Question about Singer Sewing Machines
My Singer machine 8280 saw did not pick the material. the saw won'tmove back and forth just down and up that cause the thread to bundle up in the bobbin holder. please help.
    New Friend:
  • 20 Answers
Your space regulator is probably set at zero.
Posted on May 27, 2015
SOURCE: bobbin not picking up through the needle part of the machine
thread only shows the bobbin thread when i sew and needle thread also please e-mail me the attachment instructions. marybellroberts@msn.com
Posted on Nov 09, 2008
Mongo32
  • 111 Answers
SOURCE: Sewing machine will not pick up bobbin thread.
needle's in backwards
Posted on Jun 11, 2009
RickE1
  • 202 Answers
SOURCE: i dont know how to thread a bobbin on a singer prelude 8280-help!
Look it up at www.sewusa.com threading diagrams.
Rick
Posted on Aug 03, 2009
  • 96 Answers
SOURCE: needle will not pick up bobbin thread when sewing
double check the upper and lower tensions they often need to be changed to suit types of fabric and threads
Posted on Dec 13, 2009
tunde007
  • 2382 Answers
SOURCE: My old Singer sewing machine
Hi, try re-timing the machine. Select "straight stitch," then take the bottom off the machine to see underneath the bobbin case area. Open the faceplate and look for two marks on the needle bar around where it enters the machine. Take out the bobbin case to see the hook. Turn the balance wheel toward you so the needle is going down. Stop turning when the needle is just about to start on its way up. The bottom mark on the needle bar should be just about to enter the machine, and the point of the hook should be just above the eye of the needle. If it isn't, tilt the machine backward and loosen the two screws on the vertical gear so you can move the hook to where it should be. Tighten the screws and put everything back so you can test your setup. If it sews a straight stitch correctly, try it on zigzag wide stitch. If it misses one side, repeat the timing process.
Posted on Jan 22, 2011
On my Singer 8280, the thread stitches are very loose. I've tried adjusting the tension of the upper and below thread. No change, still loose stitches. Any ideas? I wonder if I broke and...
The most common cause of this is improper threading.
1. Thread the upper thread properly with the presser foot in the UP position.
2. Make sure the bobbin is threading with the thread unspooling in the correct direction.
3. Make sure the needle and thread are suitable for the fabric in your project.
Watch this video.
Oct 14, 2012 | Singer 8280 Mechanical Sewing Machine
Singer 8280 sewing machine tension won't increase
Make sure your needle and tread match your project. There simply isn't such a thing as a "universal needle." Also try lengthening your stitch. Heavier fabrics typically need a slightly longer stitch. Upon commencing to sew always grasp the 2 threads and slightly pull as you begin your seam.
I assume your garage sale find has a manual. Be sure your bobbin is unspooling in the correct direction. If it didn't come with a manual.. http://www.singerco.com/uploads/download/430_8280_es.pdf
Good luck.
Jul 04, 2012 | Singer 8280 Mechanical Sewing Machine
My bobbin thread won't pick up. Its a new machine and everything came attached. followed the instructions and no go.
Generally, this is because the needle is inserted wrong or because it's bent. In the first case, the top of the needle (called the shank) has a flat side-this has to be inserted so it faces the back or away from you.
In the second case, when a bent needle stops the top thread from picking up the bobbin thread. Even if you think your needle is fine, change it to see if this solves the problem.
May 09, 2011 | Singer 8280 Mechanical Sewing Machine
I cant get my needle to pick up the bobbin thread
You can download a copy of your manual for free on www.singerco.com under customer support if you need to see the correct way to thread your machine. Hope this helps
Oct 01, 2010 | Singer 8280 Mechanical Sewing Machine
Sewing machine
Simple solution..
take the thread off your machine, set your tension to the middle setting. rethread your machine up to the needle. before threading the needle, put your presser foot down. If your thread pulls hard, then the machine is threaded right. If it pulls easily, you need to chead the thread thru the tension wheel.
Kelley
Rule of thumb.
Loops on the bottom, problem on the top.
Loops on the top, problem is on the bottom.
May 02, 2009 | Singer 8280 Mechanical Sewing Machine
Singer 8280 is not giving me a useable stitch due to tension is not properly feeding resulting , no interlocking
Make sure that the thread is not getting caught on the handle. I was having the same problem and tried everything only to find that my thread was caught.
Oct 28, 2008 | Singer 8280 Mechanical Sewing Machine
Sewing Machines Logo
35 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
