My TV made clicking noises and had lines flickering side to side then went dead. Faint order of melted plastic
    Top Expert:
  • Televison & ... Master
  • 74,377 Answers
Fault in the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Posted on Apr 06, 2015
  • 39 Answers
SOURCE: tv went dead
its dead.  probably had a power surge or something.  you'll need to bring it to a good repair shop to replace the inverter.
Posted on Apr 21, 2009
MNfisherman
  • 11896 Answers
SOURCE: Sony KT-T25SF8 Dead, no video or audio, low level clicking noise
Most likly the Horizontal output transistor has shorted out because of cold solder connections on the flyback transformer, and or a bad capacitor in the sweep power supply and or, a bad flyback transformer. If the set Did not blow the fuse, then mopst likly you will have a problem in the main power supply where several parts in a kit form has and should be replaced all together.
Posted on Jan 17, 2009
  • 160 Answers
SOURCE: tv went grayscreen, flickering. turned off, then
When you had gray screen and flickering you had only one problem - color wheel. After "putting everything together" you have totally different problem, caused by multiple possibilities like: forgotten connectors, cut/jammed cables/wires, lamp not being inserted properly, lamp door not being set properly, disconnected color wheel, etc. Try to open rear cover and redo what you have done. Remove optical block, check everything visually and slowly put everything back. If still no luck - then only skilled TV repairman may (or may not) help.
Posted on Mar 10, 2010
  • 12 Answers
SOURCE: My Protron power adapter went
THIS PLACE SELLS THEM
http://lcdpayless.com/productpage.php?productId=4902
Posted on Dec 27, 2010
gopakumarg43
  • 74377 Answers
SOURCE: powers up - white picture with lines and no sound
Sounds like a min board fault. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Posted on Feb 14, 2014
LG 60PS60-UA had horizontal thin black lines across the bottom half of the TV. I tried reseating y board with tv on and it went black and makes a faint clicking/pop noise everytime I turn it on now
If you wish to get some details; just Google for the site "Elelctro help". Pull up older posts. Surf the site with patience.
Line, faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent.
Apr 21, 2015 | LG Televison & Video
Powers up - white picture with lines and no sound
Feb 14, 2014 | RCA L26HD35D TV
HP Officejet J4550 All In One Reset Button
Hp printer/scanner J4550
1 day my parents did not power off my printer, they simply unplugged it so they can plug it into another room that had a phone jack so that they could fax something to the bank. ( too lazy to get a extra phone cable or just drive to the bank.. ) well anyways , they moved it, and plugged the power cable in.. as soon as they hit the power button, it went... CLICK CLICK CLICK CLICK CLICK... for about 1 minute.
it would let them auto print a blank sheet of paper.
but it would not let them access the fax or scan options.
the printer said read the manual ect...
its an old printer.. no manual...
But.. what i noticed is that.. this click noise was not really printer related. what it was ... was actually the scanner !
If you open the scanner door ( the top part of the printer)
you will notice that on the right side.. when you hear the clicking
its actually the scanners light wheel machine bounceing back n forth on the right side. about 1 minute after you open the door, then the light turns off and the scanner lazer wheel thing moves to the left. I noticed that on the right side.. there was some white plastic dust... you will notice how there is a line going across that kind of looks like a coat zipper with the plastic tringle's / line .
well 1 of the triangle's broke... so its like a broken coat zipper.. and the printer can't get the scanner lazer thing to the right side of the printer, so it kind of gets stuck... so basically... you need a new printer :( or if you are a plastic specialist.. or can find some type of plastic replacement, you would be able to melt some plastic or glue something idk..
well anyways, i just wanted to share my store.
the clicking on my printer came from the scanner lazer light not being able to reach the right side of the printer box b/c of a missing tringle plastic thing on a plastic line.
like i said, you could try to re-melt some plastic their, but it wouldn't last all that long... metal would work, just has to stay in the shape of the other small triangles.
( best option is to just buy a new printer )
you can get them for like 40 to 50 $ at wal-mart and they normally even come with ink...
Jun 04, 2012 | HP OfficeJet 6110 All-In-One InkJet...
Tv went grayscreen, flickering. turned off, then
Mar 10, 2010 | Samsung Televison & Video
TV set was on normally, just went blank screen and
I fix this problem with CRT computer monitors alots when it was popular.Ur high voltage is dead, FBT,The flyback transformer,and the horizontal Transistor it dead.The FBT,the big block of plastic with a red wire with cap hook to Ur CRT,"H" transistor to the left steal square side wall.The problem is easy to fix,if u
have some basic sodering skill."H" Transistor is easy
to find.But FBT,it hard to find these day.If u want to tries to fix.Here are some websites might have the FBT for the Sony Tv. Shopjimmy.com,Tv repair World.com,Ebay.com.
Feb 04, 2010 | Televison & Video
The tv made a squealing noise, the picture went out and flashes of light came out from the sides of the bottom of the tv.
Ur FBT,flyback transformer is dead,the big block plastic wth a red wire solder to a board.Might also have to replace the deflection board also.
Oct 14, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
SONY KV-32TW67 FAINT GREEN AND RED LINES ACROSS WHOLE SCREEN
friend maybe your LCD was broken or loose. try to pull gently if it return to normal image.
Jun 30, 2009 | Sony KV-32TW67 TV
Power window switch on 2008 Civic
Roll the window down. Now hold the button to roll it up and keep holding the button even after the window stops - you may hear a faint relay click noise. It is then reprogrammed. Sometimes I have to do it two or more times because I did not hold it long enough.
Mar 27, 2009 | 2008 Honda Civic
TV flickers when turned on
this sound like panel or inverters that drive the lamps ( fluorescent lamps that are not replacable they are part of the panel).
Jan 16, 2008 | Polaroid FLM-3201 Television
TV Flikers and StandBy Light Flickers
Your pdp panel sounds faulty - Count the red flashes this is an error code.
Nov 13, 2007 | Sony PFM-42B1 42 in. HD-Ready Plasma...
Televison & Video Logo
32 people viewed this question
Top Televison & Video Experts
Electro Med Services...
