Question about Whirlpool WTW6400SW Cabrio Washer
Takes 3 times to start washer
It starts after 3 times and then starts beeping again
  • 40 Answers
I would check the drain pump, something maybe stuck in side and causing it to shut down. Or the lid may not be locking.
Is there a display with a fault code, or flashing lights on the counsel?
Posted on Apr 07, 2015
Testimonial: "Yes it flashes F1. Then with other loads or sheets it's always UL. Grrrrrrrr"
  • eroes99 Apr 07, 2015
    https://www.youtube.com/watch?v=BAVS9mI3...
    the link above may help with the F1 code. Under the washer the outer motor is held on by a quarter inch alen screw, sometimes they may loosen and drop the motor down a bit and cause the UL, but all your problems may be caused by a control board problem.
Starts inconsistently. When pressed the start button flames and the the power button needs to be turned off. It often takes several tries to get it started.
Richard, it could be a unresponsive control to reboot the unit unplug power cord from wall a couple of min's and plug back in. I would ask if you are gently holding start button in until you here a click then release the button. as the start button is depressed it is a time process to enable to processor to think... let us know.
Apr 19, 2014 | Whirlpool Duet GHW9150P Front Load Washer
When i start my front loader it beeps 3 times when i press 3 times
Good Afternoon Penny, thank you for allowing me to assist you!
I understand your washer machine is beeping three times, however it is inoperable or preventing your washer to function properly? With this information I can better address the issue at hand. Thank you!
Oct 22, 2013 | Frigidaire ATF6000ES Front Load Washer
F8 error code Whirlpool Duet
see this causes and fix it. See yur section troubleshooting in your owner manual, or call some tech.
F8 Board failure Replace control board (also called ERC or clock).
Sep 25, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Error f1 flashes after just a few seconds of turning on the wash cycle. if i turn off power and try to start again it will somtimes start if not i turn off and try again sometimes it takes 3 or 4 times to...
The Whirlpool Cabrio and Kenmore Oasis (same machine) are infamous for this problem. Depending on the serial number you may be entitled to a new control board installed for free under a recall program. Call Whirlpool for eligibility. I had just had mine replaced last week for free and it runs fine now.
Apr 27, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Kenmore Elite Oasis Washer 110.2709
3 Beeps/E30--Error: Drum overfilled. Cause: Inlet valve,pressure switch or control board failure.Select drain/spin to remove water. Restart.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 05, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Not filling properly with water
the screens where the water hose hooks up on the back of your washer needs to be cleaned
Dec 30, 2008 | Washing Machines
The wash beeps all the time
To stop the flashing and beeping, the customer may touch the Pause Cancel button. The error code remains stored in the control but once the problem is corrected, it does not effect the operation of the washer. If the failure is something that the customer can correct (such as the water faucets being turned off), the washer will operate normally the next time it is started.
Nov 18, 2008 | Frigidaire GLTF2940ES Front Load Washer
3 audible beeps every 20-25 seconds
Try unplugging the washer for about 20 minutes then plug back in and use. I have found that this actually works! The only thing I can figure out is that it takes time for the electronic control to clear. If that doesn't fix the problem I would call sears tech since it is less than a year old. They have a 1-2 year warranty.
Dec 21, 2007 | Kenmore Oasis HE 27062 Top Load Washer
Whirlpool WTW6400SW Cabrio Washer Logo
48 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
