Question about John Deere Garden
I have a john deere L130 mower. I need to know how to take the gear off the bottom of the steering shaft. I have taken the nut off but it won't budge.
  • John Deere Master
  • 1,169 Answers
It may take a bearing separator to remove it as it may have fused to the shaft over the years.
Posted on Apr 06, 2015
    Sergeant:
  • John Deere Expert
  • 187 Answers
  • I have broken them loose by "popping" the steering wheel up.
  • Another way is to put the nut back on about 1/2 way, have someone hold the steering wheel up (firmly) then smack the nut from the bottom and drive the shaft upwards.
  • A third way. Again, have someone firmly hold the steering wheel as high up as possible. Then hammer a punch against the bottom end of the steering shaft.
  • 86 Answers
SOURCE: John Deere riding mower SRX95 - Steering wheel is sticking
You need to replace your Ball Joints! On the front steering rods There are two sometimes three !
Posted on May 09, 2009
wireguy212
  • 1627 Answers
SOURCE: Need wiring schematic diagram for JD L130 lawn
You should price a new wiring harness,around $80 so there is not much reason to spend a lot of time trying to find shorts or open wiring.
Posted on Apr 18, 2010
6ylucy
  • 742 Answers
SOURCE: manual for john deere sx95
ask manualfox.com - they have it.
Posted on Apr 19, 2010
SOURCE: John Deere 185 deck height adjustment
having a problem with dive belt being hit by the mower deck 185 john deere suggestions !!
Posted on Jul 16, 2010
SOURCE: My John Deere L130 riding mower quits after it has been running
A John Deere repair guy showed me how to fix this. It is very simple. Remove the gas cap. Pop out the liner in the gas cap with a thin pocket knife. Clean out the cap. From the top of the cap, where it comes to a peak, take a very fine point (even a small knife blade will do) and make sure the little hole in the top (that you didn't know was there) is clear. The engine is starving because the gas tank is not properly vented. I suffered with this problem for two years until he came to sharpen my blades and I asked him about this. A two minute, free fix did it and I have never had problems again.
Posted on Jul 04, 2012
How do you get the gear at the end of the steering shaft off to replace it on a John Deere la175 lawn tractor?
It's a lock nut. But you should have no trouble removing it. Just hold the steering wheel, or turn it all the way to one side. But a socket on the nut below the gear and ratchet it off. That's all there is too it.
Mar 29, 2015 | John Deere Garden
How do you remove the gear at the end of shaft to place for it? John Deere LA175
It's a lock nut, but you should have no trouble removing it. Just hold the steering wheel, or turn it all the way to one side. Put a socket on the nut below the gear and ratchet it off. That's all there is too it.
I have a John Derre L130 and the left steering arm has lots of play any suggestions?
it has a steering wheel not steer arms... your issue is either something is bent/broken, the steering shaft is stripped or the steering wheel is just off
Aug 29, 2014 | John Deere Garden
Rebuild steering on john deere L120
Hi there, I am not familliar with the L120 specifically, and suggest that you go to: "John Deere Lawn Mower Manuals" online and select your model from there. In my experience with this type of unit there are two ways that the pressed gear on the end of the shaft is fitted.. Real engineers make a ferrule, usually about twice the diameter of the steering shaft, and have either a tapered end with a threadded end for a nut which often has a split pin thru the thread like a trailer wheel bearing, and a key in the shaft and taper. Machines made with a lesser labour input often have a fixed pinion which means replacing both the shaft and the pinion. If it is the tapered end with a nut, they are often very tight and cannot be removed while mounted in the machine. They may require a sharp heat and severe blow with a good hammer. I do not recommend that you do this if you are not competent as the blow to the nut can do much damage if not hit square with a cushion of copper between the hammer and nut. The fact that you do not know how to do this job probably means that it is cost effective to employ a shop which does this type of work.
Aug 19, 2014 | John Deere L100 Series
John deere l130
There's a gear on the end of the steering column that's broken or the roll pin used to hold it on is sheared.
Jul 18, 2013 | Garden
My L130 will not turn right.
you will need to change the steering gear , and the steering pinion and its not a bad idea to change the gear pivots (2) and also the bottom steering wheel shaft bushing. they sell a complete kit on ebay that has it all in one nice n tidy kit.> http://www.ebay.com/itm/JOHN-DEERE-STEERING-GEAR-REPAIR-KIT-102-135-LA120-LA155-/261112192757?pt=LH_DefaultDomain_0&hash=item3ccb7fdef5
dont let the high price full you, just the pinion $40 and the steering gear $32 is $72 and you get both and the $10 bushings x2 plus for the same price!!
Apr 24, 2012 | John Deere 22HP VTwin 48" Riding Mower
Steering Wheel will turn when mowing. Trying to get steering wheel off as given in the John Deer Manual, but steering wheel frozen and won't budge. What else can be done to remove the steering wheel...
If you have the main nut removed, you can give the steering shaft a few shots of penetrating oil like Liquid Wrench or PB Blaster (available at auto parts stores). After lubing, let it soak at least a few hours. 24 is good. You may have to get one of those cheap "gear pullers" from like the Harbor Freight store to finally pull it off though.
Aug 13, 2011 | John Deere Garden
Steering not good. are gear parts available for this old mower?
Yes the steering parts are still available from John Deere. I had just repaired one myself.
Steering Shaft AM101937
Steering Gear AM36998
Bottom Bushing M47067
Jun 12, 2011 | John Deere Gx75 Rx75 Srx75 Sx75 130 9hp...
John deere 68 riding mower steering column won't turn wheel assembly via arced toothed plate. Wheel assembly OK and greased. Some minor play when rotating steering column with steering wheel, but appears...
Just had same problem with my craftsmen. There is a very inadequate little nylon bushing supposed to keep that shaft stable. When worn out it allows that shaft to move and puts the gears in a bind. It is located on the end closest to arced gear where shaft hooks to drag link. Its a pain.
Sep 27, 2010 | John Deere Garden
Garden Logo
248 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
