Question about Cannon Office Equipment & Supplies
Continue to check ink uo52 error message after installing new cannon cartridge
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 142 Answers
Hold down clear/stop and start 15 sec.
Posted on Oct 19, 2015
tutopian
  • 57 Answers
SOURCE: Wrong Cartridge Error Message
The Print Head might be the fault of that,try replacing the print head and see if that helps
Posted on Nov 27, 2007
SOURCE: Cannon Pixma 160 - How do I reset the ink level indicator
crapt the driver
Posted on Oct 21, 2008
manuel-d
  • 5 Answers
SOURCE: Canon Pixma ip1900 Printer wont print
i think you need a canon resetter just download it and it will fix your problem. gud luck ellyhill
Posted on Nov 16, 2009
SOURCE: replacing an ink cartridge in my MP600 and error
take off all the cartridges, turn off the printer...
turn on the printer and put inside 1 by 1 the cartridge, if the problem don't chances buy another printhead..
Posted on Apr 21, 2010
U162 error on black ink cannon printer
This error occurs when printer fails detecting ink level or printer assume that no ink in the cartridge. We cannot use print, copy,scan, and fax function before the problem fixed. It's recommended for you to replace ink cartridge. To continue using the printer without replacing the cartridge we must deactivate ink level detection function. Be aware that printing in this condition can damage the printer while sending fax or scan is not problem.
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Original source: http://ij-forum.blogspot.com/2008/12/error-message-check-ink-u162u163.html#ixzz2Cpr4Be1K
Nov 20, 2012 | Canon PIXMA MX340 Wireless Office...
Have error message UO52 print head is incorrect, have installed correct ink cartridges what do I do ?
It could in fact be a defective print head problem but try cleaning it first:
(1) Open the printer
(2) Remove the ink cartridges from the print head.
(3) Use cotton swabs dipped in hot water to thoroughly clean the print head.
(4) Repeat this until there is no ink residue coming off on the cotton swab.
(5) Once finished, allow to dry and replace the cartridges
(6) Try to print something now
Jul 07, 2011 | Canon PIXMA MP810 All-In-One InkJet...
I have installed 2 new inks and still get a message asking me -- install new ink cartridges to continue .. I purchased these new inks 2 hours ago.
Install the cartridge by following the steps given in this link.
If the problem persists you will need to reset the printer.
Follow these steps to reset the printer:-
  1. Without turning the power off, remove the power cord from the back of the printer and from the wall socket.
  2. Wait 30 seconds and reconnect the power cord to the printer and to the wall socket. Turn the unit on if it is not already turned on.
  3. Check the printer for the error message. If the error message continues, go to the next step.
Also, Don't forget to remove nozzle protective tape from the cartridge using the pink pull-tab.
Do not touch the copper contacts or the ink nozzles
Good Luck and have a nice day.
Jun 09, 2010 | HP Photosmart D7460 Printer
Error e then 7 flashes in window
I dont know why Cannon persist wuth there stupid messages by morse code,
E 7 means that a sensor has detected an incorrect ink cartridge
Options to fix
1.Check the ink cartridges are correctly installed
2. If you have recently replaced an ink cartridge with one from a supplier other than Cannon feplace the cartridge with a Cannon branded prosduct
3. If everything looks ok then try powering down the printer, unplug wait 2 minutes for all residual power to drain, then power up to see if the printer has resolved the problem, this just resets the sensor which reports the error but it often works as the sensors are the most likely part to give intermitten faults
Sep 25, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Error inkcartridge
Error message: No color or black ink cartridge-->Press the Color Copy button to install a new ink cartridge.
Solution: The indicated ink cartridge is not installed. Please install the necessary cartridge(s).
Error message: Color or black ink out -- >Press the Color Copy button to begin replacing the ink cartridge.
Solution: The indicated ink cartridge is out of ink. You will need to replace the necessary ink cartridge(s).
Error Message: Ink cartridge error -- > Press the Color Copy button to begin replacing the ink cartridge.
Solution: There is something wrong with the ink cartridge. Make sure the cartridge is genuine Epson ink. Also, try reseating the cartridge (remove it, and then reinstall it).
Error Message: Paper jam or misfeed -- > Press the Color Copy button and clear the paper jam by hand if necessary.
Solution: Paper is jammed. Check for any obstructions under the unit's cover, and in the paper tray.
Error Message: Paper out -- > Load paper in the sheet feeder and press the Color Copy button.
Solution: Load paper in the sheet feeder, and then press the Color Copy button to continue printing.
Error Message: Scanner unit open -- > close the scanner unit
Solution: Carefully close the scanner and press it down until it clicks securely into place.
Error Message: Scanner error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Unlock the transportation lock, if necessary. If it is already unlocked, toggle the lock back and forth, 5-10 times. Turn on your Stylus CX3200 again.
Error Message: Printer error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Disconnect it from power, and then reconnect it to power. Press the ON button to turn on the Stylus CX3200
Nov 28, 2008 | Epson Stylus CX3200 All-In-One InkJet...
My cannon printer pixma ip1800 cannot detect ink pls help me...
If after you install the cartridge you get a yellow light and error message:
“The following may have run out of color. The function for
detecting the remaining ink level will be disabled since the
ink level cannot be correctly detected. If you want to
continue printing with out this function, press the printer’s
start button. Canon recommends using new genuine Canon
cartridges in order to obtain optimum quality.”
Do not click “cancel printing”. Press printer start button
to start printing. This action will bypass the ink level
detection from the recycled cartridge. It will not damage the
printer! With a recycled cartridge this action needs to be
done one time.
A full recycled cartridge ink level may not display correctly.
It may show empty.
If you want to check the ink level, you can do a “Nozzle
check” by follow the directions below:
Go to menu File select print click on “Property” click
on “Maintenance”
Click on “Nozzle check” to print out the color check.
Click on “Cartridge Alignment” to align the cartridge.
See pictures for above process at Inktelligent ip 1800 topic
Also the refills refered to above are at the IP 1800 inkfilling page
Sep 23, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
I have same problem.Please let me know if u find an anser
Feb 10, 2008 | Canon MultiPASS F50 All-In-One InkJet...
MultiPASS F50
check the Canon Knowledge base at www.canontechsupport.com, it may be the printhead or unit itself.
Oct 23, 2007 | Canon MultiPASS F50 All-In-One InkJet...
Jan 31, 2007 | Canon MultiPASS F50 All-In-One InkJet...
47 people viewed this question
Top Cannon Office Equipment & Supplies Experts
Cosma Papouis
Cosma Papouis
Greg Cann
Greg Cann
Iqbal Husain
Iqbal Husain
Are you a Cannon Office Equipment and Supply Expert? Answer questions, earn points and help others
