Question about As Seen On TV H2o Mop X5 5-In-1 Steam Cleaner With Elite Accessories
Machine heats up, no steam comes out and machine makes no noise. I cleaned all hoses and still nothing, no lime scale build up either. Thanks!
Horrible damp smell in my easi logic 1500 washing machine, what's the best cause of action?
Check the drainage of the machine.nothing like stagnant water sitting in the hoses and bottom of machine to cause smells.first check the penny / button trap for coins or debris as this will cause unsatisfactory emptying .do a rinse cycle with no cloths in machine.Get some calgon or anything that removes washing machine or dishwasher lime scale.then do a full wash without clothes on 60 degrees or above with small amount of bleach and lime scale remover.make sure the room is well ventilated.never overfill machine with dirty laundry when washing as this prevents the rinse cycles from removing bad water completely.try leaving the door slightly open between washes but only if you have no pets or children to prevent build up of damp spores.
Feb 19, 2015 | Washing Machines
How do I get the boiler on my rowenta steam generator to fill? I was given this model.
You should only use distiller water in the steamer. Never ever use tap water! This is what caused lime and scale build up.
Since it's to late, you have nothing to loose by trying this to descale the unit:
Put up to one cup of white vinegar into the reservoir. Fill 3/4 of the way with water. Turn unit on and let it heat up, but DO NOT RUN STEAM THROUGH THE LINE. Once heated up, turn unit off and let it set for hours. Drain and rinse well. Then run a water only batch through the steam cycle. There are companies that sell special de scaling solutions. But hopefully, the vinegar will work.
Apr 25, 2014 | Rowenta Steam Generator DG050 Iron
Delonghi Bar14FE Coffee Machine steamer wont stop spitting and hissing even when not in use
It should not be a big job. Open the top part, I had a similar issue it is probably either a blockage in the hoses or a disconnected hose. Just drain the machine and then go ahead with the your investigation.
Best of luck,
BTW: You only need a screwdriver to complete this task.
Mar 30, 2017 | DeLonghi BAR 14 Espresso Machine
Whirlpool dishwasher model GU2275XTVQ1 cleans poorly on top only
Check your hose, pump and all water lines for lime scale build up. Sometimes if you dont use some kind of lime away product every few months your machine will/can get lime scale build up from hard water causing it to not properly dispense the water through out your machine. You can also try to run a load with no dishes and no soap but put just lime away in your machine. It might just clear any clogs you might have or starting to get.
Jan 27, 2013 | Whirlpool Gold GU2275XTVy Dishwasher
Washing machine makes this awful sound and does nothing. Won't spin, won't drain and won't fill. Just this noise. Any hints would be much appreciate. I need clean clothes!! Thanks :)
Hi, It sounds like something is jammed, most likely a drive belt has come loose or snapped. Have you tried cleaning out the filter on your machine it is possible that something got caught in there especially if there are children about. I found a mobile phone in the workings of my tumble drier once. It may also be a large build up of lime-scale but if the machine won't spin no solution springs to mind apart from physically opening the back of the machine to have a look .
Oct 07, 2012 | Washing Machines
Flakes/Particles coming out of the steam nozzle.
hi there,
the small flakes are bits of lime scale from your boiler system, to fix/ reduce flakes/particles complete a de-scale cycle on your machine using de-scaler. water hardness- set on 1 will change the length of time before it will ask you to de-scale the machine. Note- hardness 1 is the max time length. hope this helps
Feb 23, 2012 | Saeco Royal Professional Espresso Machine
Will I still get coffee if the pump is broken. The machine is leaking staem and water underneath and I beleive it is the staem valve but a 'dodgy' coffee machine repairman is telling me it is the...
I am an expert espresso certified man. First of all your repair man is wrong. Let me explain. If you are getting steam at all, then your pump is not broken. This is the way it works, you have water in your machine, it goes into a area where it heats the water by heating elements, then as it heats it builds pressure by air and heat. The machine has a water pump in it, that operates by of course electricity, it pumps the water that is heated by the elements through the machine to of course make shots of espresso. The steam part is simular as it goes in a area, the gets hot and produces steam from the water, like a iron would of press kind of method. THE MACHINE will not make coffee or steam if pump is not working. If you turn machine on, and hear it humming or running, when trying to make a cup, then motor is running, if you turn it on and try to make a cup of coffee or steam and hear nothing at all, then pump is not working. If your machine is leaking under machine from from the steam valve, means it would not do that if pump is not working. Sense it is leaking, this tells me it is clogged. Most likely your need your machine cleaned good, that means descaled. Clean hoses, use small needle to poke in end of steam wand to clean out good jet air holes and basket screen. Find your manual, and it should tell you how to properly clean your machine, and even can use can of compressed air, that you can spray in hoses. It appears to be it is clogged, and when the pump or lines are clogged , it will back up like a clogged toilet and flood area around base and underneath. This whole problem is a cleaning problem, do to a clog or build up. I hope this. PS no if you pump is out or clogged, you would not get coffee as it need to the pump to work (unclogged) to push the water through the heads. Thanks Mike
Sep 15, 2011 | Gaggia Titanium Espresso Machine
My vaporizer is running however there is no steam coming from the machine. Ran all night and used no water does it need cleaned or should i just replace it. thank you
Well, let's consider what we have:
How old is the vaporizer?-- Could the heating coil be all limed up?
Lime-Away, or Vinegar might help clear the Calcium and mineral build up on the heating element-
Or there might be a bad connection?-- Do you have any lights lit?
Open it up, and tell us what you find-
Mack B
Jan 20, 2011 | Vicks Warm Steam Vaporizer 1.5 Gallon...
The steam on my Royal Pro has been getting weaker over a period of time, I do still use it but its takes a little longer to froth. I don't think its a scale issue as I'm in Australia & nothing else...
The problem could be the building up of scales in the lines and boiler.It should be descaled after about 800 coffees been made.Is it water coming out of the steam arm freely? If water comes out good and the steam is weak means blockage in steam boiler and the lines.
If coffee comes out well means the pump is still good. You can replace the pump quite easily by yourself but make sure steam boiler and the tubes are cleaned.
Have a good day.
Oct 16, 2010 | Saeco Royal Professional Espresso Machine
Cant remember how to de scale
Instructions per De'Longhi:
10.3 DESCALING
Due to the continuous heating of the water used to make the coffee, over time it is normal for the tubing inside the machine to fill with lime scale. When the light starts flashing, it is time to descale the machine.
NOTE: when the light switches on, the coffee maker can still be used to prepare coffee.
Proceed as follows:
• Empty the tank and pour in the contents of one bottle (125 ml) of DURGOL descaler plus one liter of water. For subsequent descaling operations, descaling solution can be purchased from authorized technical service centers.
Note: Make sure splashes of descaler do not fall onto surfaces sensitive to acid such as marble, limestone and granite.
• place a container with a minimum capacity of 34 oz. under the
cappuccino frother;
• turn the machine on by pressing the button.
• wait for the green and indicator lights to come on steady.
• press and hold the button for at least 5 seconds. The decalcification warning light will illuminate to indicated the start of the descaling program (the and lights remain off to indicate that it is not possible to make coffee).
• turn the steam knob half a turn counter-clockwise. The
descaling solution will come out of the cappuccino frother and start to fill the container underneath.
• the descaling program automatically performs a series of deliveries and pauses, so as to remove the lime scale deposits from inside the coffee maker.
• after around 30 minutes, when the light comes on, turn the steam knob half a turn clockwise until it stops.
The machine must be rinsed so as to eliminate the residues of descaling solution from inside the machine. Proceed as follows:
• remove the water tank, rinse it and fill it with clean water.
• reposition the tank.
• empty the collection container (located under the milk frother) that is full of liquid, and then replace it under the milk frother.
• turn the steam knob half a turn counter-clockwise. Hot water will come out of the milk frother and fill the container underneath.
• when the tank is empty, the indicator light goes off and another light (looks like a pitcher pouring water) comes on.
• turn the steam knob all the way clockwise and fill the water
tank with clean water again.
• the program of descaling is now terminated and the machine is
ready to make coffee again.
NOTE: if the descaling procedure is interrupted before completion, the alarm is not deactivated and the procedure
must be started again form the beginning.
IMPORTANT: FAILURE TO DESCALE THE APPLIANCE REGULARLY INVALIDATES THE WARRANTY.
You can download the entire pdf manual from the De'Longhi website: http://www.delonghiusa.com/index.php?texts&pid=10&catid=1
Helpful tips:
Descaling products are widely available from stores that sell coffeemakers and espresso machines. Be sure that the product you buy to descale your Espresso machine is intended for this specific use only. Before you descale your Espresso machine, always unplug it and make sure that it is cold. Also, never immerse the appliance in water or use abrasive cleaning products/scouring materials on any part of your espresso machine.
Jun 24, 2010 | DeLonghi Esclusivo Magnifica ESAM3300...
As Seen On TV H2o Mop X5 5-In-1 Steam Cleaner With Elite Accessories Logo
340 people viewed this question
Top As Seen On TV Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
Are you an As Seen On TV Heating and Cooling Expert? Answer questions, earn points and help others
