Question about Panasonic Televison & Video
Panasonic tc-l3232c has sound but no picture. The screen is not black it's grey and you can see some light. Please help! Thanks!
    Top Expert:
  • Panasonic Master
  • 75,581 Answers
T'Con board fault. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Posted on Apr 06, 2015
trintek
  • 111 Answers
SOURCE: panasonic tv TC-26LX60 PICTURE PROBLEM
if this is under warranty still, i would take it to a service center or rma it to panasonic.. if it is not under warranty, you can try the following.
1) try a different video source and verify the problem is happening on all video sources and modes.
2.a) if the problem is not happening in all modes, remove and replace the cable that is causing the issue. if this doesn't remedy the problem, the controller for that particular input is going out
2.b) if the problem is happening in all modes, you can open the case and carefully disconnect and clean (de-oxit or rid-ox) the hirose style connectors on the back of the display panel.
3) disconnect and clean all ribbon cables around the display panel
this sounds like either the connectors are not performing adequately or are loose, the top ribbon is acting up for some reason, or the graphic controller is going out.
Posted on Nov 15, 2007
  • 92 Answers
SOURCE: Plasma does stay powered on
Your sustainer board is probably bad. You need to get the Y & Z sustainer boards replace then it should be okay.
Posted on Feb 09, 2009
  • 267 Answers
SOURCE: Black screen with colored vertical lines
YPU HAVE A BAD PANEL. THE COST OF REPAIR WILL PROBABLY EXCEED THE VALUE OF THE SET.
Posted on Mar 20, 2009
  • 135 Answers
SOURCE: We have a widescreen plasma (Panasonic TY ST05-K).
Hi there! If picture is smaller top to bottom with blank section on top and bottom then check your aspect ratio settings. If blank at the bottom only the Bottom Y-Drive board may be faulty. If blank at the top The Top Y-Drive may be faulty. If blank on the Left (TOP TO Bottom) then the Right X-Drive Board and on the Right, the Left X-Drive Board. May also be bad connections on the cables or flexible ribbon cables. Best Wishes and Good Luck, JUS004
Posted on Aug 23, 2009
  • 8457 Answers
SOURCE: Panasonic hdtv, TC-P42X1, no picture,
Tries tv unplug,replug it back like about an hour later.The tv will be resetting itself back to the factory setting.Now the tv should be working again.If it still have the same problems.The tv have a power supply board problems.That the board,where the a/c power cord plug into it.Try website like Ebay.com to buy a refurbish power supply board for the replacement.
Posted on Jan 19, 2011
Panasonic TC-L58E60..Picture problems Can anyone help me solve what is wrong? I can fix it myself if i knew what was causing this issue thanks
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Nov 11, 2016 | Televison & Video
Panasonic TC-L47DT50 no picture no sound front lights com on
No picture or sound in my Panasonic TH-P42UT30A plasma ...
https://www.ifixit.com/.../No+picture+or+sound+in+my+Panasonic+...
iFixitAug 1, 2014 - Hi Ifixit,. I've got a Panasonic th-p42ut30a plasma tv that has a fault with it. The standby light is on (red) but it doesn't come out of standby.Missing: l47dt50
Panasonic Product Support - TC-L47DT50
shop.panasonic.com > Get Support
PanasonicSMART VIERA® 47" Class DT50 Series Full HD 3D LED HDTV (46.9" Diag.) ... Issues Addressed: Solves issue where the Emergency Alert System is displayed on the TVhours after the termination of the message. Solves issue where the Emergency Alert System is displayed on the TV hours after ...
Panasonic TX-P42X50B No Picture Or Sound ' Dead ...
? 9:00
https://www.youtube.com/watch?v=EanHoWLLpxU
Nov 6, 2014 - Uploaded by Electronic Workshop
Panasonic TX-P42X50B No Picture Or Sound This plasma television ... TV repair, clicking and will not power on, loud snap,no picture, etc.
Jan 27, 2016 | Panasonic Televison & Video
Anyone have problems with Panasonic TC-P60ST30 with white fuzzy picture mal-function?
Try going into set up menu and look for a screen degauzing function or try setting the screen temp. to warmer or cooler.
Aug 11, 2017 | Panasonic Viera Plasma TV TC-P60ST30
TC-L26x1 No picture at all
you must count the red light blinks. This will indicate where the trouble is located.
Apr 23, 2013 | Panasonic TC-L26X1 26 in. HDTV LCD
Panasonic TC-P42S30 plasma power light on black screen no sound?
Main digital board should be troubleshooted. If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electrical shock! Instead, contact any experienced service technician, or the nearest service center
Mar 09, 2013 | Panasonic Viera Tc-p42s30 42" Plasma Tv -...
Lightning hit nearby now my Panasonic tc-l3232c has sound but no picture what could be the problem?
Two issues come to mind on LCD/LED TVs with a blank screen. First and foremost, unplug it from the power source for a few minutes, then plug it back in and power on to see if your problem has gone away. If not, then the easiest way to diagnose the problem is to power on your TV in a pitch black room (or drape a thick blanket over it and peek underneath at the screen while it's on)... we want to see if the backlights are working or not. If the screen looks like it's 'lit up' with a dark gray tint to it, then we have backlight and there is another problem. If no backlight, then your set has a bad backlight inverter. In either case, this will require parts replacement. Panasonic is very tight with who they will sell their parts to, unlike other manufacturers and usually require authorization from a technician before selling them.
Dec 21, 2012 | Panasonic TC-26LX20 26 in. HD-Ready LCD...
Panasonic VIERA TC-L42U5 42-Inch 1080p 60Hz Full HD LCD TV (Screen doesn't work)
If you wish to get some details; visit the site linked here. Pull up older posts.
Sep 01, 2017 | Panasonic Televison & Video
Panasonic TC-P42X1 acts like it is turning on, the screen turns black, then the tv shuts itself off and back on again.
Rule out any loose contacts in power outlet, RC Jack, cables and connectors. The problem described by you calls for opening the back cover and further investigation, which should only be done by a qualified service technician.
Aug 17, 2012 | Panasonic TC-P42X1 41.6 in. Plasma HDTV
Panasonic TC-26LX70: No Picture or Sound
Hi adlawton, I have the same model with the exactly the same defect. Did you solved it? Please help me.
Thanks in advance
mirkofc
Nov 28, 2009 | Panasonic TC-26LX70 26 in. LCD Television
Panasonic tc-20la2 black screen
Try calling up a Menu for Picture on the screen with your remote.  Also check that it operates the TV and not the VCR or DVD player.
Good luck.
Dec 06, 2007 | Panasonic TC-20LA2 20 in. EDTV-Ready LCD...
Televison & Video Logo
103 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
