We just bought a Bunker Hill Safe.We loaded the safe and locked it up when we went to try the lock we turned the know and heard somthing fall inside now we can't open it all.Please advise it's full
  • 3 Answers
Get a pro to open it
Posted on Apr 06, 2015
2 Suggested Answers
  • 3 Answers
SOURCE: bunker hill safe
i had the same problem this is what i did. i took the lil leg off the bottem it held on by a srew take a cloths hanger put it in the hole and now u can hit the lil button that is for makin a new code it is on the hing side of the door the yellow light will come on and stay on now put ur new code in then hit a or b i used 1111a then changed it once i got in o by the way ''the factory code is 159a try this first" and the cloths hanger i shoved a ear plug on the end of it so that way it could grip the button hope this helps somebody
Posted on Nov 29, 2008
How can I open my Bunker hill safe 95824 with a battery failure ?
Call harbor freight in CA and they'll let you know if there is a cure. They have an 8xx number for ordering parts and such, which is also their 'tech support' line.
Aug 15, 2014 | Computers & Internet
Bunker hill safe #91006 the batteries are dead and I do not have the key
You are going to love this answer.
I have two Bunker Hill Safes. I bought them at the same time. The batteries in both of them died at the same time. And like a dummy, I had the keys to each safe inside themselves.
So, after going to many forums and looking at videos on youtube. I found the solution and it worked. I now have the keys for the two safes in my combination safe. (no batteries on that one)
Here it is:
1) Get a soft rubber mallet (a hammer with a rubber tip works best) And of course, you can get those at Harbor Freight where you bought the safes.
2) FIRMLY tap the safe, just ABOVE the key board panel, and on the plastic cover. You must be hitting the top of the door and not the body of the safe, in order for this to work. (The locking mechanism internally will bounce up when you do this.)
3) At the same time, you must try to turn the knob/dial, that opens the safe. It will take a few tries to get the timing down, but it works.
On my first safe I did scratch it up a bit and crack the plastic housing a little. On the second safe it did it perfectly and left no marks on it. After doing that I was kind of freaked out on how "secure" these safes really are.
But how many people are going to know this.
Now I change out the batteries every year on my Birthday.
Good luck!!
Apr 18, 2013 | Check Point Network Adapter
I have a bunker hill safe ,item# 91006,batteries too low,no key, drilled out overide lock,still won"t open, now what?
you can also get some wires feed him into the back contacting the battery terminals hold in there with a 9 Volt, four hands and patieance and then..... you get my drift. Worked for me! :) $
Dec 26, 2012 | Computers & Internet
Can't open safe, locking mechanisim broken
wont hurt to ring the safe maker or a locksmith
for a second opinion
Mar 29, 2017 | Home Security
My husband locked both keys in the safe 94985...
Search on "How to open a safe with a potato" and you'll find a youtube video on how to open that safe. All the Bunker Hill safes use the same lock mechanisms which have a critical design flaw if the spring on the solenoid is weak in that the plunger bounces enough to allow the bolt to be thrown open if you can time hitting the front of the safe just right. Of course, if you mount it such that you can't get a good swing in then no problem. There are two adjustment screws to the bolt throw, if your safe is easily opened this way, you might want to adjust these screws so that more of the plunger hits the stop. I couldn't get mine to open with a rubber mallet but it's mounted so you can't get a good swing in.
Jan 30, 2010 | Check Point Network Adapter
Bunker hill safe model no.45891 bought used, can't open. any ideas?
Safe has Key lock hidden on it? Contact Harbor Freight with serial number, to try and get new key. Once opened follow these instructions at:
http://www.harborfreight.com/manuals/93000-93999/93575.pdf
Oct 20, 2009 | Check Point Network Adapter
CANT UNLOCK BUNKER HILL BOOK SAFE
Battery died and i can't find the key or the instructions to open the safe
Sep 22, 2009 | Locks & Locksmithing
I have a bunker hill safe digital, and battery is too low to open the safe and cant find my key, probably inside, any suggestions
If you have the small electronic Bunker Hill safe with lost keys and dead batteries, this is a potential solution... Take a hammer and strike the top of the safe while attempting to open at the same time. You may need to place on object on top of the safe such as a flip flop shoe to strike with hammer to smooth out the pressure when striking. It should pop open after several attempts.
Jan 25, 2009 | Check Point Network Adapter
Bunker hill digital safe
CHANGING CODE ON MODEL # 45891:
On the inside of the door toward the hinge, you will see a small red button. Press this button until the yellow light on the front control panel lights up. Now you can imput the new code (1 to 8 digits) into the front control panel, followed by either the "A" or "B" key. The safe will beep twice (2 times) to confirm the code has been changed. Important: If the safe beeps 3 times, then the code has not been accepted and you must repeat the above steps.
DO NOT LET THE BATTERIES RUN OUT BECAUSE YOU WILL NOT BE ABLE TO OPEN THE SAFE OR CHANGE BATTERIES.
Dec 19, 2008 | Check Point Network Adapter
Cannot get my Bunker Hill Safe open.
get the key number that is listed above the key hole and then call 888-299-3427 for a replacement
Nov 21, 2008 | Check Point Network Adapter
Computers & Internet Logo
238 people viewed this question
David Payne
David Payne
