Question about Toshiba REGZA 42WLG66 42 in. HD-Ready LCD Television
What do I do when screen stays black? The only thing working is the red light under the Timer Rec sign on the front of the TV.
    Top Expert:
  • Toshiba Master
  • 74,118 Answers
Sounds like main board fault. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Posted on Apr 06, 2015
Trying to replace lamp in HDTV and having trouble. Does not function correctly after putting in new bulb. Boots up and then visuals go black and the green power light keeps flashing. Help?
Panasonic DLP TV Bulbs
Make sure its an original Osram or Philips bulb inside the housing. If its a cheap lamp it will act this way. If it is an original lamp, then you may have a power supply issue. It shouldn't affect your TV but you may want to try resetting the lamp timer by following the instructions that came with the lamp.
TY-LA1001 Timer reset
While pressing the VOL- button on the projection display, hold down the number 0 button on the remote control at the same time for more than 5 seconds.
Aug 15, 2015 | Panasonic Pt-52lcx16 Projection Television
LG 32cs460-us TV black screen red light blinks 3 times
I can give you some advice on the first thing you need to try. Unplug the tv for 10 minutes. Plug the tv back into the wall or power strip. Try powering on the tv. This may work or may not. It is important to try this before moving on to more complicated troubleshooting.
Jan 20, 2014 | LG 32CS460
Tv comes on with sound no picture,timer light stays on for about 20secs,then lamp light comes on stays on as tv shuts down,we are stomped,cant fix prob with no screen.
The first question i need to ask is Have you removed the bulb to check to see if it has blown. If there is no visable signs that it is bad then replace it and make sure the door is secure. Secound thing you can do is retrieve the error codes. To do this press and hold MENU and INPUT button on the front of set. The timer light will flash then pause then flash again denoteing a 2 digit code. this will maybe point the way to possible problem
Apr 22, 2011 | Mitsubishi WD-60735 Projection Television
Red LED lights
power supply shot ... sometimes x board or y board
Oct 02, 2009 | Pioneer PureVision PDP-5030HD 50 in....
TV acts like it is turning on then shuts off then repeat, repeat
When my lamp died the bulb literally exploded. That may be what you heard. Have you check the lamp? If the lamp is ok, the lamp's ballast or power supply might have blown.
May 22, 2009 | Toshiba 62HM95 62" DLP HDTV
The tv skeen stays black but the red light stays on . is my tube blowned out and needs replaced .idon't know can you tell me ?
If the screen is black but on, as opposed to black because it is off, check to see if your timer is set to turn the tv off.
Mar 08, 2009 | JVC AV-32050 32" TV
Black screen and red timer light is on
It may be the problem of the Dish connection or stablizer. Remove the stablizer and connect the Tv direct to switch board and re connect the dish connection. Then switch on the TV it will work.
Nov 04, 2008 | Samsung HCM4215W 42" Rear Projection...
Returns to standby
Green flashing 3 times = digital DC - DC converter fault
Red flashing 3 times = scan circuit fault
Oct 31, 2007 | Pioneer PureVision PDP-5040HD 50 in....
Toshiba REGZA 42WLG66 42 in. HD-Ready LCD Television Logo
82 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
