Question about LG DLG5002W 27" Gas Dryer
Dryer is not heating and it says check filter. What does that mean?
Not heating check filter
  • LG Master
  • 2,322 Answers
The check filter light is only a reminder. it goes out after cycle is started.
Posted on Apr 18, 2015
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 15 Answers
Check filter could possibly mean more than that, what it indicates
is an air flow restriction in turn not allowing for burner flame to ignit
as would cause over temp. fault, if not filter only check and make sure no pinched or crushed exhaust vent hose or external vent cover
and lint build up to restrict air flow ,hope this provides all angles of your symptoms.
PAUL DOUGLAS
Posted on Apr 06, 2015
    Top Expert:
  • LG Master
  • 50,354 Answers
There is a lint filter that needs cleaned . usually every time you use the machine check this link LG D1102W Owner Manual Page 35
I have Electrolux dryer model number EIED55HIWO and it says E64code...what do I need to do?
It indicates that there is an open it the heating circuit. It most likely means the heating element has gone out in it.
Feb 12, 2018 | Electrolux Dryers
LG Electric Dryer DLE2140W, it keeps running plus no heat. It says check filter, but filter is all clear.
Dryer will only turn off when cloths are dry. Seems like you have a failed heat circuit. If electric, first reset the circuit breaker (double) a couple of times. If gas, call a tech.
Oct 14, 2015 | LG DLE2140W Dryer
What does it mean when the filter check comes on. The dryer works but doesn't dry well.
May have to remove cabinet and check inside appliance for a lint build up around blower etc. check ur venting out of appliance and into wall as well. lastly u may have a heating element going out,
Feb 13, 2015 | Samsung Dryers
Kenmore gas dryer has heat, but very little...
what do you mean by a little heat?do you mean it will heat for the first 15 to 20 minutes and then no heat,if so you have bad gas coils,the coils will work normally until they heat up and then they fail,when they cool they will work again,also you could have a blocked vent line or the duct that the lint filter could be clogged with lint and has to be cleaned out.remove the vent line from the back of dryer,if it's long blow it out with a leaf blower,then remove the duct that the lint filter slides into and clean it out and vac out the cabinet that the motor is in,with a gas dryer you should do this once a year so your dryer runs good and you don't have a fire.hope this helps
Aug 03, 2012 | Kenmore 63942 Dryer
Samsung dv218eb dryer runs but won't heat
No heat almost always means a heating element. But if you ar talking low heat, then check the lint filter; exhaust pipe for clogges and that the fan is circulating the heat up to the drum.
Aug 14, 2011 | Samsung Dryers
Whirpool dryer 10 years old is still heating but taking very long to dry clothes. Checked dryer vent and it is clear. Will heating element help?
If your heating element is still heating up the cause lies elsewhere. Filter for dryer both at the base of dryer and filter location . If you are getting heat then airflow is the problem. how is the fan motor in front of heating element
Mar 09, 2010 | Whirlpool LER5636P Electric Dryer
Does not heat I have cleared the vents and filter
if your dryer doesn't heat, check these:----
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected. Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.) Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Jan 11, 2010 | Kenmore Elite Oasis 6808 Electric Dryer
ESTATE DRYER NOT HEATING
Check for a blown thermal fuse. It's about an inch long and is inside the rear of the dryer, usually attached to or near the exhaust duct. It can be tested using a multimeter or ohmmeter. Check for continuity. A lack of continuity means a blown thermal fuse. The filter being full of lint has most likely caused the fuse to blow, Sorry for your trouble and I hope this helped. Best wishes.
Sep 14, 2009 | Estate TEDS740JQ Electric Dryer
Won't heat up
Try removing the lint filter from the dryer and with no clothes, start the the dryer, and if it works then replace your lint filter.
Tip: Fabric softener sheets in the dryer can deposit an invisible coating on the screen of the filter and reduce air flow.
May 27, 2008 | LG DLE2532W Electric Dryer
LG DLG5002W 27" Gas Dryer Logo
726 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
