Question about Lexmark X5470 All-In-One InkJet Printer
Computer start-up My Dell desktop will not start up with the USB cable for the printer being disconnected from the computer. What is causing this?
  • 1 more comment
  • marty 70 Nov 14, 2007
    typing error in original message. Should read " will not start up with the USB cable connected to the computer
  • Anonymous Dec 29, 2007
    I have the same problem and I just keep the printer USB disconnected until I start the computer. All else works fine
  • Anonymous Sep 09, 2008
    Exactly the same problem - worked fine till recently then suddenly developed this fault - I just unplug the printer before re-booting otherwise the pc freezes on the motherboard screen and I have to turn it off at the mains and start again. I'll try checking the bios setup and see if I can rectify the problem there. Lexmark tech help say this is a usb grounding problem but I don't have this problem with other usb connected hardware.
  • 29 Answers
Fiend your solution direct from Lexmark. Here is your solution
Posted on Mar 03, 2009
  • 3 Answers
I have been using the Lexmark X4570 all in one printer with desktop pc & windows xp professional and the same problem developed (had to disconnect printer usb cable to boot up). I removed the bios options to boot from removable drives and also disabled the A (floppy) drive (I don't have one). The pc now boots up with the printer connected but still continues to freeze on the Asus motherboard screen if I leave a memory card in the printer's card reader. I suppose this is only half a solution but maybe someone out there has some other ideas. I don't have this problem if I leave other usb devices plugged in (eg keyboard, portable hard drives, camera etc.)
Posted on Sep 09, 2008
  • 1,601 Answers
Disable booting from USB in the BIOS or check your BIOS manufacturer for an update. Some PCs attempt to boot from the card reader in the lexmark printer causing the problem.
Or just connect the printers USB cable after booting your computer.
A friend has a 2.0 Usb port next to him and connects it there after boot.
Attention Windows Vista Users
If you have installed your printer on your PC using an original Lexmark Driver CD that came with your product and you are experiencing problems when printing, you may have installed the Windows XP driver.
Follow these steps to resolve:
· Disconnect your USB cable from your printer.
· Uninstall all Lexmark printer drivers on your PC.
· Download the correct Vista driver for your model.
· Install the driver on your PC.
Important - Do not reconnect the USB cable until the install software prompts the question of how the printer is connected.
Also, You do have the new VISTA software for your Lexmark, right.
Posted on Nov 14, 2007
Dell xps 420 computer will no start blinking amber light no diagnostics lights working
If the power light is blinking amber, the computer is receiving electrical power, but an internal power problem might exist.
Ensure that the voltage selection switch is set to match the AC power at your location, if applicable.
Ensure that the processor power cable is securely connected to the system board.
This can be caused bya defective power supply or a defective motherboard. Just to make sure thatnothing else is causing the problem, remove any PCI cards like modem, videocard, sound card, etc... Remove the memory modules and disconnect cables toCD/DVD drives. Look at the USB ports to see if any are damaged.
Jul 25, 2011 | Dell XPS 420 PC Desktop
I somehow uninstalled the Dell Imaging Toolbox for my V305 printer. How do I get it back?
I cannot find a separate software download for the Imaging Toolbox. I can only assume it comes with the driver itself when installed.
If you have the disk for the printer, uninstall the printer software you have already installed using the Add/Remove Programs from the Control Panel. Restart your computer and look under the Start>Printers and Faxes and make sure it is not listed.
disconnect the USB cable from either the computer or printer and insert your disk and install as you did originally. Connect the USB cable when prompted.This should reinstall the driver and Imaging Toolbox.
If you do not have the disk, you can download the software from the Dell website at:
Dell V305/305w Driver
Download the software to your desktop. Uninstall the previous software...reboot...then double-click the file on your desktop.
Hope this helps. If you have further questions, just use the Comment link.
Thanks for using Fixya.
Dec 11, 2010 | Dell V305w All-In-One R840635AU InkJet...
When I try to scan or print a message comes up telling me to ck power and usb connections. I have unplugged and restarted computer 4 times and still have problem
It could be a communications error message, the printer is not communicating with the computer.
  • Disconnect and then reconnect the USB cable.
  • Disconnect and then reconnect the printer power cable.
  • Restart the computer.
  • Remove and reinstall the printer software
  • If your printer does not function properly or communication error messages appear when using your printer, you can remove and reinstall the printer software.
    1. Click Start®Programs or All Programs®Dell Printers®Dell Photo AIO Printer 962®Uninstall Dell Photo AIO Printer 962.
    2. Follow the instructions on the computer screen to remove the printer software.
    3. Restart your computer before installing the software again.
    4. Insert the Drivers and Utilities CD, and then follow the instructions on the computer screen to install the software.
    If the installation screen does not appear:
      1. In Windows XP, click Start®My Computer.
    In Windows 2000, double-click My Computer from your desktop.
      1. Double-click the CD-ROM drive icon. If necessary, double-click setup.exe.
      2. When the printer software installation screen appears, click Install or Install Now.
      3. Follow the instructions on your screen to complete the installation.
    Communications error message
    The printer is not communicating with the computer.
    Dec 06, 2010 | Dell 962 Photo All-In-One InkJet Printer
    When printer connected to pc is showing usb device not recgnised in windows xp
    two things to try
    1. try using another usb port ( preferably one on the back of the pc)
    2. switch out usb cable with another
    Sep 24, 2010 | Office Equipment & Supplies
    Dell 946 printer has been working for over 2 yrs with Dell computer. Today computer says can not communicate with printer. Will not print from any program. Ran thru trouble shooting, disconnecting USB...
    reinstall the printer driver and check the printer spooler started or not........... to start print spooler go to start...>run..then type services,msc then enter..>it will open a window....>open printer spooler service and restart it.....................
    Nov 02, 2009 | Lexmark X6170 All-In-One InkJet Printer
    I can print from my Dell 926 all in one, but it wont scan
    Try removing your 926 icon in Printers and Faxes, disconnect the USB cable, restart your computer, reconnect the USB cable, see the 926 and install the driver again. If scan has never worked, you probably need a different driver.
    Hope this helps.
    Aug 06, 2009 | Dell 926 All-In-One InkJet Printer
    Power off the printer and disconnect the USB (Parallel ?) cable from the printer to the PC. Reconnect the cable. Restart your PC.
    If that doesn't work ... go to Start - Printers and Faxes and delete the Dell Photo 926 icon. Then, power off the printer and disconnect the cable from the PC. Power on the PC and log in. Reconnect the cable and see if the printer is found. If so, install the Photo 926 printer driver. If the printer is not found, you have a printer cable or printer hardware problem. Good luck.
    Jun 11, 2009 | Dell 926 All-In-One InkJet Printer
    I am trying to hook up to a hp laserjet printer to the computer
    disconnect the printer from your omputer (the cable i.e; parapllel, usb, CAT-5).
    trun off the printer.
    unisntall the printer software from your computer
    restart the computer
    reinstall the pirnter software.(don't connect the printer).
    restart the computer again
    connect the printer, turn on the printer
    configure the printer from start>>printer and faxes.
    Jan 13, 2009 | Dell Dimension 9200 PC Desktop
    Computer won't recognize printer
    We know it isn't the printer or the USB cable. We know it isn't the software. You are running Windows XP on both the desktop and laptop, correct? On your desktop, you go to 'Start''Settings''Printers' and is the printer there ?? Try this; go to 'Start' 'Settings''Control Panel'. Double click the 'System' icon. Click on tab 'Hardware', click on 'Device Manager'. Do you see a yellow (!) on any Universal Serial Bus Controller. If not, were good. Check all USB ports with a USB mouse or device to make sure they're active.
    Jul 03, 2007 | Lexmark X4270 All-In-One InkJet Printer
    Lexmark X5470 All-In-One InkJet Printer Logo
    191 people viewed this question
    Top Lexmark Office Equipment & Supplies Experts
    Don  Farrell
    Don Farrell
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
