Question about Hitachi Saws
I have a Hitachi c 10FS sliding compound mitre saw that won't spin. I can hear the motor trying to go but no action. Could it be the brake? Ceased berring?
    Sergeant:
  • 206 Answers
The brake is incorporated into the motor field - highly unlikely to be the problem.
If the motor is turning but the blade is not then I would be looking at the belt or possible stripped gear at the arbor.
If the motor hums or does not turn it most likely is the front armature bearing.
The C10FS is not an easy tool to service - the entire thing has to be torn down to get to the bearing, I would recommend bringing it to a reputable shop in your area.
Posted on Apr 07, 2015
  • Hitachi Master
  • 2,825 Answers
The brake is likely electric, and not engaged when unplugged. Unplug your saw, and see if you can turn the blade. if not, then either of your other ideas is plausible.
Posted on Apr 06, 2015
  • 5 Answers
SOURCE: 10in sliding compound mitre saw
turn the bevel lock to counter clockwise
Posted on May 29, 2008
thabrain
  • 76 Answers
SOURCE: How to replace lockdown pin DW708 12" sliding compound mitre saw
you are going to have to drill the inside pin out. be sure to center punch and drill a pilot hole. hope this helps
Posted on Oct 28, 2008
SOURCE: ryobi compound mitre saw sliding 10
rotating the laser in its' housing moves it left and right. The hexagonal bolt on the sides needs to be loosened to do this, then it can also be adjusted up and down. Make sure the trigger to the saw is locked before doing this.
Posted on May 08, 2009
rowdy45176
  • 2176 Answers
SOURCE: Compound Mitre Saw Motor turning, spindle isnt.
I have went to 3 different sites and cannot find the model number listed on them, I did look at a Ryobi saw and they indicate it is an assembly. but before I did that I would try and removing the gear from the spindle. It is possible that when it spun it put a burr in the parts and you would have to use a little extra effort to remove them I would suggest going to a repair shop and having them press them apart and see what you canfind that way. Sorry I couldn't find more for you
Posted on Aug 21, 2009
  • 8404 Answers
SOURCE: Compound mitre saw won't shut off unlss unplugged
Relace the switch.
I am presuming the lock button has not been inadvertently pressed ... Check that first.
The condition you deacrive is dangerous. Please fix it before you use it any more.
If you require additional assistance, let me know.
Otherwise, check RepairClonic.com for parts and technnical instruction from their crack crew.
Thanks for the opportunity to lend you a hand
a
Posted on Sep 26, 2009
Power is going to the motor on my dewalt 12 mitre saw but the motor is not spinning
Does the saw make any noise? If not it could be an open circuit in the field coils
Feb 22, 2014 | Dewalt Heavy - Duty 12" Double - Bevel...
Stop spinning
Check brushes making contact with armature, ensure switch operates correctly & carry out continuity check of field coils.
Feb 22, 2014 | Dewalt Miter Saws 12" Double Bevel...
Skil 3316 Compound Mitre Saw 10"
I suspect that the brushes have fallen out between the end bearing and the armature bars.. Try removing the brushes and see what happens.
May 18, 2013 | Skil 10-in 15-Amp Compound Miter Saw...
I have the old model c10fsb mitre saw but need to replace the two parts of the handle & the trigger,where would i get them ?
You can go to www.toolpartsdirect.com and search by brand name than tool description by model number then view a schematic to get part numbers. You can also call direct at 1-866-597-3850.I hope this helps you. Good luck and thank you.
Mar 14, 2011 | Hitachi C10FSB 10" Sliding Dual Compound...
I casnt remove the centre nut from my c8fse chop saw
Hi, when I do this I insert a large screw driver into the blade saw to stop the blade turning, as you will need to turn the nut clockwise.
Aug 01, 2010 | Hitachi C8Fse Sliding Compound Mitre Saw...
I have just gotten my Hitachi 10'' compound mitre saw (C10FCE2) out of the box, and have disengaged the packing pin, and put on the stabilizion bar and handle. I can not seem to get the blade to tilt back...
the hndle at the front is for your mitre. there should be one at rear of tool to bevel (COMPOUND) IT SHOULD HAVE A HANDLE AS WELL possibly left hand thread !
Jan 04, 2010 | Hitachi C10FCE2 10" Compound Miter Saw
I lost my manual and need to adjust the bevel settings
Make sure its a compound mitre and not just a mitre saw. The check in the back for a round knob with degrees marks on it, theres your adjuster.
Sep 24, 2009 | Dewalt 12" Beveling Sliding Compound Miter...
Jul 30, 2009 | Ryobi Saws
Need a detailed schematic for handle of a hitachi C10FC mitre saw
I would go to Ereplacementparts.com and type in your exact model number (there are about 5 saws) and they you can download a schematic of your tool. Hope this helps.
Dec 30, 2008 | Hitachi C10FCE2 10" Compound Miter Saw
Saws Logo
212 people viewed this question
Top Hitachi Saws Experts
John Trevino
JOHN LAPIER
Are you a Hitachi Saw Expert? Answer questions, earn points and help others
