Dose my tv have a reset button - Televison & Video
    Top Expert:
  • Televison & ... Master
  • 74,634 Answers
There is no external button, marked as Reset; to modern TVs. If you wish to reset the modern TVs to its factory settings, you have to enter its service mode option, and to select the Reset function, and to press the OK button.
There are two types of reset to TVs. The first is simple to do; a Hard Reset; and the other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight; will be better. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Posted on Apr 06, 2015
  • 2,833 Answers
If you tell us the make and model we might be able to tell you. Otherwise we'd be guessing.
Why dose my sharp aquos lc-40d78un power on then turns right back off
No reset button. Probably a problem with the internal power supply.
Jun 09, 2014 | Sharp LC40D78UN 40 in LCD TV
Wrong resolution on smart tv- cvd601
I made the mistake of selecting the largest of the resolution settings of 1920x1080-50Hz. The CVD601 DOES NOT HAVE A RESET BUTTON! You have to do all your business on screen. So to regain my setting of 1280x720-60Hz, I disconnected from my TV and hooked up to my computer monitor. At that point, I got my picture back and went to settings. Upon restoring the settings in TV Screen Resolution to: 1280x720-60Hz just click and exit. In the US everything is based on the 60Hz cycle. Hence the hickup when you pick anything in the 50Hz cycle. I hope this helps!
Jan 08, 2014 | Craig Electronics Craig Smart TV HDMI...
Reset button
There is no such button to this set. To make it a system reset, you should enter its service mode option. To get more details, http://electronicshelponline.blogspot.com/
Nov 28, 2013 | Philips 42PFL5603D/27 42 in. LCD TV
Hisense tv input stuck
hi take the leads out that you have on the vidio as the tv is wating for you to plug your camra back in if this dose not work threr shoud by a reset button on the back some were thank you
May 19, 2013 | Televison & Video
The volume control on my sercive electric remote dose not work but everything else dose why?
you need to program the tv code into the remote. then the volume will work the tv volume.
Jan 19, 2013 | Televison & Video
Why does the playstion 3 dose not work on standard tv
Have you tried holding down the power button for 5 seconds to revert back to standard definition?
Jul 23, 2010 | Sony Playstation 3 (PS3) Console
Why dose my tv guide not work anymore?
This will probably be down to some software issue, try getting into the service menu and reset to factory, google for service menu
Mar 05, 2010 | Sony Bravia KDL-46Z4100 46 in. LCD HDTV
I locked my panasonic tv and for got the code
Hold the menu button on the remote & the volume down button on the tv simultaneously for 7 to 10 seconds. The tv is reset to original manufacturer settings.
May 26, 2009 | Panasonic Viera TH-50PX80U Plasma TV
I have just been given a Samsung sp42w4hb back projector TV that has a problem,after about 4 power cuts in the area the TV went off and only the standby light comes on,it stays on for about 10/15 seconds...
check to see if you have a loose conection at the relay or at the power source a lot of times the relay goes bad and you can solder a neew one in get a service manual to locate relay and parts
Jan 21, 2009 | Samsung Televison & Video
Tv has a mind of its own
Just had the TV repaired for the same issue. According to the shop it was a bad channel up/down switch. That impacted the other functions (menu not working, remote malfunction) because they're all intertwined. Only about a $75 fix here in the DC area, so maybe cheaper elsewhere.
Sep 02, 2006 | Sony FD Trinitron WEGA KV-20FS100 20" TV
Televison & Video Logo
61 people viewed this question
Top Televison & Video Experts
Electro Med Services...
