Where to reattach speaker wires in back of tablet that came loose
  • 700 Answers
And there is only single tablet in the world - and it is yours...
did you try at least to use all three cells of your brain? did you read the question before you post it?
give us at least a chance to help, what manufacturer, model, what wrong, what did you try to fix it...
Posted on Apr 06, 2015
My son was playing with the speaker cube and the push button, internal springs, and clips fell out. He tried to fix it himself and pushed the button back into position. I need to get the button out a
Have your son "play" with it again, or at least have him show you what he was doing when it "fell" out, he may have stumbled on the technique, but chances are a tab has broken off meaning it should be easier to remove now. Good Luck!
Nov 22, 2014 | Bose Acoustimass 5 Series III Speaker...
There was a boken wire inside of the Tablet when we opened it. I closed up my Tablet and the ony way to get it to come on was to plug in the adapter. What do I do now to get my Tablet fixed/?
can u take pic of the inside for me? Alot of the time ribbins connections or ports and yes wires come loose. But wires rarely break inside the case. They can come loose due to bad sodering.
Most of these tablets have a speaker wire with is sodered to the speaker on back of housing and even I have pulled the loose on cases that wont pop off the tabs. Post a pic for me and ill look and see what where and maybe how to go from there..
Goodluck
Chad man
Dec 20, 2013 | Coby Kyros 716829701508 Tablet PC
I have a life size jason voorhees and he works fine except the sound is really bad and has a lot of static over it. I have tried removing the head and reattaching it several times but that did not work,...
Sir try to check the speaker cone if damage, because damage cone speaker produces unnecessary sound. And check all wire connectors if loosed. Good day and best regards.
Sep 11, 2011 | Gemmy 6 Life Size Jason Voorhees
My Clarion AM/FM,CDMP3,marine radio will play when...
    I had the same issue with a blown speaker that was shorting it
    self out. I found this on "TeamClarion.com" site.
    Step 1: Disconnect all the speakers from the head unit and try again. If the same message comes up, send the unit in for service.
    Step 2: If the message goes away, you have a wiring problem. Check each speaker lead for a short circuit, damaged speaker or a ground to chassis.
    Basically means one set (or more) of the speaker leads are touching each other (shorting out). This can be somewhere inline to your speakers or your speakers them selves. The advise above isn't to clear. In the first step they want to rule out the speakers attached but "disonnecting all the speakers" is vague. You should disconnect at the rear of the radio. This might be difficult because the multi plug in the back has the speakers and power wires together (at least most clarions). Also if it was a good install then the outgoing speaker wires were soldered to the long run speaker wires going to the speakers.
    To truly test for radio fault verses the wiring or speakers, you have to sever the connection at the back of the radio. If this is not something you wish to do then there is one suggestion. Order a new multi plug for the back of the radio. This way you can pull the old plug and test it with a new plug with no speakers attached (just have to run 12v positive and negative).
    If the radio is OK then start by checking all the wires to your speakers (if possible). If nothing seems bare and shorting (remember it's usually in tight places or were the wires are hanging loose that vibration will cause cutting to the wire) then disconnect all your speakers (at the rear of the speakers). Turn the radio back on and see if it does the error message again. If not reattach the speakers one by one checking for the error message.
    You can check these in any order. If you don’t want to order a new plug then you and can’t get to much of the wiring to physically check then starting at the speakers is OK.
May 20, 2010 | Clarion CX609 Car CD/ MP3 Player
Amp guard on stereo?
    I found this simple message on "TeamClarion" site when I had an "amp gaurd" issue.
    Step 1: Disconnect all the speakers2_bing.gif from the head unit and try again. If the same message comes up, send the unit in for service.
    If the radio is OK then start by checking all the wires to your speakers (if possible). If nothing seems bare and shorting (remember it's usually in tight places or were the wires are hanging loose that vibration will cause cutting to the wire) then disconnect all your speakers (at the rear of the speakers). Turn the radio back on and see if it does the error message2_bing.gif again. If not reattach the speakers one by one checking for the error message.
Mar 04, 2010 | Clarion CX609 Car CD/ MP3 Player
I am a regular Dell customer. Received Altec Lansing ADA745 Speakers with my Dell Computer. The cable from "right front" speaker has a broken wire or loose connection in the plug.It isthe "power connection...
Yes thats real easy. You could get a replacement plug, cut the "Old" end off, and reattach the new one, a little bit of soldering will be needed. Usually the Center pin is Plus, Positive, the Outer is Negative. Or take it to a friendly local serviceman and he'll be able to do it for you for a small. free? fee.
Feb 11, 2010 | Audio Players & Recorders
Tomtom one 3rd edition, sound not working
My had the same problem after dropped on the stair. I did the reset but no help. Here what I did: uncrewed 4 torx crews and pop out the back cover slowly. remover speaker's wire connector and check speaker resistance 3-4 ohm. reattach connector firmly and did a speaker test in volume preferences menue. Mine works just fine after this attemp. In my case is a loose connection. The battery and speaker can be change as necessary.
Jun 28, 2009 | Tomtom ONE 3rd Edition GPS
Sound
I just fixed mine. No ring or external sounds following a short drop. Found a loose internal header on the back, right side of the phone.
Remove back.
Remove battery.
Remove SIM.
Remove 4 screws (note will void warranty)
Starting from top, carefully de-attach rear plastic cover.
Inspect. Header on right side as you look at the back of the phone has black/white wire going to speaker.
Reattach.
Re-install in reverse order.
Crazy phone still works great!
R
Apr 07, 2009 | Cingular Wireless Cingular 8525 Smartphone
Brother tripped over speaker cord
open up tthe speaker case and resoulder the leads/unless the wires pulled loose from the speaker face on the back of the speakers that should fix the problem,if the wires are pulled loose from the speaker face then reattach them with a drop of craze glue and a small drop of silicone sealer which should do the trick!
Jun 02, 2008 | Logitech Z-2300 2.1 Computer Speaker...
124 people viewed this question
 Grubhead
Grubhead
