Question about Garden
Old M70-130067 Sno Thro my Dad says it just conked out cant pull the pullstart at all and the electric start doesnt even make a sound ...... oil looks fine ..... suggestions ?
  • 2,760 Answers
Assuming you have already tried to remove all external drive belts from blower (to remove all load from engine) try removing the spark plug from engine , and try pulling engine over with pull start (it cant start) if it still fails to move at all or is real hard to pull look farther for an internal engine fault , if it does move then you have an "Hydraulic" problem most times is caused by motors oil inside cylinder , most times caused by head gasket failure or turning engine on it's side will do it too
Posted on Apr 15, 2015
How do you fix a pull start
-Take the handle off the rope. You want to only have one knot in one end of the rope. (Of course, if the rope's already broken, you can skip this step ....)
-Get the reel and lay it facedown.
-Get the coil, and begin carefully winding it up so that it fits inside the grooved edge on the reel. BE PATIENT - this will take time.
-On the inside of the coil, there should be a little hook on the end of the coil. That hook matches one inside the pullstart cover when you put the two pieces together. The trick is to get the hook on the reel to catch the hook on the pullstart cover. CAREFULLY put the reel and coil inside the cover, and ***** the bolt in for a moment to hold it in place.
-Turn the pullstart reel clockwise until you feel the hooks catch each other. Feel some resistance? Good, that's what you want.
-Take the bolt back out, and reassemble the starter pawl assembly inside the pullstart, then put the bolt back in and tighten it.
You should now have a complete assembly, minus the pull rope. -Now, looking down into the pullstart, notice there is a hole in the reel off to one side. This is where your rope threads through. Grab the reel, and crank it around about .... four or five times, and try to get the hole in the reel lined up as close as possible with the outer hole in the pullstart cover. -Take your rope (you DID take the handle off first, right? Oh yeah, it broke off ...), and thread it through the reel, then through the outer hole in the cover. This will be a little tricky, as you need to be holding the reel so it doesn't unwind ...
-SLOWLY let the reel start to retract, but don't let it go all the way. Does it look like it's drawing the rope all the way back in? If so, great! If not, pull the rope back out, crank the reel around another turn, and try again.
-Once you have the reel set to where it will retract the rope all the way, thread on your handle and tie it off. You're done!
Apr 16, 2016 | Motorcycles
Fluid levels in gear box
Amber. With machine on level surface,fill gear box with specified gear oil until it starts running out the fill hole on front of gear box.
press the helpful button and follow me on fixya for more tips
Service
Craftsman snowblower auger gearbox lubricant
Sno Thro Engine Oil Gear Case Lube
Auger Gear Oil Sorry to ask again Snowblower Forum Snow Blower Forums
Feb 09, 2016 | Garden
Ryobi chainsaw rcs4640n pullstart slips frequently
sounds like the gears on the pullstart mechanism is starting to get stripped there generally not expensive a small engine parts store can get it for you
Jul 28, 2014 | Ryobi Garden
Why sno thro continues to run after ice block is removed
Because that is how it's designed. It's designed to run again, after you remove ice block.
Apr 29, 2014 | Ariens Snow Blower. Sno-Thro Deluxe Drift...
Auger does not engage on Ariens Model 924121 sno- Thro
first check shear pins in the auger ( try to turn big auger by hand, engine off)
then if they are good then try to turn impeller by hand, engine off
youll need to turn it a few times before the larger ones turn, but thats what you want
if they dont turn then you have sheared the gear box gears
be sure belts are good tooo
Dec 15, 2013 | Ariens Snow Blower. Sno-Thro Deluxe Drift...
Mcculloch 650 user instructions
put 2stroke mix in,put chainbar oil in,pull choke out,pullstart till fires,push choke in,pull start,goes
Nov 01, 2013 | Garden
We have an Ariens ST 504 Sno-Thro that is probably 25 to 27 yrs old. Husband had it running a week before our first big snow storm. The day of the storm he tried to start it and couldn't get it ...
Need to know things like
Has it got a good blue strong spark??
Is the fuel getting to carb / remove air cleaner and look to see if primer is squirting fuel in??
Is there "suction" when trying to start engine by using hand over intake manifold with air cleaner off.
All "aspirated" engines need spark / air and fuel.
Is fuel clean and recent with correct oil added??
Jan 08, 2010 | Champion International Champion& Small...
I have a 7 HP Ariens snow blower Model # 910995 S # 007686. It made a popping sound and stopped yesterday. The elec start cranks but the engine won't start. Checked the engine oil, which was low and filled...
Pull the spark plug out, cover the hole with your finger and slowly pull the pull starter. You should feel compression. If not look for a blown head gasket or valve problem.
Jan 04, 2010 | RTO Sno Wovel wheeled snow shovel
Pullstart wont pull
sometimes the float in the carb can stick causing the gas to fill the engine, this will prevent the engine from moving and therefore locking the pull cord. check the oil, is there gas in the oil? remove the spark plug and try to pull the cord again. gas may come out of the plug hole . if this is the problem you must change the oil and fix the carb. the other cause could be that the engine is seized. ouch.
I hope this helps
Sep 01, 2009 | Garden
Ariens SnoThro w/5hp Tecumseh has no fire
Check the fuel. Pour some fuel into a clear jar and let it set. See if it seperates due to water in the fuel. Very common problem.
Rich
Jan 15, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Garden Logo
572 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
