My printer is e2 error show
Paper is moving but stop in the middle position
  • 2072 Answers
SOURCE: E2 Paper Jam code flashing .... but no paper jam!
There is a small sensor on the fuser that most likely has become disloged. It requires a lot of disassembly to get to.
But an E2 code is that sensor not being cleared off. It pops out of the frame sometimes during paper removal.
Posted on Apr 14, 2008
SOURCE: ERROR E2
Here is a picture of the aforementioned broken gear, with a replacement gear visible for comparison:
From a different angle:
The printer repairman said that the plastic gear found in this and similar models can fail after as early as a few months of use. Best of luck!
Posted on Jul 24, 2008
mybox258
  • 63 Answers
SOURCE: E 2 and service error 5100 on Pixma mp160 printer
You can try to clean out the printer check to see if there is any paper jammed in it somewhere
Then realighn the printer cartridges and run a test page.
Make sure that the paper tray is not overloaded
Posted on Dec 24, 2008
pineworks
  • 4041 Answers
SOURCE: mp140 e2
E3 – Paper jam error.
How to correct, fix: Remove the jammed paper. If paper jams frequently occur, check the following:
1. Confirm there is no foreign material inside the machine.
2. Confirm only recommended paper is installed.
3. Confirm paper is installed properly.
4. Confirm the maximum number of sheets in the auto sheet feeder is within the paper limit mark.
E4 – Empty ink tank.
How to correct, fix: An ink cartridge is empty. To cancel printing, press the <Stop/Reset> button. To continue printing, press <Black> or <Color> button. After printing completes, replace the empty ink cartridge. Printing with an empty ink cartridge may cause the machine to malfunction.
E5 – The ink cartridge(s) is not installed. The ink cartridge(s) cannot be recognized.
How to correct, fix: Make sure to install both ink cartridges even when you set the machine to use only one ink cartridge in printing. If one of the ink cartridges is missing, this error can occur.
E7 – The ink cartridge is not installed in the appropriate position.
How to correct, fix: The ink cartridge is not installed in the proper position. Install each ink cartridge in the proper position.
E8 – The ink wasteabsorber is almost full.
How to correct, fix: The waste ink absorber is getting full. Press the <Black> or <Color> button to clear the error and continue printing. Printing can continue until the waste ink absorber becomes full. If the waste ink absorber becomes full, the machine will require service. The waste ink absorber is a part inside the machine, which absorbs ink used in the cleaning operations.
E9 – A specified period of time has elapsed without receiving a response from the digital camera. A print mode compliant with PictBridge is not selected. A specified period of time has elapsed without receiving a response from the digital camera.
How to correct, fix: The machine cannot communicate with the connected camera. Disconnect the cable between the machine and the camera to clear the error. Check the following items, then try printing again.
1. Confirm that the camera you are using supports PictBridge or Canon Bubble Jet Direct. If the camera does not support either one, the machine cannot print directly from the camera.
2. Set the camera in PictBridge print mode before it is connected to the machine. This is required before printing for some cameras that support PictBridge. Please refer to the camera instructions for more information about procedures required before and after connection to the machine.
3. There may have been no response from the camera for the prescribed time. Re-connect the cable between the camera and the machine.
E14 – Ink cartridge cannot be recognized.
How to correct, fix: Unsupported ink cartridge may be installed.
E15 – Install only recommended ink cartridges.
How to correct, fix: Install only recommended ink cartridges.
E16 – The ink level cannot be correctly recognized or detected.
How to correct, fix: A used ink cartridge may be installed, or the ink cartridge is empty. Press the <Black> or <Color> button, to clear the error and continue printing without replacing the ink cartridge. However, the remaining ink amount cannot be detected properly, so the function to detect the remaining ink amount does not operate.
E19 – Scanning failed error.
How to correct, fix: Scanning a document failed. Check if the document is placed in the correct orientation position and try the operation again.
Posted on Feb 24, 2010
SOURCE: Canon MP145 Error 2
Just press the green (color) button about 5-10 seconds. Hope this help a bit.
Posted on May 03, 2010
How di I reset my Pixma printer MP150 from
Use this method with your own risk!!
E2-2 = No paper (ASF)
E3-3 = Paper jam
E4 = No ink
E5-5 = The ink cartridges are not installed or a non-supported ink cartridge is installed, or the ink cartridges are not installed properly
E8 = Waste ink absorber full, or platen waste ink absorber full
E9 The connected digital camera / video camera does not support Camera
Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature rise error
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD overcurrent error - USB
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
Reset E27 Waste ink absorber full or platen waste ink absorber full
First way
turn off printer.
- put your finger and hold on/off with reset/stop button together
- turn on printer power switch
- release on/off button but in the same time still hold stop/reset button and then press on/off button again and hold.
- wait at the moment
- relese stop/reset button 2X.( your will see alarm led blingking for 2X)
- relese on/off button.
wait until your printer digital screen shows number 0.
- after printer panel screen shows number 0.
- press reset button 4x
- press on/off button 1x
wait until your hear printer roller is moving
after your hear roller moving, wait until your dont hear anything from your printer :)
then turn off and turn on your printer again and your will see your printer back to normal.
Second Way
turn off printer.
Good Luck
Jul 18, 2010 | Canon Office Equipment & Supplies
Tip
Use this method with your own risk!! E2-2 = No paper (ASF) E3-3 = Paper jam E4 =...
E3-3 = Paper jam
E4 = No ink
Direct Printing
E22 Carriage error
E29 EEPROM error
Reset E27 Waste ink absorber full or platen waste ink absorber full for Mp140
turn off printer.
- relese stop/reset button 2X.( your will see alarm led blinking for 2X)
hopefully this can helped to solve your problems.
Thanks.
please leave your evaluation....
Extra download =====> Fix_ip1000_InkOverflow
on Jul 29, 2010 | Computers & Internet
Tip
True guide to reset ink tank absober full on canon mp140
E3-3 = Paper jam
E4 = No ink
Direct Printing
E22 Carriage error
E29 EEPROM error
turn off printer.
Ok world...Good luck
Thanks.
Extra download ====> Fix_IP1000InkOverFlow
on Jul 16, 2010 | Office Equipment & Supplies
Canon MP145 Error 2
Mar 25, 2010 | Canon Office Equipment & Supplies
When i start printer E 7 2 error messge is displaying
Probably It show 2 (two) kinds of signal or error message.E2 or E7.
just problem E2 mean no insert recording paper.
Problem solve: when show this error press color key or black key then try to feed paper this printer.
E7: when show E7 some fine cartridge are not install properly right position.
Problem solve: follow mark where install color and black cartridge.
Dec 11, 2009 | Canon PIXMA MP160 All-In-One InkJet...
I had a paper jam and got the paper out but still shows E2
E22 = Carriage error
E23 = Paper feed error
E24 = Purge unit error (bagian cleaning head)
E25 = ASF(cam) sensor error
E26 = Internal temperature rise error
E27 = ink absorber full or platen waste ink absorber full > reset dengan toolsnya
E28 = Ink cartridge temperature rise error -
E29 = EEPROM error
which error message exactly your printe show?
Sep 13, 2009 | Canon PIXMA MP160 All-In-One InkJet...
My canon M 160 jammed, I pulled paper thru, now it won't print
E2 is "NO PAPER" error but in most case it's showing when the paper feed is in incorrect position.Check it movement correctly and check for any objects drop in printer.
Jun 14, 2009 | Canon PIXMA MP160 All-In-One Printer
Canon Pixma Mp150 keeps having E2 flash
Clear the EEPROM:
How to clear Error Code Canon printers MP150 MP160
CANNON Printers MP150/MP160 ERROR CODE
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
E5-5 The ink cartridges are not installed or a non-supported ink cartridge is installed ,
E8 Waste ink absorber full, or platen waste ink absorber full
Direct Printing
E22 Carriage error
E29 EEPROM error
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset See waste ink counter reset
procedures below.
5 times Orange Destination setting See Destination setting
procedures below.
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Dec 20, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Canon mp160 E2; printer won't re-set
hi dear
may the error code or how many blinking can solve your problem
this is the list of error code
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
full
Direct Printing
E22 Carriage error
E29 EEPROM error
try this methode
Methode 1
service mode. (Waiting formenu selection)
button pressing
procedures below.
procedures below.
that's all
maybe it can fix your problem
thanks
cropp
Feb 16, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Samsung SCX-4216F feed wheel
Clean the Feed Roller In the middle of the printer. Take the paper tray out- you will see the roller in the middle. Send a print job with paper tray removed. Press the black thing to fool the printer that it has paper. You will see the feed roller move. When it is in the position you want to clean- open the toner door and it will stop moving so you can clean it. Isopropyl alcohol and LINT FREE CLOG.
Nov 07, 2007 | Samsung SCX-4216F All-In-One Laser Printer
k24674
