Question about Microtek Televison & Video
Sir I have microtek inverter its problem is main input ac supply given to the inverter its not start but while connect DC 12v its out put is ok ..I already check both relays..mains corard..fuse its ok
SOURCE: Microtek ScanMaker power AC/DC adapter
OK WELL I HAVE A MICROTEK SLIMSCAN C3 AND I HAVE THE CABLE FOR THE POWER AND FOR USB......BUT MY PROBLEM IS THAT I DON'T HAVE THE CD TO INSTALL THIS.
IS THERE ANY ONTHER WAY TO INSTALL THIS IN MY COMPUTER WITH OUT THE CD??????
PLEASE EMAIL ME TO gemalabonita92@hotmail.com IF U HAVE THE ANSWER TO MY QUESTION!
THANK YOU!
Posted on Apr 22, 2008
SOURCE: No power
I had the same problem and i fixed it by unscrewing and installing the lamp cover on the bottom.. give it a try!
Posted on Jun 05, 2008
  • 12 Answers
SOURCE: power supply/ no output voltage
Actually i haven't fixed the problem as yet but i did find some info that would help me to fix problem.
I went to google and entered keyword,,, Electronic parts,,there came up a page,,and i went to several manuf sites till i found a replacement transformer,,then i disassembled the power supply and am now waiting for a replacement transformer.
Posted on Sep 22, 2008
freetek
  • 5568 Answers
SOURCE: ESA Plasma PDP4294LV No video,sound
 checked voltages meter set to AC referenced to chassis VA, VE, etc no voltages.
Do not try to measure voltages on the primary side of the power supply with a meter; you may damage the meter and cause new damage to the supply. There are switching frequencies somewhere between 50,000 - 100,000 Hz and possible voltage peaks of several hundred volts.
Checking AC is only useful before a diode bridge that converts incoming AC into raw DC that is then chopped at higher frequency into an approximate HF AC, coupled to the secondary, then tapped and connected to more diodes to produce DC, finally regulated and sent on its way.
Your plasma set uses some higher voltages that could have caused the cracking sound they heard but the DVD player didn't cause the problem directly; maybe just caused the HV for the display to surge for a moment.
You may have additional fuses on the secondary side of the supply. If test points are accessible there, check for DC voltages and be suspicious of any fuse or test point that measures nothing at all.
I can't tell you which voltages to expect since that varies from one design to another but you should find several lower voltages such as 5 VDC for logic circuits and perhaps a 12 V point. The plasma's HV could be produced from a separate board fed from the AC line or get its supply voltage from the main supply. There aren't many standards to rely on here.
The most likely semiconductor failure would be on the secondary side and diodes come in many different packages, many cylindrical, some in the TO-220 package with a metal flange and mounted on upright aluminum heatsinks. These will have only two leads and there will be some in the same package with three legs. The latter can also be checked statically but unless you know what kind of transistor or regulator (look about the same) you are measuring, you will not be able to ferret out a defective one with any luck.
While you have the set open, check for any dust bunnies that can act as sponges, collect moisture and create a discharge path for higher voltages.
Posted on Dec 27, 2008
dave1645
  • 834 Answers
SOURCE: No power from switch mode power supply. Input fuse
you could try shop jimmys.com or look closely at your supply to see if you might have puffed up caps these can like devices will have a puffed up yop from venting if you find some try replacing them the values are on the side
Posted on Nov 03, 2009
I mistakenly connected energy source at the AC inverter output .Inverter is 5KVA cyberpower inverter.After correcting the connection, It cannot switch from DC to AC( fault signal is displayed on its...
John,
It's shorted out, either replace the part or buy a new one.
If you need UPS, Surge, or Power Related help don't hesitate to contact me!
Daniel • daniel@psihq.com • Power & Systems Innovations • 800.260.2259 • www.psihq.com
Sep 24, 2013 | Cybernet Systems CyberPower DC to AC...
When i connect my inverter to dc power supply all fuses blow
DC input is polarity sensitive. This means that the positive input to the inverter must connect to the positive (+) side of the battery. Likewise the negative lead must connect to the (-) side of the battery.
An inverter does not work backwards. Attempting to put AC into an inverter will blow fuses at least.
Nov 23, 2012 | Stanley PC809 Inverter
Can i connect my tele in mt caravan on 12v
Yes. Either by using a 12v dc tv, or if it uses 120v/240v ac by using an inverter on the 12v dc supply which ups the voltage and converts to ac.
Jul 14, 2011 | Televison & Video
What voltage is applied to the lamp inverter PCB. ? MP7650
Most lamp invertor boards receive rectified and filtered mains dc voltage as the input power supply.
So if you have 240 V AC mains you would typically get around 339V DC. ie 240 times root 2. the peak AC voltage.
Jun 13, 2011 | 3M MP7650 Projector
Why would my new 1500 watt inverter readout show overload 13.8 volts entering
It would show overload if you're drawing more power than it can supply. 1500 Watts is a very high output for an inverter but that is the maximum it's capable of. As with any electrical supply you should not draw the maximum power it's capable of as this can cause it to burn out. Around 1200 would be the max you should draw continuously. You need to check the power requirements of whatever you're running on it. Also you need to check that it's capable of taking 13.8 volts. If 12 volts is the recommended input, putting in 13.8 will increase the voltage output which could damage appliances being run on it.
Jan 10, 2011 | PowerBright New 1500 Watt 12V DC to AC...
Circuit diagram
I'm afraid I cannot comply with your wishes, as there are copyright laws governing this, for one. (For existing circuitry)
Two, there is the liability issue. Take for example that I design the requested circuit, give it to you freely, and you or someone in your group is injured using my circuit.
Will state that this is a basic circuit design. I believe that if you 5 put your minds together, you can build this circuit.
Sep 14, 2009 | Powerline 200Watt DC to AC inverter...
Power supply/ no output voltage
Sep 21, 2008 | Boston Acoustics MicroMedia Computer...
THANK YOU!
Oct 18, 2007 | Microtek SCANMAKER 4850 Flatbed Scanner
MAGELLAN ROADMATE 700 ON THE FRITZ.
I had the same problem with myRm 700, too. Solution : connect your unit into the AC power pack . Turn it on. Then reinsert an address into the unit while plugged into the 110 volt ac wall outlet power supply. You may need to repeat this operation a few times.
Also, used mine in my 18-wheeler using a ac to dc power inverter. It seemed to work everytime. Note make sure the ac to dc inverter you by has enough dc output to feed your Gps all the juice it needs. That ac to dc inverter can be used to run other ac powererd appliances, too.
Aug 30, 2007 | Magellan RoadMate 700 GPS Receiver
Televison & Video Logo
Top Microtek Televison & Video Experts
Electro Med Services...
Are you a Microtek Televison and Video Expert? Answer questions, earn points and help others
