Question about Vermeer BC625 6IN Brush Chipper
What are the safety stops to prevent the engine from starting?
    Sergeant:
  • 458 Answers
The first thing I would do is remove the spark plug.
Posted on Oct 30, 2015
Can't get mark 8 1996 lincoln in to park
Your neutral safety switch is bad.The neutral safety switch is a safety device that only allows you to start your engine when the automatic transmission is in either Park or Neutral. ... This switch prevents you from starting the engine when the transmission is in any gear other than Park or Neutral.
Jul 11, 2017 | Lincoln Mark VIII Cars & Trucks
OUTDOOR UNIT START AND IMMEDIATELY STOP
Its probably a safety causing it to cycle off, or a component failure. It may have a low pressure safety switch. In the event of freon loss, this safety does not allow operation to prevent compressor damage. Or it has a high pressure switch. Same process but prevents excessive freon pressure.
Mar 07, 2017 | Heating & Cooling
I put on a deck belt for my huskee 42 and the engine wounld trun over
A safety feature on many newer mower decks and some older ones is: that the engine will not start if the PTO is engaged. Also there is a deck clutch (or deck break) that prevents the deck pulleys from turning. Make sure it is connected properly. It's under the deck and has a big spring on it. If the wire it is attached to has lost tension or is slack for some reason, the deck break will come on and prevent the tractor from starting. It's not usually an engine problem, but a friction problem. Because the deck pulleys are stopped by the break the high amount of friction is to much for the engine to turn over. This usually is the problem if you have the PTO ( deck engage lever) on before you try to start the engine.
I hope it's just this. :)
Aug 20, 2016 | Garden
Car in park turn key starter engages engine starts and you can hear the Bendix still spinning in the ring gear put car into drive and then they stop spending
Does the starter engage again when you go back to park ?
Shifting from park to drive would cut the circuit from the key switch to the starter. The neutral safety switch prevents you from cranking the engine in drive or reverse.
I would say the key switch is not turning off power to the starter when you go from start to run.
Sep 14, 2015 | Cars & Trucks
Location of fuel pump relay on 2000 toyota corolla
The relay is probably working correctly. It should power the pump for about 3 seconds then stop until the computer sees oil pressure or RPM from the engine.
This is a safety to help prevent a fire in a wreck.
The relay should be in the fuse box in the engine compartment.
Aug 26, 2012 | 2000 Toyota Corolla
Neutral safety switch in a 1999 monte carlo
Nope. The neutral switch has 2 functions. It prevents the engine from starting in any other gear but park and neutral. It also switches on the back up lights when in reverse. You have electrical problems located elsewhere.
Aug 13, 2017 | 1999 Chevrolet Monte Carlo
It turns over approx 3 to 4 times, then stops (lights go off, engine stops turning over), within 2 seconds and with the key still in the start position the lights come back on and the engine starts...
The starter has a thermal safety switch on it which is suppose to stop the starter from cranking when the starter is overheated to prevent damage to the starter. This switch is not working properly therefor stopping the starter from working.You have to replace the starter to correc this problem.
Apr 25, 2011 | 2000 Chevrolet Silverado 1500
Riding mower Safety Tips
Lawn mowers in general can be dangerous, but riding mowers and lawn tractors are even more so. Some models have better safety features than others. You’ll want to look for, at the very least: * A system that prevents the engine from starting unless the blade is disengaged and the machine is in neutral. * An automatic blade shut-off that stops the mowing blades if you stand up rather than sit on the machine, or if you leave the mower/tractor. * A system that stops the blade if you shift into reverse, or at least a lock that requires you to make a deliberate decision to mow in reverse.
Aug 27, 2008 | Husqvarna Lawn Tractor - 54in. Deck, 26...
Vermeer BC625 6IN Brush Chipper Logo
589 people viewed this question
Top Vermeer Heavy Machinery Experts
Jerry Kramer
Jerry Kramer
Tony Crow
john h
Are you a Vermeer Heavy Machinery Expert? Answer questions, earn points and help others
