Question about Maytag Dryers
Maytag dryer runs about 30 min. and starts making a loud noise. I turn it off 5-10 min. Restart is quiet then louder with time. Month prior had restricted airflow code cleaned vent no prob. till now
    Top Expert:
  • Maytag Master
  • 45,204 Answers
Bearings are going out and they will quit completely if not changed sooner than later .
Posted on Apr 06, 2015
    Novelist:
    Habit-Forming:
  • 112 Answers
The dryer drum rotates on two rollers towards the back. The bearings in these rollers dry out and freeze up or barely turn. The drum then bumps around on them making noise. Unplug the dryer. Remove the front panel by removing two screws on lower end and lift panel back and up so top comes out. Remove the frame (4 screws) holding the drum and fan cover. Unplug electric wires from door switch. Carefully pull the drum out a few inches, look thru the back of the drum and record on paper the threading pattern of the belt on the pulleys to the lower left of the drum. Continue removing drum and belt. Take the clips off of the two rollers that the drum was rolling on back there. Remove the two rollers and clean the bearing surface and shaft. Lube the two surfaces with suitable oil or grease. I use silicone grease. Also remove belt idler pulley and lube bearing surface. Reassemble all. To put belt on, hang it on the drum, slip the drum in 3/4 of the way, reach thru the drum and thread the belt on the drive and pulley correctly. Ease the drum onto the two rollers in back, rotate the drum while easing the belt into proper running position. You should be able to fit the front roller frame into the cloth lined channel, then replace the front panel. Plug it back in. Try it! Don't mess with it with the power on.
Posted on Dec 15, 2015
5 Suggested Answers
  • 41 Answers
SOURCE: Dryer making loud noise
the humming noise is most likely your motor. does it overheat or shut down on you? do you smell anykind of burning? Joe
Posted on Nov 18, 2008
  • 311 Answers
SOURCE: Maytag Dryer squeeling
Drum support rollers. I cannot see your repyl due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Posted on Nov 28, 2008
kachbibi1
  • 979 Answers
SOURCE: LOUD NOISE AND BURNING SMELL
How old is this dryer? If it is older that 15 years get a new one. You don't want to deal with the headaches. The motor may be going bad on it and the wiring could be melting. I assume it is not working now. Have him check the breakers. Make sure the connections are o.k. in the back. Clean out the lint piping and look for lint underneath it as well.
Posted on Jan 14, 2009
  • 86 Answers
SOURCE: Dryer is making loud noise while running
Hello. It sounds like an issue with either the motor or a component in the motor drive subassembly. Go to http://www.pcappliancerepair.com/model-display.php and enter your model number. Two versions will pop-up, but both share the same parts. Scroll-down on your left side for the motor drive section and then on you'll see an illustrated picture of all the parts there. I doubt it's the main motor, but the sealed bearings could be dried-up and needs to be repalced, but I'm leaning more towards a worn-out gear
Posted on Apr 03, 2009
Dryer starts and runs fine but makes a loud buzzing noise from the motor that sounds a lot like the end of cycle signal
FIXED Dryer won't start. Makes electrical buzzing noise - model ...
www.applianceblog.com/.../7655-Dryer-won-t-start-Makes-electrical-buz...
Feb 12, 2007 - 10 posts - ‎1 author
It makes electrical buzzing noise when you press the start button. ... One would think that if it's the fuse that it wouldn't buzz at all but ... unplugged, re-assembled back, hooked back up to hose, turned on and running hot .... The belt was fine. ... Kenmore gas dryer 70 series is making very loud buzzing noise.
Troubleshooting Your Dryer Noises ' PartSelect.com ...
? 4:32
https://www.youtube.com/watch?v=Tk1YezyYMDY
Aug 26, 2011 - Uploaded by PartSelect
In this video you'll learn why your dryer may be making a variety of ... that is not only making a grinding noise but it also makes a loud banging noise. ... it's been drying about 15-20 min. it startsa loud humming sound. ... The dryer is working just fine, but I am concerned about the noise as it sounds electrical.
DRYER BUZZING NOISE - Dryer For Sale
Dec 18, 2015 | Amana DLE330RAW Electric Dryer
Dryer heats however will not turn, prior to it stopping it was making a loud squealing noise for weeks
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Feb 12, 2011 | Maytag MDE308DAYW Electric Dryer
MATAG DRYER, MAKES A VERY LARGE HIGH PITCH SQUEEL
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Asker's Testimonial " This should give me an ida of what to look for once I open er up " -
Apr 15, 2010 | Maytag Dryers
I have a kenmore dryer, recently it has started to be loud, on start up and has a loud hum when running. It runs for 20 min and turns off. If you try to restart it just hums. if you wait about 30-45 min it...
It is possible the belt has come off the the tensioner pulley, or the pulley itself has locked up and is putting a strain on the motor making it run hot and tripping the thermal overload. Either that or the motor is getting weak and needs to be replaced.
Dec 28, 2009 | Kenmore Dryers
My Maytag dryer buzzes when I push the start button. If you hold it in, the dryer will start but makes a noise, almost like a bad belt. After a few minutes the dryer will shut itself off and will not...
Remove the belt from the motor and push 'start'. If the motor makes loud noises, squeals, or the shaft has side play in several directions, then it probably is the motor. Replace it. If the the motor runs quietly, then check the drum by hand to see if it is making excessive noise while turning. There should be a little resistance to turning, but not real difficulty. Hope this helps.
Aug 13, 2009 | Maytag PYE2300AY Electric Dryer
New Maytag dryer model mgdc400vw makes loud humming noise
Weird, try making sure it is level, and make sure your vent pipe aint too long. Tip the cabinet back while running if the noise goes away the damn metal vent pipe is too dang long.
Jun 09, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune MDE9700AYW Elec. Dryer. Drum Not Turning
the problem is with its motherboard .. i too had the same problem.. ask the repairing persons to change the motherboard if it is warranted. ( but there is no other way)..
Apr 21, 2009 | Maytag MDE9700AYW Neptune 174 Electric...
I have a noisy Maytag LDG 7500 gas dryer.
thats your blower wheel.pop the hood take off the frount the blower is at the bottem.if you are able to turn it and the drum dose not turn thats your problem
Dec 31, 2008 | Maytag PYE2300AY Electric Dryer
Dryers Logo
130 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
