Question about Hitachi Televison & Video
After moving house we put our Hitachi CLE-970 back in our bedroom and put the aerial plug in. We can't get any channels ???? Yet our other TV works fine when plugging it in to same aerial plug???.
  • Hitachi Master
  • 16,010 Answers
Go through the setup program again to scan channels, check the connection on the set for damage and looseness
Posted on Apr 06, 2015
The on off button on the remote control. All other buttons work.
new remote needed probably also try unplugging tv from wall socket for ten mins then retry remote failing that
www.genuineremotes.co.uk for a new remote
Apr 09, 2014 | Hitachi CLE-970 Remote Control HL02127
My daughter has a Goodmans GTVL19W17HDF in her bedroom for two or three years. She has only now mentioned that she has now lost ITV1 Channel 4 and Channel 5 using DTV, and also has a very inconsistently...
Fisrt check that the aerial connector going into the TV is OK.
The UK is in the process of switching off the analogue channels and reassigning to digital TV. This means that the signal strengths of various transmitters are getting stronger and channels are moving around to different frequencies. Try retuning the digital TV stations. If this does not work then try an external DTV box to see if the TV is at fault or it is a bad signal on the aerial.
May 16, 2011 | Televison & Video
Can't pick up channels itv, channel4/5 and itv2 on my bedroom freeview tv and down stairs doesn't pick up film4 and a few others?? I have only recently connected the bedroom aerial to the ariel which was...
hi when fitting an new aerial line you need to put a splitter in the line.
4963215_1-oo4k03phwtyaxld0gomgkgbv-2-0.jpg it looks like this. they say satellite/tv on them this will stop interference from the boosters and the tvs on the same line, you connect it on the main arial line. you can then use both boosters if signal is weak but most digital aerials are good enough without them. it you have the right arial for your area. there are meany sizes. but say you are 15 miles from your tower then use a small aerial has the same fitting as this pic. that is out side aerials, inside aerials ie in loft you need a high gain aerial , long type. hope this helps. also if the aerial is not lined up it will not get great signal there is an app you can use on iphone or androids, tables etc to help you position the aerial in the right place it's called Uk aerial alignment . tool on app shows you the towers in your area and the best ones to use and shows you the aliment to the tower for best results. good luck
Jun 22, 2017 | Samsung LE40R74BDX 40 in. LCD Television
Lost our freeview. New TV in bedroom (Sharp LCD, LC-19SH7E-BK), which has freeview and was working fine. However, we set up a magic eye so we can have SKY (which we can now use through channel...
if you have connected your sky box as per instructions, putting the aerial coax to it and a fly lead(as in a male to female coax as used on a vcr to tv) from the output to the tv's aerial input, then disconnect the aerial from the sky box and put it back to the tv. The skybox will weaken and even loose the signal.
Feb 14, 2010 | Televison & Video
Hi, I have a digital tv plugged into an extension cable in an upstairs (Toshiba) bedroom; it works perfectly - receiving all channels. I have a digital tv downstairs (Samsung) where it seems the wall...
Hi Fiona
Somewhere along the line from the aerial there must be a signal splitter that feeds the upstair and downstair terminals.
Try to find that splitter and switch the output to see if the problem goes from up to downstair.
If it does switch then you know the problem is with the splitter block, and if it stays the same then the problem is with the cable and/or the connectors that run downstairs.
Also the reason you get a pixellated(snowy) picture is because of signal loss during the length of the cable you ran downstair.
If running a cable downstair becomes the best option to fix your problem , then you could buy a cheap 10db signal booster/r.f amplifier to correct the signal loss and a cable splitter to feed both tv`s
That booster would be installed upstair in your case(near the source of the signal to be amplified).
I could send you a small diagram if need be. Hope this will help and Merry Chrismas
Dec 14, 2009 | Televison & Video
Manual tuning of Hitachi cle-942 tv
Select the channel to tune & press "CH" this is the key to the right of zero on the CLE-942 remote, Now you can tune the selected channel. You also need this key to sort/move channels after running auto tune.
Aug 20, 2009 | Hitachi HL01453 Remote Control
Hitachi CLE-976 problem.
The CLE-976 was no a cellular phone but a remote control for a Plasma TV. I contacted Hitachi Australia who put me into contact with a company that sell spares.
Thanks
Aug 04, 2009 | Sprint Hitachi P300 Cellular Phone
KEEPS SAYNG NOT PROGRAMMED TO WATCH NORMAL CHANNELS
Do a first time installation, move the TV or bite the bullet and either buy an external aerial or extend the main house aerial cable to reach the TV. assuming your TV has no signal where it is now
May 04, 2009 | LG 42LC2D 42 in. LCD HDTV
Tuning
Same here. I have the tv with a hitachi r/c CLE-87613 but can't tune the tv to the aerial channels.
My email is tonyhutchinson@hartsheadgroup.co.uk
Nov 27, 2007 | Televison & Video
Televison & Video Logo
94 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
