Question about Toshiba Televison & Video
When i turn on my toshiba CT-90314 had sound but a very dark picture. it flickers on for a second then goes
My original tv remote has broken so i purchased another off ebay!
    Top Expert:
  • Toshiba Master
  • 74,858 Answers
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
In some models of LCD TVS; the backlight inverter and its T'Con board will be a part of the panel itself, and will be a built-in type inside the LCD panel. If so, they can't be replaced. In this case; a panel replacement is the only repair. For some other models, the backlight inverter section circuit will be a part of the main power supply regulator [SMPS]. To such sets, the power supply section circuit too should troubles shoot. Contact any service technician. The circuit will differ with models and versions.
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Posted on Apr 06, 2015
Testimonial: "that great thankyou i will have a go!"
I bought a replacement remote for Toshiba TV and it was the same model number CT-90325 same as the original. but it won't operate the TV, does it have to be programmed to the TV somehow?
Sounds like the manufacturer did an upgrade. You can look up the remote control codes for that TV. Turn the TV power on. Then using the codes you found set each one into the remote you have and check the functioning by trying to turn the TV off. If you are unable to see instructions for setting the codes into your new remote, or if they weren't supplied by the seller, you'll have to find it's manual online and follow those instructions. It could be that Toshiba used the same control model for more than one TV set model. Often just putting in batteries will work but when it doesn't you have to treat the remote as a universal remote. If you can't use the primary unit setting to work you can try to set it up as an"AUX" unit as you would do for a second TV.
Dec 20, 2016 | Televison & Video
How to reset a Toshiba TV Model CT-90233
Probably needs the caps replaced in the power supply but I would get an engineer to tackle this job unless your confident at soldering.
Sep 09, 2014 | Toshiba CT-90233 Remote Control
Toshiba lcd CT-90302
This is not the fault with remote control. It must be the fault with the TV. Check its main power regulator board. Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. You can also click the [Home] tab to the latest updates. It will make search easy. There are more than 1300 posts to different brand TVs now. Pull up older posts there.
Nov 26, 2012 | Toshiba Ct-90302 Remote Control
High pich whine from CT-36D32 36" TV
jdosk-the high pitch noise you hear is generally from the horizontal output being shorted,the horizontal output is usually near the flyback transformer,get a digital multimeter to checkthis part.Let me know I'll try to help. cooltek Feb.16/08
Feb 05, 2008 | Panasonic CT-36D32 36" TV
Remote help
What is the model# for your set? Find your TV set below: MODEL: CT90157 PN: 23306517 MODEL: CT-90157 PN: 23306517 23306495 this remote has the pic size button Originally supplied with models: 32A33, 32A43, 32AF43, 32AF44, 35A44, 35AF44, 36A43, 36AF43, TOSHIBA Used with models: 13A21, 13A21C, 14AF43, 19A21, 20A42, 20A43, 20A44, 20AF43, 20AS21, 24AF43, 24AX61, 27A43, 27A61, 27A62, 27AF43, 27AF44, 27AX61, 27AX61C
Feb 27, 2007 | Toshiba CT-90157 Remote Control
Remote control code to program for directv receiver
What is the correct model@ for the set you own? Tv set that is... MODEL: CT90157 PN: 23306517 MODEL: CT-90157 PN: 23306517 23306495 this remote has the pic size button Originally supplied with models: 32A33, 32A43, 32AF43, 32AF44, 35A44, 35AF44, 36A43, 36AF43, TOSHIBA Used with models: 13A21, 13A21C, 14AF43, 19A21, 20A42, 20A43, 20A44, 20AF43, 20AS21, 24AF43, 24AX61, 27A43, 27A61, 27A62, 27AF43, 27AF44, 27AX61, 27AX61C
Dec 27, 2006 | Toshiba CT-90157 Remote Control
Help
Hi,I have this same model Tv. The Remote control Model is CT-90037 http://www.tacp.com/televisions/product.asp?model=CT-90037 You can pick it up often times on Ebay or Amazon. Hope that helps.
Sep 17, 2006 | Toshiba 50A50 50" Rear Projection...
Televison & Video Logo
50 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
