Question about John Refrigerators
NOPOWER TO FRIG. ALL THREE 12V GAS ELECTRIC. VERY LOW BATTERY IS IT THE PROBLEM OR CAN I LOOK FOR SOMETHING OTHER THAN LOW VOLTAGE. CAR RUNNING NO 12V. THIS IS IN MY CARAVAN. JOHN
  • John Master
  • 5,323 Answers
Fridge not starting? CLICKING? FIRST ALWAYSCHECK FORpower at the outlet,checkfor 120 volts.
MAY HAVE A BAD START RELAY OR CAPACITOR ON THE COMPRESSOR , CAN BUY A INEXSPENSIVE 3 IN 1 HARDSTART KIT AND BY PASS THEM , NOT THAT HARD TO DO, COMES WITH INSTRUCTIONS> BY THE WAY DO U HEAR ANY CLICKING SOUNDS FROM COMPRESSOR? BUT U MAY ALSO WANT TO CHECK UR COLD CONTROL THERMOSTAT IF IT GOES BAD U MAY GET A NON START ALSO HAVE IT CHECKED FOR PROPER VOLTAGE AND OHMS RESISTANCE WHEN IN THE ON POSITION
A BAD DEFROST TIMER CAN SHUT DOWN COMPRESSOR HAVE IT CHECKED WITH MULTI METER.
to check the defrost timer, u can get by and test manually by placing a small screw driver into the tiny slot or hole underneath the timer and turn slowly clockwise till u hear 1 click. this will engage ur defrost cycle in about 15 minutes u should be able to come back and feel the heat in freezer as it melts the ice providing ur terminator is not bad?
Another way to test it is with a multi meter. Remove timer it from fridge and you will see 4 prongs numbered 2,1,4,3 in that order. Place ur meter prong on prong 1 & 3 (if your fridge has a capacitor wired in series with the windings, then u check for micro fares rather than OHMS) If u cannot confirm this test, still try the next.
Take ur meter prong and connect to prong 1 & 4, it should read resistance or ohms ( closed) now remove prongs and place on prong 1 & 2, this should now read infinity or open (no ohms) now take a small screwdriver place it in the tiny hole or slot under the timer. Turn it clockwise slowly till u hear 1 click. Now ur 1& 2 should read closed ( showing ohms or resistance) now place meter prongs on 1 & 4 and you it should now show open ( or no resistance - no ohms) this is how u know ur timer is good, Remember when testing for ohms ADJUST meter to use a high ohms rating in the thousands as the resistance is very high in OHMS. And adjusting to low ohms rating may give a false reading or not show the proper resistance..
AT TIMES YOU MAY HEAR THE COMPRESSOR CLICK OFF AND ON OVER AND OVER. Signs of a bad start relay or capacitor. Check with an OHMS meter for continuity (ohms) and voltage, capacitor can be checked for Microfares.
To check ur compressor with multi meter:
Disconnect and remove the relay and capacitor from compressor, somes located next to compressor in a casing.
You wills see 3 prongs coming out of compressor. 1 goes to ur srtart winding, 1 goes to ur run winding and the center goes to ur ground.
Place ur meter connector or prong on the start prong and the other on the ground (center prong) take note of the reading in OHMS for example 5 ohms.
Next place meter prong on run prong and the center ground prong agin. Take note of the reading in OHMS. Example 4 ohms
Next place meter prong on the start prong and the other on the run prong, now take note of the reading example 9 ohms. Now match the total of this ohms test with the total of ur two separate test. 9 ohms, if they match ur ok give or take 5 percent plus or minus. One more test to make to test of there is a short in compressor attach meter prong to ground prong and rub the other end of meter prong to metal ( scrape the metal clean of paint and test on metal surface not painted surface. If it shows continuity or ohms , u have a short in ur compressor. It should show infinity
Posted on Apr 29, 2015
3 Suggested Answers
22yooper
  • 828 Answers
SOURCE: Thetford Fridge N112
There is a very likely possibility that the resistance heater for the 12 Volt side of the operation is open. This heater can be checked for continuity using an OHM meter from the terminals for the 12 volt .
Posted on Jun 02, 2008
  • 29 Answers
SOURCE: does running the frig on gas heat the element the
Yes.
Posted on Mar 20, 2010
EZGO TXT, what is the voltage I should see at the battery while engine running under load?
Around 15 + or - a little. This indicates the alternator is charging.
Oct 18, 2017 | Cars & Trucks
Engine cranks but no start
Check the fuel pump. Fuel pump relay. Car security system.
Oct 27, 2015 | 2011 Kia Forte
My 2007 toyota prius dash lights are out???
Have you checked the dimmer control, could be turned all the way down. check your owners manuel for instructions on how to turn up the lights.
Sep 06, 2014 | 2007 Toyota Prius
Can I charge ev warrior with standard battery charger?
Yes, But. 2 pack so 6volt each, I will assume standard lead acid batteries as the is common, and that is what the pic shows. depends on what you call standard charger, I would not do it with my 40 year old standard charger, although at a push, it will still charge them, but need to keep a check on them, later chargers, monitor the battery voltage, and adjust output to suit. All chargers work the same way, so basically yes, but keep a check on them, not running to hot etc. check voltage if you can. But they all work the same way, just later cells are used to the controlled cct of later chargers. especially with them being so called sealed, they still let gas escape, via a pin hole, If they get hot, to much gas, going out, reduces the effiency of the electrolyte, so will reduce the life, BUT as long as you keep checking them and stop if they get hot no problem, they will get warm anyway.
Jul 29, 2014 | UPG 12V 18AH Electric Bicycle Co EV...
2006 Honda accord ex... Wipers ... In stationary mode ( car sitting at a sroplight) the wipers are fine. Give the car gas and the wipers are on steroids banging at the up and down position like they are...
Dont think you have much wrong here ,they work ok which is the main thing ,firstly check the battery voltage then the alternator voltage ,ie engine off check the voltage which should be about 12.6 to 12.9 volts then with the running at 2500 rpm and it shouldnt read more than 14.7 volts if its greater then change the alternator regulator if battery voltage is low to start with say 12v or a bit less and with engine running it comes up then renew the battery .But if its all working and the battery voltage isnt excessive then leave well alone and save your hard earnt cash and put it towards a new car
Apr 27, 2013 | Cars & Trucks
I have a 2000 Dodge Durango 5.9l all wheel drive, 120,000 miles I have replace the alt and battery within the last week check every wire comming and going, the car will start sometimes and most of the time...
Your alternator is not recharging the battery. You need to check the connections on the alternator. You should have 12V on the "FIELD" terminal on the alternator. If not, find out why. Check for a blown ALT fuse.
Also, check the voltage on the battery when the engine is running. It should be more than 12V if the charging system is working correctly.
Oct 26, 2010 | 2000 Dodge Durango
Code PO401 is coming up on the computer and the car wont start. it also is reading 4 or 5 little sensors. It seems like its not getting any gas, but if you put carb cleaner in the port it will start up and...
It sounds like a weak fuel pump. Very common when you add fuel manualy that it gets the pump running because once the car starts you now have charging voltage of about 13.5v or more to the pump instead of 12v. Also make sure battery terminals are clean or a voltage drop could cause the pump not to prime. . The 401 code is a low flow egr code. It shouldnt have anything to do with the no start
Get the fuel pressure tested to confirm if cleaning the battery doesnt help.
Dec 27, 2009 | 2001 Ford Crown Victoria
Battery light came on car started backfiring loosing instruments and power
Check battery voltage with car off. Start car, check voltage again. Have a helper rev the engine slightly (hold RMP's around 2000). If low with car running as well (less than 12v) suspect bad alternator.
Dec 10, 2009 | 2003 Isuzu Rodeo
Electric windows and central locking wont work first thing until car has been drove for a while A4 tdi audi 2001
First check the battery voltage when the windows and door locks will not work (before driving) Will they function if you connect a battery charger? (Low battery voltage) This condition may be related to the security system (if installed) or poor electrical connection to the battery bus that is overcome when the alternator is charging.Be sure to check for 12V connection to the ECM and security Module (if installed)
You will probally need a schematic to check the wireing, Start with the 12v to the windows switches and discover where the power is missing. It will probally be common to the lock problem at some point.
Good Luck
Sep 28, 2009 | 2001 Audi A4
Thermoking
This system uses in conjunction with the transformers a rectifier which converts the High AC current voltage (220V-AC) to a Low AC current voltage (12V-AC) and then the rectifier converts that energy into the D/C current (12V DC). The two diffrent 12V power sources are controlled, operated by a "electric" relay, via a roadside or electric selector switch. DS_TK TECH
Jun 20, 2008 | Classic Minicooler Mini Cooler / Warmer...
Refrigerators Logo
63 people viewed this question
Top John Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a John Refrigerator Expert? Answer questions, earn points and help others
