVICE MODE: <br />1) Press the asterisk key ' * ' on the control panel.<br />2) Press '2' and '8' on the keypad at the same time.<br />3) Press the asterisk key ' * ' on the control panel.<br /><br /><br />If these doesnt helps, you need to call service to locate the fault, which is probably bad thermistor.<br /><br />Hope that helps!<br /></span>
on Feb 06, 2011 | Cannon i70 Printer
Canon iR6800C printer error code E000002-0001 pls fix this error code on photo coppier machin
Hi. You have to clear that error from service mode
Try to clear that error from service mode
press additional function
2 and 8 together
select copier
select function
select clear
select ERR
select ok. Unplug of the machine for 5 second and then turn it back on
try to make some copies, if problem persists fixing heater is damaged and need to be replaced
Mar 28, 2015 | Canon Office Equipment & Supplies
How do I fix the copier if it says call for service?
Hi
You don't mention any error code that may shown and which would identify where the fault is. A full list of error codes can be found here:
Error Codes Sharp ARM355
and from here you can also get a pdf format service manual for this model which in combination with the error code explanation may enable you to fix your machine. On the error code page you can also change the model of your machine if you need to by using the drop down menu in the centre of the page.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Nov 27, 2014 | Sharp BR AR-M355N/455N - 1-DRUM
How to go service mode Cannon ir 400 ?
Here is the error code page http://www.scribd.com/doc/56428927/iR-400-Code-List
And here is the service manual
http://www.scribd.com/doc/135167936/canon-Ir-400-Service-Manual
Looking at what the error is, getting into the service mode will not allow you to fix it; you have some parts to replace first.
Jul 20, 2014 | Cannon Office Equipment & Supplies
How to fix error 006 in canon service tool
how to solve it service tools code error 06?
Jan 04, 2012 | Canon PIXMA iP2000 InkJet Printer
Dec 17, 2011 | Kyocera Office Equipment & Supplies
Printer error. Turn off the printer, and then turn it back on again after a moment. If the same error occurs, turn off the printer, then contact the store you purchased the printer, or a service...
Fixing temperature control startup error
Temperature of the Fixing Assembly did not reach the specified temperature within the specified period of time.
Remedy1. Check connectors on the fixing film unit. 2. Replace the fixing film unit. 3. Replace the engine controller PCB.
for more help visit CBR Tech Solutions
Dec 03, 2011 | Xerox Phaser Office Equipment & Supplies
What is Canon C3100 error code E000008 0001
The reading of the fixing roller life counter has reached its upper limit.just reach the counter reading at svc mode.
Mar 06, 2010 | Canon imageRunner C3100N Copier
CANON IR 3300 HAS ERROR CODE: E000002-0000
OK, but first try to clear the error under service mode, then replace fixing film assy, for EU 240V is FG6-6041.
To clear the error:
* 2 8 *
COPIER
FUNCTION
CLEAR
ERR
OK
Turn off and on ( main switch )
If this dont help - replace fixing film assy.
Dec 02, 2009 | Canon (6981A002AA) for imagerunner 2200,...
Top Kyocera Mita Office Equipment & Supplies Experts
Kyocera HP Expert
Henry Gertcher
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
